Old 10-30-2013, 08:20 PM   #1
gregbenoit
Member#: 156545
2007 WRX STi
UGM
Default MY 07 STi won't pass smog…Please help!
My 2007 STi won't pass a smog check. I did mod my car but it has been back to stock for a couple of years now. I have no idea what it could be. Any help would be appreciated.
Thanks, Greg
gregbenoit is offline   Reply With Quote
Old 10-30-2013, 08:50 PM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
Thanks, Greg
Very descriptive. Maybe if you provide more information about what was done previously, you might get a reasonable response. Did you not have to get smogged last year?
JonnyV2889 is offline   Reply With Quote
Old 10-30-2013, 10:36 PM   #3
gregbenoit
Member#: 156545
2007 WRX STi
UGM
I'm sorry. I posted this thread in a panicked rush. I had a catless exhaust system and a protune from Jon at HB Speed in Califonia. I changed the intake to a Cold air set-up. I also switched the fuel pump. A basic "Stage 2" set-up. After it was tuned it was boosting about 21psi. Then the motor blew. I put all the stock parts back on and I took the car to Subaru in Fullerton, Ca and they put a new short block in it. After I got it back it was bone stock and nothing has been changed since. This the first year that I've needed to smog my car.
Old 10-30-2013, 11:30 PM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
What did they fail you for? Codes? Emissions? Visual inspection?
Also, blowing you motor, returning to stock and defrauding SOA for a new motor. Weak.
Old 10-31-2013, 12:01 AM   #5
gregbenoit
Member#: 156545
2007 WRX STi
UGM
Originally Posted by kpluiten View Post
What did they fail you for? Codes? Emissions? Visual inspection? Also, blowing you motor, returning to stock and defrauding SOA for a new motor. Weak.
Passed everything but emissions...It passed in higher rpms but it failed at idle. And I really DGAF what you think is weak. Any and all info is appreciated but comments/opinions are not necessary.
Old 10-31-2013, 10:58 AM   #6
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
Do you have a CEL?
CRAZYHAWK is offline   Reply With Quote
Old 10-31-2013, 12:02 PM   #7
gregbenoit
Member#: 156545
2007 WRX STi
UGM
No CEL's. The car runs just as good as when I bought it. I did hear something about the valves tightening up and restricting emission flow. But I really don't know.
Old 10-31-2013, 01:33 PM   #8
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Failed at idle would suggest bad 02 sensor, or bad catalyst. Both of which SHOULD turn on the CEL. In any case, you're probably going to have to take it to the dealer so they can use their diagnostic equipment to figure it out.
Bacon117 is offline   Reply With Quote
Old 10-31-2013, 02:14 PM   #9
gregbenoit
Member#: 156545
2007 WRX STi
UGM
I took it to the dealer and they couldn't find anything wrong. They checked the o2 sensor and the cats too. I left the dealership with absolutley no answers.
Old 10-31-2013, 02:22 PM   #10
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Dealer just shrugged and said GTFO? Interesting. Do you know specifically what the smog tester said failed? CO2, NOx, etc.?
Old 10-31-2013, 02:40 PM   #11
CRAZYHAWK
Member#: 198067
WHITE Premium
If you mean the valve adjustments are tighter than spec. , have them
readjusted. Tightening the valves would produce less power near idle,
and more at high rpm.
Old 10-31-2013, 02:42 PM   #12
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Did you flash a stock tune back on the ECU after getting it running again? And when you say all stock...all stock exhaust parts including the cats?
darkstarmoto is offline   Reply With Quote
Old 10-31-2013, 03:08 PM   #13
gregbenoit
Member#: 156545
2007 WRX STi
UGM
Pretty much. The service advisor kept my car for a week and then told me that the tech couldn't figure it out. I was super disappointed. I'm not sure what failed. I do have the paperwork. I'll check and post it.
Old 10-31-2013, 03:10 PM   #14
gregbenoit
Member#: 156545
2007 WRX STi
UGM
Yes and yes.
Old 11-01-2013, 09:45 AM   #15
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
It's probably a cylinder balance issue. One cylinder is running slightly lean, but another is running rich. Overall the engine is stoich, but emissions are bad. A lean cylinder will create NOx, while a rich will create CO. The catalyst should take care of the CO, but a gasoline engine doesn't do anything with NOx, because it isn't supposed to run lean. (As an interesting aside, that's what the new diesel fluid in modern diesel pickups is for, it removes NOx from the exhaust). This is why I was curios about what you actually failed. If you had High NOx, this would indicate one cylinder is running lean.
But, What's causing the cylinder imbalance is the question. It could be valve lash. You can also measure exhaust temperature at idle to see if there are any differences. You might also want to do a compression check just to see if there is any cylinder imbalances there.
Old 11-01-2013, 01:57 PM   #16
gregbenoit
Member#: 156545
2007 WRX STi
UGM
Thank you for the info.
