Old 10-28-2013, 08:20 PM   #1
TurboLaaag
Member#: 369841
2011 Subaru
Default car feeling odd today need a log look-over
car seemed a bit under power today so I hooked up the accessport to log, one of my main concerns is the fkl, till today I have NEVER seen my car show more then -1.4 at low load and that was once in a never ( so not worried about that) but today im seeing alot of (from my experience anyways) -2.45's at upper RPM's. With the car feeling the way it did and seeing the fkl I was a bit worried so I didnt do a super hard pull.
INFO:
2011 STI
AEM CAI
COBB 3.33 stg1 aem CA91 map
3rd gear pull starts at line 615-633
https://docs.google.com/spreadsheet/...UE&usp=sharing
TurboLaaag is offline   Reply With Quote
Old 10-28-2013, 09:38 PM   #2
nismopowerdqg
Member#: 312580
2010 WRX SWP@310/334
Cobb/Torqued Performance
i believe on the 08+ STIs +/-8% is normal in the A/F learning range, that being said you are quite close to that line with the -6.25, so just keep an eye there (possibly a post MAF leak). Also see a tiny bit of FKL which is at low loads, wouldnt be TOO concerned with that either.Also, it dosent appear that your reaching target boost of 18 psi.
nismopowerdqg is offline   Reply With Quote
Old 10-28-2013, 09:41 PM   #3
TurboLaaag
Member#: 369841
2011 Subaru
so I decided to change maps (went back to v330) and do a hard pull and it went perfect, no fkl, no knock in general.. felt amazing really.. but none the less would like the log above read along with this one if possible.
did a 3rd and 4th gear WOT on this one.
https://docs.google.com/spreadsheet/...Hc&usp=sharing
3rd gear = lines 57-96
4th gear = lines 97-113
MANY thanks,
Paul G.
Old 10-28-2013, 09:46 PM   #4
Chicago AJ
Member#: 353343
'13 WRX Sedan Stg 3
'13 Prius C 86mpg!
If your boost target is 18, you're not even close.
Chicago AJ is offline   Reply With Quote
Old 10-28-2013, 10:28 PM   #5
TurboLaaag
Member#: 369841
2011 Subaru
never have been close even with HWG maps. I have gone through and checked every hose under the hood and all is tight and good, so I have no clue on the boost target issue. All I know is that cobb claims all cars respond diff, Im in the process of contacting clark turner for an e-tune so Im hoping he can resolve what cobb cannot with the major low boost issue with there ots maps.
Old 10-28-2013, 10:31 PM   #6
TurboLaaag
Member#: 369841
2011 Subaru
im guessing this is after looking at my first log?? if so then Im not surprised as the v3.33 decided to just go weird on me, if you could please check the last log I posted and let me know what you think because I think it looks pretty dang good.
thanks again,
Paul G.
Old 10-28-2013, 10:56 PM   #7
Airboy
Member#: 72829
2006 WRX
2015 WRX
What is your elevation? Wastegate and boost targets are quite low.
Airboy is offline   Reply With Quote
Old 10-28-2013, 11:02 PM   #8
TurboLaaag
Member#: 369841
2011 Subaru
I'm east bay sf bay area, so sea level
Old 10-28-2013, 11:24 PM   #9
snoopy_sti
Member#: 164942
2013 WRX STI Limited
2007 WRX STI Limited
You should be hitting what the map notes say at that elevation.
snoopy_sti is offline   Reply With Quote
Old 10-28-2013, 11:39 PM   #10
TurboLaaag
Member#: 369841
2011 Subaru
COBB says alot of things, just waiting for them to do something.
Old 10-29-2013, 10:18 AM   #11
bluemax189
Member#: 137405
20g 6spd
I doubt your target is 18psi. Looking at the TD boost error, you're not too far off your from your targets which looks to be about 14-15psi. Which exact map are you running(stage 1 or 2) and have you played with that in ATR?
bluemax189 is offline   Reply With Quote
Old 10-29-2013, 10:25 AM   #12
Cobb Tuning
Member#: 4803
These maps are "boost select" maps and the boost target will vary by the SI-DRIVE mode that you have selected. The 17.0 psi peak boost target will only be in Sport # mode. Sport mode will target a peak of 14.5 psi and Intelligent 8 psi. It looks like perhaps you were in Intelligent mode in the first log and Sport mode in the second. For maximum performance, you will want to do a run in Sport # mode.
Old 10-31-2013, 11:15 PM   #13
TurboLaaag
Member#: 369841
2011 Subaru
the beginning of the log i was in S but for the 3rd & 4th gear pull i was in S#.
I was able to get suuuuper close to target 17.16psi (with 3.30 map) but it was during the cold morning time (high 40'sF) and in 4th gear not 3rd, on a side note I was getting random FKL's and FK's that I could not reproduce myself about once to twice a day and the sums where always -1.4 or -1.45. This was with both 3.30 and 3.33 maps but now that Ive again resorted back to 3.30 from 3.33 I no longer get any FKL's but only FK's now, long story short i went into my AP and retarded the timing by 1degree and can no longer get any FK's or FKL's out of the car no matter what I do (which is awesome) . here is the morning log with FK's.
https://docs.google.com/spreadsheet/...0E&usp=sharing
Old 11-01-2013, 09:51 AM   #14
TurboLaaag
Member#: 369841
2011 Subaru
I may have jumped the gun with retarding fixing the FK, went as far as retarding to 3degrees and still got a random 1.4fk . So am I wrong to assume that what the knock sensor is picking up is not knock but an engine bay noise?
