Old 08-08-2013, 02:24 PM   #1126
tersplat
Member#: 337888
2003 WRX Wagon
wagon MY: 03
rim size: 18x9.5
rim offset: 38
rim brand & model: Rota Grid
tire brand & model: Bridgestone RE970AS Pole Position
tire size: "245/40/18"
tread (actual patch) width: ?
camber adjustments: front -1.7, rear -1.5
suspension: Tein flex coilovers
lowered?: ~ 25mm
fender rolling?: yes- rolled and pulled in the read, sedan conversion in the front
rubbing w/o load?: No
rubbing w/ load?: No
(handling /gearing- gearing is around oe with version 7 cluster, handling is wonderful- very sticky street tire, very stiff sidewalls
tersplat is offline   Reply With Quote
Old 10-21-2013, 01:03 PM   #1127
Sebeastin
Member#: 348599
2002 Wrx wagon
Psm
Man this thread has been quiet for a while, well I was wondering if I would run into any issues with a certain setup and if I can run a certain tire size also
2002 wrx wagon
Rim size: 18x8.5
Rim offset: +44
Rim brand and model: rota grid
For suspension I will be running rce wagon springs and for struts I will have tokico dspecs.
I want to run 235-40-18 size tires and I was also wondering if I could run 245s also for more meat and traction. I will have my fenders rolled and also have sedan front fenders. Anyone know if there is a possibility of running 245s?
Sebeastin is offline   Reply With Quote
Old 10-21-2013, 01:28 PM   #1128
needasubie10
Member#: 234907
2002 wrx wagon
mbp
2002 wrx wagon
Rim size: 18x8.5
Rim offset: +44
It has been quiet, I'm running the same size wheel and close to rhe same offset on a 225/40. Also running dspecs and prodrive blues. I have definate rub in the rear on hard cornering and if there is someone in the back. I'm not rolled, so I can assume I would help. But I won't be rolling anytime soon as just yesterday I picked up the last peices to my sedan body conversion.
needasubie10 is offline   Reply With Quote
Old 10-21-2013, 01:37 PM   #1129
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
I have a 2002 wagon on RCE wagon springs. 17x7.5 ET48 wheels with 225/45-17 tires.
I had no rubbing, but I rolled the rear fenders just to play it safe.
My guess is that you may rub with that sizing. Or, it will be veeery close.
mmiller2002 is offline   Reply With Quote
Old 10-21-2013, 01:39 PM   #1130
Sebeastin
Member#: 348599
2002 Wrx wagon
Psm
Are you converting just the front fenders or the rears quarter panels also? Yea fender rolling would definitely help. I want to run 235s at least and 245s at most for the extra meat and grip. I will be autoxing and tracking it a few times a month. I have plans to convert the rear quarter panels to sedan later on, but for now I'm just doing a roll and possibly a slight pull in the rears if I need to to for those tires and wheels
Old 10-21-2013, 01:41 PM   #1131
Sebeastin
Member#: 348599
2002 Wrx wagon
Psm
Yea I'll be rolling the rears and maybe a slight pull if need be to fit 235s or 245s, I like those for the extra grip and meat, plus I love the 18" on these wagons. Props on the wagon, paint those side skirts and your golden bro
Old 10-24-2013, 12:27 AM   #1132
Sebeastin
Member#: 348599
2002 Wrx wagon
Psm
2002 wrx wagon
Rim size: 18x8.5
Rim offset: +44
Can anyone else help with this?
Old 10-24-2013, 09:57 AM   #1133
JonnyV2889
Member#: 197384
2006 WRX Ltd
Most likely doable with some added camber, what choice for a tire will make a difference. I'm running a fat 235 (rsr) on 18x8 + 48. Rubbing inner fender well (loaded) with stock camber lowered on blacks. You may need to massage the inner fender with a hammer. A lift spacer would probably help as they aren't wagon spec.
JonnyV2889 is offline   Reply With Quote
Old 10-24-2013, 02:05 PM   #1134
Sebeastin
Member#: 348599
2002 Wrx wagon
Psm
How much camber are we talking about? I don't want to go too far since I will also be daily driving it. I was thinking about running Falken azenis if they are any good for performance, still fairly new to this stuff. Yea I'll be getting the wagon spec ones just to stay wagon specific. So your saying that 235 would be the widest without big fender modifications?
Old 11-01-2013, 01:27 AM   #1135
Sebeastin
Member#: 348599
2002 Wrx wagon
Psm
Anyone that can inform?
Old 11-01-2013, 10:18 AM   #1136
wrxsomeday
Member#: 141991
14 FRS Ultramarine
16 Forester XT CWP
FYI, your rim diameter doesn't matter if is a 17 or 18. What matters is the width, offset, and tire size. I'm sure there is another person in this thread with the same setup, you will just need to search.
Tire width by tire brand also varies greatly. Both Federal 595 RSR's and Dunlap Star Specs run wide for their size. For reference, on my last wagon, I ran a 225 star spec on an 8" wide wheel that were +48 and I rubbed in the rear (about -1 or -1.5 degrees of camber). I rolled the rear fenders (didn't pull) and had plenty of clearance.
With your setup, I'm guessing that you will be fine with a rear fender roll and maybe a slight pull. Otherwise adding camber will help (maybe - 2 degrees?) but depending on your application (assuming its not hella flush), I wouldn't want to exceed -2.0 degrees of camber.
wrxsomeday is offline   Reply With Quote
Old 11-01-2013, 11:37 AM   #1137
Sebeastin
Member#: 348599
2002 Wrx wagon
Psm
Thanks man, your input is greatly appreciated, yea I'm only dropping about an inch both front and back on racecomp engineering wagon springs so I want be "hella flush". I want it to be functional.
Old 11-01-2013, 11:40 AM   #1138
wrxsomeday
Member#: 141991
14 FRS Ultramarine
16 Forester XT CWP
Ah yes that rights, I forgot to mention that my old wagon was on RCE yellow springs (and I think I kept my 3/8" spacer on the rear). The RCE wagon springs are a bit higher in the rear than the yellows without a spacer, so I would think you would be at my same ride height or perhaps a hair higher.
Post pics when you're done!
Old 11-02-2013, 07:14 PM   #1139
Saabaru300
Member#: 334105
2005 Saab 9-2x Aero
Ver8 EJ207, 6MT, Red
Wagon MY: 2005 Saabaru
Rim Size: 17x8.25"
Rim Offset: +35
Rim Brand & Model: XXR 530
Tire Brand & Model: BFGoodrich G-Force KDW NT
Tire Size: 235/40R-17
Tire (Actual Patch) Width: ~8"
Camber Adjustment: Stock 0 Front, 1.5 Rear
Suspension: Stock Struts, Epic Engineering Lowering Springs, 1/2" Subtle Solutions Aluminum Spacer in rear
Lowered?: ~.7" Front, 1.3" Rear (Not including spacers)
Fender Rolling: Yes, rear fenders rolled and very slightly pulled. Nothing to fronts.
Fender Rubbing w/o Load: Nope
Fender Rubbinh w/ Load: Nope
Handling/Gearing: Stock Everything Else
Notes: Front tires stick out of fenders about a 1/2" but doesn't touch fender. Want to get coils and higher offset 8.5" wide wheels to fit 245/35 tires.
Saabaru300 is offline   Reply With Quote
Old 11-02-2013, 10:29 PM   #1140
sc00by4life
Member#: 97135
Originally Posted by Saabaru300 View Post
Wagon MY: 2005 Saabaru Rim Size: 17x8.25" Rim Offset: +35 Rim Brand & Model: XXR 530 Tire Brand & Model: BFGoodrich G-Force KDW NT Tire Size: 235/40R-17 Tire (Actual Patch) Width: ~8" Camber Adjustment: Stock 0 Front, 1.5 Rear Suspension: Stock Struts, Epic Engineering Lowering Springs, 1/2" Subtle Solutions Aluminum Spacer in rear Lowered?: ~.7" Front, 1.3" Rear (Not including spacers) Fender Rolling: Yes, rear fenders rolled and very slightly pulled. Nothing to fronts. Fender Rubbing w/o Load: Nope Fender Rubbinh w/ Load: Nope Handling/Gearing: Stock Everything Else Notes: Front tires stick out of fenders about a 1/2" but doesn't touch fender. Want to get coils and higher offset 8.5" wide wheels to fit 245/35 tires.
0* camber is flat dangerous.
Old 11-02-2013, 11:53 PM   #1141
Saabaru300
Member#: 334105
2005 Saab 9-2x Aero
Isn't that subaru's spec on the front wheels. What is so dangerous about it?
Old 11-02-2013, 11:59 PM   #1142
sc00by4life
Member#: 97135
no manufacturer would ever set factory alignment to 0 camber.
Old 11-03-2013, 12:03 AM   #1143
shimmies
Member#: 248524
02 Wrx Wagon
The stock Subaru alignment specs does include 0 in the range. Not optimal but it is what's on the sheet
shimmies is offline   Reply With Quote
Old 11-03-2013, 12:36 AM   #1144
Saabaru300
Member#: 334105
2005 Saab 9-2x Aero
What is bad about 0 camber in the front? I had this alignment done at a standard mechanics place after I had installed the lowering springs.
Old 11-03-2013, 12:52 AM   #1145
sc00by4life
Member#: 97135
do some reading on how camber works.
Old 11-03-2013, 04:10 AM   #1146
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Plenty of cars aim for 0* camber. But keep in mind that's on stock suspension where it compresses a lot more on turns. As it compresses negative camber increases. So you get camber when turning which helps cornering but no camber when going straight which helps tire wear
cowboy_Rob is offline   Reply With Quote
Old 11-03-2013, 10:39 PM   #1147
pescatom
Member#: 215425
16 STI DGM
06 WRX Wagon SGM
Scoob: From what I've learned, Factory sets front camber near zero and rear more negative to induce plowing/pushing (not spinout) in emergency situations. In the turn the outside tire will lose grip and go straight instead of turn. As you're probably talking about performance applications, you do dial in more negative in front to get optimal grip on the outside tire in a turn, so that it goes where you want it to, and not plow straight. Do you agree with me? If not can you further explain how zero camber in front is dangerous? And why most factory cars appear to be close to, or at, zero camber setting? http://www.miata.net/garage/align.html
http://www.ffcars.com/FAQ/handling101.html
Thanks Mike
pescatom is offline   Reply With Quote
Old 11-18-2013, 11:24 AM   #1148
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
Just ordered new tires. Ordered a set of 235/45/17 to get a little bigger sidewall but the guys over at tirerack called and talked me down to a 225/45/17. I really like my 235/40/17 tires but the tire selection just isn't there.
wagon: 2005
rim size: 17"x8"
rim offset: 45??
rim brand & model: Enkie RPF1
tire brand & model: BFG G-Force Sport Comp2
tire size: 225/45/r17
camber adjustments: will update when installed.
suspension: D-Specs, STI springs, Whiteline Camber Plates upfront, Group-N in the Rear, Sedan LCAs.
lowered?: Slightly... STI Springs
fender rolling?: Yes
rubbing w/o load?: No.
rubbing w/ load?: No.
Reason for posting this info here is b/c the BFG tires run very large. While talking to the TireRack Folks (Blake) we looked at the tread measurments and the patch is 3/4" different from the 235. This is the main reason I was ok with going to a 225. The standard difference is 10mm. The overal height of the 225/45 was 25.2" which is the "set max height" vs the 235/45 at 25.4" which would likely hit the spring perch.
Previous Set-up:
wagon: 2005
rim size: 17"x8"
rim offset: 45??
tire brand & model: BFG KDW2
tire size: 235/40/r17
bdj238 is offline   Reply With Quote
Old 11-20-2013, 01:57 AM   #1149
socalbugeye
Member#: 356276
2002 WRX Wagon
Originally Posted by tersplat View Post
wagon MY: 03
rim size: 18x9.5
rim offset: 38
lowered?: ~ 25mm
Really, really similar to what I'm looking at. I'm looking at 18x9.5, 245/40/18 as well, but +40 offset. I'm wondering if this will fit on my wagon with the issue being I'm on stock suspension. I can roll/pull my fenders, but I, unlike you, do not have the sedan conversion in the front, and am not on coilovers. I'm sorry if this is a n00b question, I searched the thread and forum and couldn't find anything specific enough to what I'm looking at. Is there any way this will fit without rubbing?
socalbugeye is offline   Reply With Quote
Old 11-20-2013, 02:29 AM   #1150
sc00by4life
Member#: 97135
You need coilovers for that fitment.
245 or wider tires on the rear? (WRX) j y Brakes, Steering & Suspension 8 07-05-2011 02:32 PM
245/40r17 or 235/45r17 on 17x8? toebotypera Tire & Wheel 7 06-08-2007 12:14 PM
245/50/16 or 245/45/16 tires on 16*7 rims?? coolray Tire & Wheel 0 09-28-2005 01:17 PM
Prodrive PFF7 and 235 tire on a wagon?? Alan l. Tire & Wheel 5 07-09-2005 12:36 AM
245 or 235s for my 18x8.5s tifosi77 Brakes, Steering & Suspension 3 12-02-2002 12:58 AM
