Old 11-05-2013, 03:25 AM   #1
HXC573
Member#: 268007
Ice Silver Metallic
Default Air Pump delete? How hard. 2012 WRX
Took the wagon up to Subaru today to get a broken wire fixed. I had posted many times saying that I could not get any scan tools to work on my car well that one wire they fixed was the problem, low and behold the reason being of the CEL was the air pump and the left and right valves. Now they said it would be a 2600 to 2700$ fix . But I found the delete plates for 50$ . What all will need to be done , how hard is it, will I have to get the car tuned once removed, and is there a thread on this already ?
HXC573 is offline   Reply With Quote
Old 11-05-2013, 03:39 AM   #2
Sonnyblk
Member#: 164505
06 WRX TR
Here is the other thread link http://forums.nasioc.com/forums/show....php?t=1209260. I had a local nasioc vendor take out the whole secondary air injection system it was pretty cheap and deleted the codes with a Cobb AP we dont have smog check or any inspection here in FL. Id check your waranty you have a 2012. If you do get the block off plates get KS ones with the gaskets for your year dont know if you have a bpm sensor like the 07. I think someone posted in that thread the stock part number for the subaru block off plates which were cheaper its a long thread.
Sonnyblk is offline   Reply With Quote
Old 11-05-2013, 07:28 AM   #3
GrumpyPitbull
Member#: 313311
Your warranty won't cover this repair?
Old 11-05-2013, 08:48 AM   #4
HXC573
Member#: 268007
Ice Silver Metallic
Voided warranty a long time ago .
Old 11-05-2013, 08:49 AM   #5
HXC573
Member#: 268007
Ice Silver Metallic
Alright thank you.
Old 11-05-2013, 08:51 AM   #6
JimmyBoyWRX
Member#: 371081
2013 WRX Limited
2006 WRX
Did would any of your mods have affected those parts?? If not get them to pay for it.
JimmyBoyWRX is offline   Reply With Quote
Old 11-05-2013, 08:55 AM   #7
superdonkey23
Member#: 350000
2013 WRX
Crystal Black Silica
You cannot "void" a warranty, the dealer has to prove that your aftermarket parts or tune caused the system to fail. Go back to the dealer and fight your case. 99% of the time with dealerships if you bitch enough you will get your way.
superdonkey23 is offline   Reply With Quote
Old 11-05-2013, 10:31 AM   #8
some dude
Member#: 100300
06 WRX
Yeah, use the warranty to fix that fo sho!
Old 11-05-2013, 10:53 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Did they tell you it was "voided" or are you simply assuming it is?
Truth.
Old 11-05-2013, 11:11 AM   #10
johnstc
Member#: 339777
2007 WRX
I've seen people get this covered under warranty due to the fact their evap emission control system wasn't modified or affected by modifications. I would definitely push to get it covered and not assume your warranty is voided if you haven't tried.
johnstc is offline   Reply With Quote
Old 11-05-2013, 12:34 PM   #11
Razgeiz
Member#: 358782
2013 STi
I got a blown motor replaced for free with a perrin inlet hose and grimmspeed aos installed. Its burden of proof that what you have done cause the failure. Otherwise they could say oh you used non OEM windshield wipers so your now failed transmission isnt covered.
Razgeiz is offline   Reply With Quote
Old 11-05-2013, 04:49 PM   #12
GrumpyPitbull
Member#: 313311
As several other members already stated, your warranty cannot be voided. They can only refuse certain warranty work if it is determined that a mod caused the failure.
That said, I cannot think of a mod that would cause a wire to never have worked from the factory or an air pump to fail on a pretty new car ... Unless your not telling the whole story behind this issue.
If you are telling the whole story, I would absolutely take your issue to SOA if your dealer won't cover it.
Old 11-05-2013, 06:12 PM   #13
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Not to thread jack but does any one know the part numbers for the oem air pump delete plates? I know that the one from the tribeca is the larger one p#14754AA050 will work for both sides if you drill the holes out on one of them but i have seen there was another oem plate that is a direct fit?
nate_fisher is offline   Reply With Quote
Old 11-05-2013, 06:44 PM   #14
mikill
Member#: 50506
2008 Forester XT
PhatRon tuned fun box
Driver 14754aa050
Passenger 1108aa020
mikill is offline   Reply With Quote
Old 11-05-2013, 06:59 PM   #15
nate_fisher
Member#: 270482
2011 turbotek fxt
Thank you!!
Old 11-06-2013, 05:33 PM   #16
HXC573
Member#: 268007
Ice Silver Metallic
So just go up there and tell them to fix it under warranty or just delete . The modifications done to the car prior were Cobb AP Stage 2 91 tune , Tomei Down pipe , Cobb SF intake and invidia cat back. Could any of those have caused the problem .
Old 11-06-2013, 05:34 PM   #17
HXC573
Member#: 268007
Ice Silver Metallic
And if not then should I have had to pay the 125$ for them to diagnos the problem .
Old 11-06-2013, 06:05 PM   #18
superdonkey23
Member#: 350000
2013 WRX
no you shouldn't have had to pay for anything. Tell them that your mods do not affect the secondary air pump at all. If they try to screw you over yet again threaten to take your issue to SOA. That will probably change their minds a little.
Old 11-06-2013, 06:07 PM   #19
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Most dealerships i have dealt with charge you for diagnosis and if fault is covered under warranty you get a refund.
Cathexis is offline   Reply With Quote
Old 11-06-2013, 07:29 PM   #20
HXC573
Member#: 268007
Ice Silver Metallic
Alright . The wire had been been my fault though , bumper had been getting painted and had no fender liners so a rock had ripped a wire .
Old 11-07-2013, 02:20 AM   #21
GrumpyPitbull
Member#: 313311
That's fine .. then forget the wire.
As for the air pump, since you have a catless DP, my guess is that the dealer is going to argue that you modified the emission control system so they won't cover it.
I guess it comes down to whether or not you want to go to war over this, or just say screw it and delete it. I think if you fought you would win in the end because the presence or lack of a catalytic converter does not effect the function of the air pump. The pump does not know or care if there is a catalytic converter there or not.
Whatever you decide, there is no way I would pay 2500 bucks to repair it if I were you.
Old 11-07-2013, 03:55 AM   #22
HXC573
Member#: 268007
Ice Silver Metallic
Well car is back to stock now but I'm missing little things so will that matter like say I think a inter cooler bracket and I think some bolts not to anything major
Old 11-07-2013, 11:31 AM   #23
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Returning it back to stock will not help get anything fixed fyi.
Old 11-07-2013, 04:00 PM   #24
GrumpyPitbull
Member#: 313311
Like Hinshaw said, going back to stock at this point will not help you. Since a dealership has seen your car modded already, it is probably flagged in the computer as modified.
Old 11-08-2013, 10:59 PM   #25
HXC573
Member#: 268007
Ice Silver Metallic
They have never seen it with any mods on it except for the axle back I built for it would that still matter
