Old 10-31-2013, 12:47 AM   #1
02nismokiller
Member#: 322963
04 wrx
psm
Default 2.1 Stroker pistons
Ok so I did some research but came to no avail. I'm starting a 2.1 stroker build but I'm stumped on which pistons to get. I've read that the wiseco's are noisy but want to know what other are running and how they been running so far.
Thanks in advance guys/gals
02nismokiller is offline   Reply With Quote
Old 10-31-2013, 03:14 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I have run wiseco and manley with no problems.
Old 11-01-2013, 09:39 AM   #3
02nismokiller
Member#: 322963
04 wrx
psm
Which were quieter?
Old 11-01-2013, 12:02 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by 02nismokiller View Post
Which were quieter?
Watch your piston to wall clearance. Both are offset wrist pins. The 2.1L Stroker wiseco vs the Manley was quieter from our experience. IIRC the wiseco had a longer shirt compared to the Manley.
Old 11-02-2013, 01:00 AM   #5
02nismokiller
Member#: 322963
04 wrx
psm
So having the longer skirt is more beneficial or mot really?
Old 11-02-2013, 09:52 AM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Yes, keeps the piston from rocking; slapping.
Old 11-02-2013, 12:29 PM   #7
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
If you're looking for quiet, you may want to look at the mahle 4032 pistons.
Guess it depends on what power level you are wanting.
theotherguy is offline   Reply With Quote
Old 11-03-2013, 09:13 AM   #8
02nismokiller
Member#: 322963
04 wrx
psm
Hmmmm how do these do performance wise? They as strong as the Manley or wiseco? I did some research and found that the mahle stroker pistons has a compression ratio if 8:1:1 vs the others are 8:5:1
Old 11-03-2013, 09:17 AM   #9
MartinSTi05
Member#: 145145
2006 wrx STi
I have used several different brands of pistons, only one brand of 2.1L though. If you are not planning on making mega power I cannot recommend Mahle enough. the 4032 Alloy allows you to run 1 .0025-.003" PTW. Couple that with the skirt coating (which is thicker and better IMHO than what can be had on other brands pistons) and they are as quiet as stock. I have used standard 2.5L and 2.1L Mahles and loved the results. I have had good results with other brands at the expense of slightly more noise. Also Mahle comes with excellent rings that in my experience have seated quickly and consumed little to no oil
MartinSTi05 is offline   Reply With Quote
Old 11-03-2013, 09:28 AM   #10
02nismokiller
Member#: 322963
04 wrx
psm
Are they pretty strong pistons though? I plan on pushing 22psi and maybe 24psi with my ported vf48. Plan on hitting 350whp
Old 11-05-2013, 12:02 PM   #11
subaru_gc8
Member#: 29292
2004 WRX wagon
I think you are going to need more turbo than that to hit 350whp. I was told that a 18gxt would do it
subaru_gc8 is online now   Reply With Quote
Old 11-07-2013, 12:48 AM   #12
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
^^^ or some much better fuel.
Old 11-07-2013, 09:57 PM   #13
theotherguy
Member#: 191514
'05 FXT 6spd, 98
I would be comfortable with 350whp if I was comfortable with the tuner.
