Old 11-05-2013, 12:44 PM   #1
neb_subi
Member#: 329049
04 sti
PSM (unfortunately)
Default Draining fuel
What is the best way to drain the fuel out.
A lot of people say to disconnect the return line and let it run out at idle.
However I have my motor out of the car and I'm guessing it will be awhile until I fire it back up.
There is about 3/4 of e85 I'm my tank...what a waste
neb_subi is offline   Reply With Quote
Old 11-05-2013, 08:57 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
there's a drain plug underneath on either side of the tank
Old 11-05-2013, 10:32 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Shoot the gas tank with a blunderbuss. There are 97 ways to do this, all equally the same level of pain in the ass.
Old 11-05-2013, 11:14 PM   #4
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Drain what you can and huff the rest out.
Hoon Goon is offline   Reply With Quote
Old 11-05-2013, 11:47 PM   #5
Dillinja666
Member#: 332644
07 STI
It's white
I'm actually all for seeing someone do this....lol
Dillinja666 is offline   Reply With Quote
Old 11-06-2013, 07:26 AM   #6
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Just extend the feed line into a gas can and jump power to the fuel pump
cowboy_Rob is offline   Reply With Quote
Old 11-06-2013, 08:30 AM   #7
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
You can just put Sta-Bil in the tank (yes it works with E85) if you're worried about it going "bad".
darkstarmoto is offline   Reply With Quote
Old 11-07-2013, 11:23 AM   #8
crazycraigsti
Member#: 359175
2010 Forester XT
I am in the same boat as you I have a full tank of gas but an empty engine bay. Jumping the fuel pump will only pump out one side of the tank, the returning fuel causes a siphon to draw from the other side of the tank. Now I am speaking of a 2010 forester, but I think the fuel systems are similar. If you are going to try to use the pump to drain the tank you will need to create a loop so that you can pump some fuel back into the return line. What I am doing is to pump what I can from the tank, connect a hose from the feed to the return, let the pump run for a while to level the two sumps out, then pump the fuel into a gas can and repeat. I know this is not the most efficient way to do this, but I didn't see any drains on the tank (I didn't really look too well).
Good luck
crazycraigsti is offline   Reply With Quote
