Old 11-06-2013, 08:26 PM   #1
Doug12992
Member#: 372981
2008 outback sport
black/gray
Default 5w-20 mistake?
First off I want to say I'm new to this forum, secondly I've made a mistake when changing my oil this morning on my 08 outback sport. That being said when I cracked the pan open I happened to look at the jug of pennz ultra saying it was 5w-20 instead of 5w-30, I didn't have time to run to the store to get the correct oil because of work. So my question is will the car be okay or should I switch the fluid out asap?
Doug12992 is offline   Reply With Quote
Old 11-06-2013, 08:34 PM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Do you know what the numbers on oil do? You should read up on that.
http://forums.nasioc.com/forums/showthread.php?t=499177
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Your car should be fine for the time being. But it's cheap money to have the correct oil in your car. Cheap peace of mind, don't you think?
Also, fill in your profile so we know where you are. If you're located in Alaska, that answer is going to be different than if you were in Mexico.
Old 11-06-2013, 08:55 PM   #3
Doug12992
Member#: 372981
2008 outback sport
black/gray
I see.
Old 11-06-2013, 11:39 PM   #4
Doug12992
Member#: 372981
2008 outback sport
black/gray
Well I'm going to swap out the 5w-20. Is it okay to leave the oil filter on or should I replace that as well?
Old 11-06-2013, 11:52 PM   #5
subi400
Member#: 216984
1996 Impreza outback
Green
If it was an OEM blue filter, then you can leave it
Old 11-06-2013, 11:52 PM   #6
Doug12992
Member#: 372981
2008 outback sport
black/gray
Lol nope it was not. It's only got 2 miles on it.
Old 11-06-2013, 11:56 PM   #7
C4RBON_F1BER
Member#: 208507
'15 BRZ
Keep the current filter on there. Don't waste your money on a new one.
C4RBON_F1BER is offline   Reply With Quote
Old 11-06-2013, 11:58 PM   #8
subi400
Member#: 216984
Green
Next time, get an OEM blue filter
Old 11-07-2013, 12:19 AM   #9
Doug12992
Member#: 372981
2008 outback sport
black/gray
Anything special about the oem filter? I've always been Purolator guy.
Old 11-07-2013, 12:21 AM   #10
subi400
Member#: 216984
Green
What is the part # of the Purelator PureOne filter you use?
The OEM filter has the proper 23 psi bypass spec which is specific to a subaru engine.
Old 11-07-2013, 12:53 AM   #11
Doug12992
Member#: 372981
2008 outback sport
black/gray
I'm not home right now to look at the box due to work but I could have recalled that earlier this year didn't subaru have a recall on those blue filters?
Old 11-07-2013, 04:31 AM   #12
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
You're worrying waaaaaay too much. You'll be fine.
i_c_the_light is offline   Reply With Quote
Old 11-07-2013, 11:14 AM   #13
Giamilton
Member#: 8002
2013 WRX 5dr/Abarth
WR Blue/Nero
IBUS
In Before Uncle Scotty.....
Giamilton is offline   Reply With Quote
Old 11-07-2013, 11:34 AM   #14
Paidfor
Member#: 267815
Be in awe
dont hate .)
Surely he has something better to do than school some newb on proper oil viscosity and lubrication requirements..............o wait you said Uncle Scotty..........nevermind.....he will most likely chime in lol
Old 11-07-2013, 02:53 PM   #15
bluesubie
Member#: 767
04 FXT
This.
There are hundreds (if not thousands) of stock and modified WRX's driving around with 5W-30 that has sheared to a 20 grade anyway. Since you're n/a it's probably fine. Just keep an eye on the oil level and top up with 5W-30 if it gets low.
-Dennis
Old 11-07-2013, 10:40 PM   #16
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Has he hurt your feelings?
Old 11-11-2013, 05:26 PM   #17
Paidfor
Member#: 267815
Be in awe
dont hate .)
No hes a Douche...........havent you seen some of his posts?
Old 11-11-2013, 06:02 PM   #18
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Stick around here for a few more years and reply to the countless repetitive threads here and in General. I imagine you'll end up "douchey" as well.
Gallo2011 is offline   Reply With Quote
Old 11-12-2013, 08:01 PM   #19
Daniel wrxTR
Member#: 300014
2007 wrx
Or you can just ignore the thread.
All I can do is think of OT when uncle scotty gets brought up. d00d!
Daniel wrxTR is offline   Reply With Quote
