Old 10-26-2013, 10:54 AM   #1
Sudo
Member#: 332175
Default $50 Gauge overlay for 02-06 WRX
For a while now I've been pretty disgusted at the green glow from my factory gauge cluster. Something had to be done and the DIY route never seems to come out that well.
I came across these while browsing ebay last week.
http://www.ebay.com/itm/01-07-Subaru...aa8e8c&vxp=mtr
I ordered them up and they arrived at my door three days later. Being just an overlay with It's own light source the install took about 30 minutes. I tapped into the radio dimmer for power and the same harness for ground.
Here's the end product.
Still need to red out the hvac controls
If only this company made a completely red set.
Sudo is offline   Reply With Quote
Old 10-26-2013, 11:04 AM   #2
DrSnazzy
Member#: 368848
I really like the look! How did you get the stock overlay off?
DrSnazzy is offline   Reply With Quote
Old 10-26-2013, 11:18 AM   #3
Sudo
Member#: 332175
The stock overlay stays intact. I used some scotch poster tape to keep the new overlay down. It's thin enough not to impede needle operation. The manufacturer says the bezel is enough but I'm skeptical. I've done a few overlay installs in the past in this manner and they've held up so far.
Old 10-26-2013, 11:22 AM   #4
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
That actually looks pretty good
Old 10-26-2013, 11:23 AM   #5
Sudo
Member#: 332175
Also there's another more expensive variant. I wanted to go this route but they're $110.
http://www.ebay.com/itm/131010284233...84.m1438.l2649
There is a 140mph 9000rpm variant in blue and red
Old 10-26-2013, 11:25 AM   #6
Psychoreo
Member#: 79643
2015 WRX STI
The cheap one looks better than the overly busy expensive one.
If I ever get rid of my jdm cluster, I might pick one up.
Old 10-26-2013, 11:30 AM   #7
DrSnazzy
Member#: 368848
Its in KM/h tho :'(
Old 10-26-2013, 11:30 AM   #8
DrSnazzy
Member#: 368848
I like the one you got better actually
Old 10-26-2013, 03:25 PM   #9
vms150
Member#: 172917
2004 WRX
This can't fit 01-07. 02-03 has the speedo in the middle and tach on the right, while 04+ has the tach in the middle and speedo on the right. Seems this will ONLY fit 02-03.
vms150 is offline   Reply With Quote
Old 10-27-2013, 09:17 AM   #10
Sudo
Member#: 332175
I wanted to remark again after I drove with these for a while.
The speed markers are on 100% (Measured with my GPS).
Traditionally we have 55 and 75 mph speedometers here in the US to suit our common speed limits. I was thrown off a little bit by the 60 and 80 mph markers on these gauges. Overall I feel this is a subtle difference and will only take a little while to become accustomed to. So far I absolutely love these.
Old 10-27-2013, 03:22 PM   #11
xsv141
Member#: 231904
2007 WRX
UGM
http://www.ebay.com/itm/2004-2005-Su...4c4030&vxp=mtr
these ones are pretty cool as well and a good alternative to changing the color of the lights. i thought about getting them to see what it looks like
xsv141 is offline   Reply With Quote
Old 10-28-2013, 02:53 PM   #12
jnich69
Member#: 242484
2003 18g'ed wrx
sunset orange metallic
Does anyone think you would be able to put a stage gel behind these to change the color like other people do with the stock cluster? I really want to change the color of mine and if it can be done with these overlays without messing with the stock ones that would be awesome.
jnich69 is offline   Reply With Quote
Old 10-28-2013, 04:43 PM   #13
mrkevinchiu
Member#: 283396
SILVER
and how did you get your middle console lights change? did you get the bulbs from the same dealer?
mrkevinchiu is offline   Reply With Quote
Old 10-28-2013, 06:19 PM   #14
m4r10
Member#: 41877
02 wrx
Not bad for less than $50.
Is it backlit? It looks like all of the warning lights come through no problem.
m4r10 is offline   Reply With Quote
Old 11-01-2013, 09:36 AM   #15
Sudo
Member#: 332175
Middle console was easy. There's no green tint on the hvac controls. Just picked some up some bulb condoms from amazon to replace the existing ones.
The gauge overlays are in fact self lit. The only warning light not showing through properly is the oil indicator.
Here's a closeup day pic
Uploaded with ImageShack.us
Yes i was driving. Tisktisk
Old 11-01-2013, 10:01 AM   #16
Mattman57
Member#: 346692
2004 WRX
I saw these a while back and wondered how they would look. Thanks for doing this. You made up my mind
Mattman57 is offline   Reply With Quote
Old 11-01-2013, 10:09 AM   #17
Mattman57
Member#: 346692
2004 WRX
you're right about that. Looks like you would have to trim this one to separate the tach and speedo.
I coulda swore I saw this one for an 04 a while back...but now can't find it.
Old 11-01-2013, 11:33 AM   #18
WREXMachina
Member#: 275929
02 WRX
I used this exact same overlay in my 02 last year. Was a bit of a pain to get on, but it's been running great.
It is developing some cold spots (Spots where the light isn't as bright) but it's not very noticeable.
WREXMachina is offline   Reply With Quote
Old 11-01-2013, 01:26 PM   #19
Mattman57
Member#: 346692
2004 WRX
yea I'm pissed I can't find one for the +04's. I really hate the dim green display and do not want take mine apart and take the green film off. Also that way seems to have more uneven bright spots
Old 11-01-2013, 01:26 PM   #20
vms150
Member#: 172917
2004 WRX
You could not cut them apart to fit because the lighting system for that panel is on 1 wire for the 2 gauge faces.
Old 11-01-2013, 01:40 PM   #21
Mattman57
Member#: 346692
2004 WRX
Yeah after I said that I was looking at it more and realized it probably wouldn't work.
Plus I believe the middle display for our cars are bigger then right display. So the tach off this cluster face for an 04 would be too small and the speedo would be to big.
