Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 04-25-2013, 03:34 PM   #26
CygnusPerformance
Member#: 201606
2013 STi Hatch
PBP
Originally Posted by Bullit62 View Post
Geoff,
Thanks for the advice and the recommendations on parts! After installing the Super Pro adjustable sway bars (24F/22R) and the Super Pro front control arm bushings (including the ALK) my car has been transformed! The slop that was present with the "yellow" bushings is gone, the steering is far more neutral and the car is just stupid fun to drive again! I really wouldn't have considered the Super Pro parts until talking to you but I'm glad I did. Super high quality and some really nice little touches like the metal rings imbedded in the front LCA front bushings and the sway bar lock rings mounted to the rear bar before the powder coat.
And the package price you worked up for me sealed the deal!
Thanks again!
- Jon
Thanks very much, Jon Glad you are happy with your new set up.
-Geoff
Originally Posted by chimchimm5 View Post
Hi cygnus/Geoff what do you recommend for me?
In my case I have a 06 WRX wagon with stock arms and SPT pink springs. The narrower-than-sedan width of the wagon arms is an absolute curse in many many ways. Besides camber problems with sedan struts, I also have another independent problem: squeaking, clacking, popping, clunking endlinks.
I have adjustable 22mm/22mm Whiteline sway bars with Whiteline bushing type heavy duty endlinks (used to have Kartboys with similar and different problems). I think that due to the slight lowering of the SPT spring, the endlinks are forced to lean inwards more for the typical / \ configuration. So I put in washers (kartboy spacers are too thick for the provided hardware with Whiteline). This improved the angle slightly and helped... for awhile.
As the miles have racked up, the endlinks have become more problematic. They clunk and pop so violently that you can feel it in the brake pedal and foot well. You can hear them shifting in place even in stuff like backing out of a parking space and turning. And the fact that the popping becomes worse with time shows how un-ideal the setup is. (To your point in your OP you say they need to be 90 degree; which I agree from an engineering standpoint). I would actually prefer the side-to-side thump of the sway bar shifting with ball joint endlinks than the popping/jarring of bushing endlinks popping in various positions.
I can mask the problem by changing replacing the hardware every somany 1000 of miles, but that is a bandaid to the real problem, and a bandaid I'm sick of doing. My current bandaid step is to get super long bolts to insure the 90 degrees.
But I can't just get ball joint because they don't make them specifically for the wagon. I'm willing to do the modification (hole enlargement) but I wonder if the single ear of the wagon endlink mount actually can hold the forces meant for two. If not, this is yet another temporary bandaid solution.
What would you recommend?
I'm going to PM you on this so we can talk more about your specific issues. I will do my best to help you out with this.
Thanks,
Geoff
CygnusPerformance is offline   Reply With Quote
Old 04-28-2013, 02:57 PM   #27
Panterag82
Member#: 277974
2008 STI
Lightning Red
Post Suspension Continued...
Your article was very informative and has me educated on sway bars, end links, and what to expect. That said, now I have even more questions tying all this into a more complete suspension. I have an 08' STI hatch and its a street/daily driven car only with a stage 2 AMR kit on it. I want to keep the car neutral as you suggested thinking a 22/22mm front/rear sway bar set up with end links is the way to go. The next set of questions pertains to springs and struts.
With the sway bar set up chosen how do I go about choosing the right spring/strut set up that will compliment the sway bar set up?
Thanks for the help, my suspension knowledge is limited to say the least!
Panterag82 is offline   Reply With Quote
Old 05-01-2013, 07:57 PM   #28
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
OEM '13 is 22mm front/20mm rear correct?
DisrupTer911 is offline   Reply With Quote
Old 05-22-2013, 12:35 AM   #29
ajsti24
Member#: 345666
2015 STi
Correct!
ajsti24 is offline   Reply With Quote
Old 05-30-2013, 03:16 PM   #30
lordsanointed
Member#: 301522
Awesome thread!
lordsanointed is offline   Reply With Quote
Old 06-01-2013, 12:08 AM   #31
DDabs
Member#: 339686
2013 WRX Sedan
It says that 22mm front/24mm rear is only for 04-07. Is this not a possible setup for a 2013 WRX hatch?
DDabs is offline   Reply With Quote
Old 06-06-2013, 02:21 PM   #32
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Nice writeup, especially your take on which bar combos work for what.
As an added data point I snapped a brand W rear endlink in half. The thin bent ones not the super beef AL ones. Also the '02's have really weak rear mounting brackets, as you pointed out. I broke one of those too. Both ears where it mounts to the frame snapped clean off. A relatively cheap and easy upgrade is to replace the mounts with later model STi mounts. They're much beefier. This was only running a 22mm bar, BTW.
bushflyr is offline   Reply With Quote
Old 06-06-2013, 03:57 PM   #33
DZXN
Member#: 306186
2002 Subaru WRX
Hey Geoff,
What sway would you recommend to replace a Hotchkis front competition bar? I ran into some problems with mine today, luckily I was not in a bad area of the road or driving too hard. I have the competition rear as well, I really am not too sure I want to replace the front with the same as what just broke.
[IMG][/IMG]
DZXN is offline   Reply With Quote
Old 06-15-2013, 03:22 AM   #34
EodSTI
Member#: 248467
2006 sti
flat black/white/mud
So my car makes up the .0000001% of most Subaru owners, I lifted my 06sti' kept the stock sways because they are perfect for where and how I drive, but the endlinks are the real problem, I've broken 2 sets of perrin's and now the Heavy Duty Rallitek's I bought are bending, and bad- I need something that is gonna hold my sways in place. I drive off road in a loose setting so I need endlinks that can handle abuse. Rallitek's never even got to see dirt.
Personally I might just have to make some from scratch from some stiff heavy metal I got around the shop, the lift isn't even done but the spring alone pushed the Rallitek's to a damn near breaking point. Any help would be welcome., ty man.
EodSTI is offline   Reply With Quote
Old 06-19-2013, 02:49 PM   #35
Igs
Member#: 359913
08 Impreza Wrx
Awesome Post man! I had no idea that sway bars could make such a big difference and I am pretty stoked about this.
I just got my Rex on friday and have been LOVING every minute of it. On the other hand I have the dreaded 08' Rex and as you must very well know, its a cushy sunuvub*tch. It's crazy fun to drive but it quite frankly scares me to turn fast on this thing.
Granted I am changing out the crappy all seasonal tires for some stickier summer goodness ( I live in brazil, no snow).
Thing is I am still learning how to drive it ( my last car was a 150hp FF ) but I was running it on 225 summer tires and back breaking H&R springs. The WRX has the original 205 all seasonals but I applied the same confidence first time I drove it and darn near crapped myself as the front leaned over and the back pivoted when I took my foot off the gas. Let's just say it was my first spirited driving WRX experience and I would like something a little more flat.
Now Brazil isnt known for its great pavement and it is quite bumpy out here.
I would certainly like to try out something more neutral though but not back breaking. Problem right now is that the stock suspension is just too darn soft and it leans over like an SUV. I love the REX but this 08' stock suspension just isn't working for me at all and it is quite frankly ruining a bit of the experience. It's such a confidence inspiring car until I turn hard you know? I just know the car can be SO much more than this. Help me Obiwan Kenobi!
PS: I should add I won't be tracking the car or AutoXing and its an Daily Driver. Also...it doesn't have VDC for some reason..the button is just not there...
Igs is offline   Reply With Quote
Old 07-09-2013, 02:30 PM   #36
Silentwolf8
Member#: 343898
2013 STi Sedan
PW
What are your thoughts on the WRX and the STi Sway bars. (08+) I have a STi sedan and my buddy has Hatch WRX. are they the same. or is the STi slightly bigger. will they match over to give him a better stiffer ride then his stock wrx suspension.
Silentwolf8 is offline   Reply With Quote
Old 08-01-2013, 01:42 PM   #37
bucata206
Member#: 333333
Great post! I recently got a bugeye (after an incident with my 04...) and not I'm in the process of trying to figure out what suspension and sway bar combination to go with. I daily drive the car and love to autox. My last car the suspension was already done so now I have a stock car and trying to figure out how to do the suspension. This post helped a lot with the sway bars! Thank you!
bucata206 is offline   Reply With Quote
Old 08-10-2013, 03:22 PM   #38
That_Black_Subie
Member#: 364987
Default Ride hight difference
I just recently installed some coilovers in my wrx and I've noticed that the left rear side is about a 1/4 inch lower than the right. Both coilovers are adjustable and they are at the same hight adjustment. Is it possible that the sway bar could be causing a difference in ride hight on each side by the amount of tension on it? A little help would be greatly appreciated
That_Black_Subie is offline   Reply With Quote
Old 08-11-2013, 04:06 AM   #39
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
Default Test it.
Undo the end links. If the sway bar is causing the height diff, disconnecting the sway bar will eliminate its influence. The sway bar resists twisting, but if it's connected with the suspension evenly loaded, the ride height should remain level.
dagger108 is offline   Reply With Quote
Old 08-20-2013, 11:48 PM   #40
f7firecatkid
Member#: 308605
perrin ones good? any of them?
f7firecatkid is offline   Reply With Quote
Old 08-27-2013, 08:51 PM   #41
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
How do you feel about solid (Whiteline) verses hollow/tubular (Cobb) sway bars for a daily driven 2011 STi with BCBR 8k/10k spring rating coilovers? I have no idea which is better In terms of strength and performance.
Rafe
rmarchigiani is offline   Reply With Quote
Old 08-28-2013, 09:38 AM   #42
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
Default Perrin endlinks and other bad ideas
They look nice, which is far far better than my experience with them.
They said they fit my '02 - They do not
They said they would work with the vendor for a refund (Streetrays) - They did not
Streetrays said they would refund my $ - They did not
Streetrays then said they would give me store credit - They did not, then refused to talk to me and Perrin
6 mo and at least a dozen emails later Perrin offered to get me F-endlinks that I had to replace 6 mo ago to drive the car. I bought F&R.
Looks nice, but no chance that I'm going near either again.
Old 10-07-2013, 07:12 PM   #43
patsforlife
Member#: 368662
2008 Impreza
black
Not sure this is the right place to ask, but will an oem rear sway bar from a 2013 wrx fit an 08 2.5i?
patsforlife is offline   Reply With Quote
Old 10-22-2013, 04:25 PM   #44
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
Originally Posted by ajsti24 View Post
Correct!
What is OEM 08+ Sti?
The original post seems to read that they are the same 20mm rear.
but now I'm reading STi's may be 22mm rear?
Old 11-04-2013, 02:01 PM   #45
elmore055
Member#: 372754
2003 Impreza WRX
MBP(Midnight Black Pearl)
Awesome thread!
elmore055 is offline   Reply With Quote
Old 11-12-2013, 05:22 PM   #46
Mdsiman
Member#: 360019
2013 Wrx
Just got my eibach f/r sways with kartboy endlinks installed today!!! Wow what a difference!!!
Mdsiman is offline   Reply With Quote
Old 11-14-2013, 03:39 PM   #47
tdo911
Member#: 373618
Thanks for all the detail in this thread. Trying to decide on a rear sway bar and this helped narrow it down considerably.
tdo911 is offline   Reply With Quote
Old 12-07-2013, 07:52 PM   #48
J_Jay
Member#: 374618
So what's the stock size on a 2014? I can't find it using the limited search on the iphone app.
J_Jay is offline   Reply With Quote
Old 01-13-2014, 05:39 PM   #49
Grimnebulin
Member#: 187978
^Bump for all the amazing info. Thanks!
Grimnebulin is offline   Reply With Quote
Old 01-15-2014, 11:09 AM   #50
bsolony44
Member#: 282916
2006 WRX
Sent you a PM
bsolony44 is offline   Reply With Quote
