Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 06-20-2013, 10:49 PM   #1
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Default 2010 WRX stuck in second after PAR dogbox install.
So I bought a trans from a buddy of mine and swapped the internals to my trans case. I first didn't realize that the shift forks had to be swapped over too. It was installed and got locked in second (what the shop said, will explain later.). They tore it apart and swapped the rest of the parts over. I got it back today and drove it maybe 100 miles before it locked up. When it happened, I was shifting from second (which is helical for some reason) to third. Now comes the strange part. The only "gear" or gear position the shifter will go into is second and it will appear to come out of gear into neutral and not go into any other gear position, however the trans doesn't go into neutral.
So, what could it be? Shift fork? Collar damaged from my stock forks?
Old 06-22-2013, 01:51 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Anyone?
Old 06-24-2013, 05:47 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Bueller?
Old 07-04-2013, 09:37 PM   #4
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Torn apart again and nothing changed but seals, locked in third now. Could it be shift linkage or anything? Everyone that's looked inside has said that it looks perfect. I don't know how or why it keeps doing this, but I'm fairly certain that the tranny itself is fine.
Old 07-04-2013, 10:05 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
detent balls......not visible unless you had everyone who looked inside the box, remove the shift rails too.
Jay
Old 07-04-2013, 10:35 PM   #6
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Yeah, I had the shop look at them and they were there and fine.
Old 11-01-2013, 10:57 AM   #7
gqjag7921
Member#: 330669
2003 WRX
Any updates on this issue?
gqjag7921 is offline   Reply With Quote
