Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 11-08-2013, 04:52 PM   #1
Member#: 354703
Default 02 WRX, CEL after removing rear O2 sensor, problems?
So I have an 02 WRX, and it now has catless up and down pipes. When I changed the down pipe, I did not put the O2 sensor back in. I do have a CEL, which is no huge surprise, and the car is running fine, if just a little rich. Still getting around 18-22 mpg, which isn't any different from before. From what I understand, this is is okay and the rear O2 is just for emissions / fuel efficiency, but I just wanted to make sure. Is it okay to run without the rear O2 sensor and just ignore that CEL? Or will I cause problems by leaving that out? Should I bother with the mechanical fix, or just wait until I get a tune in a month or two?
zaphodb2002 is offline   Reply With Quote
Old 11-08-2013, 10:40 PM   #2
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Why the hell would you not reinstall the damn thing?
Can you do without it? Yes, but only for the 02/03 models. Does that mean you should? No. Will a basic tune get rid of your issue? Yes.
Next time, do some damn research man.
