Old 10-14-2013, 01:40 PM   #1
Tonytheliger
Member#: 361940
Default Finding good Short Block?
Well i found out my 07 STi has rod knock... i need a new short block.
I am wondering if I should buy a new stock shortblock, or rebuild mine...
At the moment what I want most is reliability, i can do with the stock power.
but then again i dont want to tell myself "man i should have just bought a built motor while i was at it.
Also what is the difference in ej255 and ej257?
Let me know what i should do, I'd like to stay at around 2-2.5k (which a new stock SB is 1.7k online)
Thanks (:
Tonytheliger is offline   Reply With Quote
Old 10-14-2013, 02:08 PM   #2
ALOKIN
Member#: 348177
2013 WRX STI Limited
600whp IAG CD goodness
Stock block with drop ins? Ive seen a few shops offering them fror ~$2500
ALOKIN is offline   Reply With Quote
Old 10-14-2013, 02:23 PM   #3
cowboy_Rob
Member#: 194062
2003 Impreza WRX
This
Preferably find a vendor near you so you can avoid huge shipping fees
cowboy_Rob is offline   Reply With Quote
Old 10-14-2013, 02:39 PM   #4
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Also if you have any metalic particles in your oil make sure to replace the oil cooler and oil pump. A killerb pickup while you have it apart is cheap insurance too against your pickup breaking and going through all this again down the road
Old 10-14-2013, 03:01 PM   #5
Bullit62
Member#: 281311
2009 WRX
I just bought a new stock short-block (EJ255), master gasket kit and new head bolts from Flatirons Tuning (SB was $1800) and the shipping was only $80 to my semi-rural corner of Kalifornia...
And their customer service is the BEST I've ever seen from a parts supplier! They called me in the middle of their epic flooding (Boulder, CO) to make sure I was ok with everything...
Bullit62 is offline   Reply With Quote
Old 10-14-2013, 03:16 PM   #6
Bullit62
Member#: 281311
2009 WRX
And if you're doing the work yourself, don't forget the AVCS system (solenoids, pulleys, cams, etc...)
http://forums.nasioc.com/forums/show....php?t=2441411
Old 10-14-2013, 04:11 PM   #7
Tonytheliger
Member#: 361940
wow great thanks!
Old 10-14-2013, 04:12 PM   #8
Tonytheliger
Member#: 361940
Wait why? I do have metal flakes in the oil, but wouldnt just cleaning the oil cooler through remove these particles? the cooler cost like 250$ :P
Old 10-14-2013, 04:13 PM   #9
Tonytheliger
Member#: 361940
and do the flakes affect any other part of my engine, anything else i might need replaced
Old 10-14-2013, 04:14 PM   #10
Tonytheliger
Member#: 361940
I can have a friend help me but im kinda iffy. Im guessing having a shop do this will be expensive...
anybody know of a good shop here in Las Vegas
Old 10-14-2013, 04:20 PM   #11
Tonytheliger
Member#: 361940
nice shop, but i only see the ej257's and that was my question, whats the difference? They say "If you are putting this block in a car that it was not originally designed for, it carries no warranty expressed or implied." so i guess i would like the warranty.
Old 10-14-2013, 04:30 PM   #12
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Don't
Reuse
The
Oil cooler
Or sump
Or pump
Or pickup tube
Or we'll have another rod knock again wtf thread.
There is a huge thread on this subject.
SlimJim8804 is offline   Reply With Quote
Old 10-14-2013, 04:38 PM   #13
Tonytheliger
Member#: 361940
Originally Posted by SlimJim8804 View Post
Don't
Reuse
The
Oil cooler
Or sump
Or pump
Or pickup tube
alright i'll look for it,
Should i do those 10 minute oil cleaners before or after everything is done, to maybe get anything else out of there
Old 10-14-2013, 05:38 PM   #14
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Don't
Reuse
The
Oil cooler
Or sump
Or pump
Or pickup tube
Why not the sump? That's the easiest thing to clean when off the car and there are no "trap doors" or crevices for junk to hide in.
kellygnsd is online now   Reply With Quote
Old 10-14-2013, 05:40 PM   #15
Bullit62
Member#: 281311
2009 WRX
The EJ255 is specific to the WRX and the EJ257 is specific to the STi. The differences used to be more significant but Jon at Flatirons explained to me that the only difference in the new version factory short blocks are the pistons. The EJ257 blocks have a different piston installed.
And please don't skimp on the parts. I've found rod bearing "glitter" in every part of my motor including between the cam bearings and journals.
I know the oil cooler is expensive but there are dozens of threads where the owner opted not to replace the oil cooler and they were soon doing another rebuild.
I'm personally replacing my oil pump (new one is ACL/Orbit), pickup tube (new one is KillerB), oil baffle plate (new one is KillerB) and all three banjo bolts with mesh filters in the oil supply system since I can't ensure I'm getting everything out. My heads are disassembled and going out for professional cleaning with all the galley plugs removed and I'm disassembling my turbo and AVCS pulleys to inspect/clean them as well...
Good luck!
Old 10-14-2013, 05:49 PM   #16
Tonytheliger
Member#: 361940
Good luck!
Thanks for the help and for the brands too, very helpful! (: Would this be managable by me and a friend who knows more about cars than I do? :P
Old 10-14-2013, 06:04 PM   #17
Bullit62
Member#: 281311
2009 WRX
Please keep in mind those brands are upgrade replacements, not OEM.
How comfortable are you and your friend at doing open heart surgery?
If neither one of you have ever rebuilt an engine, I'd STRONGLY recommend finding a third friend who has experience. Otherwise, it can be a very expensive way to learn.
I don't do this for a living but it's been a hobby of mine for a loooong time. My grandfather was a mechanic his whole life and got me started somewhere around age 7 or 8 (40+ years ago)...
Old 10-14-2013, 06:07 PM   #18
Tonytheliger
Member#: 361940
yeah ill keep that in mind. maybe i can find someone here in vegas that can help me? if not i guess ill have to take it to a shop. Thank you!
Old 10-14-2013, 11:13 PM   #19
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
freddy121389 is offline   Reply With Quote
Old 10-15-2013, 08:54 PM   #20
Tonytheliger
Member#: 361940
alright i guess ima pull out the engine and have the shop just rebuild the engine or add the new shortblock.
Old 10-16-2013, 01:16 PM   #21
Bullit62
Member#: 281311
2009 WRX
Big cost difference... ;-)
Old 11-07-2013, 03:48 PM   #22
Tonytheliger
Member#: 361940
I'm about to do it this week but my dad said if I pull it out myself and something happens.. the mechanic will just blame me.. its like 1.1k to remove and install engine again. In total for everything I'm gettingbcharged almost 6k.... :/ its only a stock sb, and killer b pick up tube. what do you guys suggest?
