Old 11-08-2013, 03:17 AM   #26
nfm
Member#: 171697
05 WRX
The noise could be coming from front diff, this is how things sounded when I had bad transfer case bearings:
nfm is offline   Reply With Quote
Old 11-08-2013, 06:11 AM   #27
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Originally Posted by Subbie n00b View Post
Yeah, I wouldn't be posting this if I knew the problem lol. It's defiantly not the tranny but the mechanic at Subaru said either loose cat (my downpipe is not aftermarket, only exhaust is after market) or a shaft play on my turbo sounds really lucid at this point >.<
I can assure you that mechanic is clueless to what's causing that noise if he thinks those 2 things could be causing that noise.
booSTin-scoobs is offline   Reply With Quote
Old 11-08-2013, 07:07 AM   #28
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
also does it make the noise if your parked and in neutral or only while driving?
Old 11-08-2013, 10:33 AM   #29
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that's tranny rattle noise.
perfectly normal, and due to gear lash.
Old 11-08-2013, 10:41 AM   #30
beermuscles
Member#: 370850
2014 STi
ISM
adding aftermarket exhaust without changing the downpipe could effect the fitment and create rattling, especially as air escapes through the exhaust. but i'm a newb.
beermuscles is offline   Reply With Quote
Old 11-08-2013, 10:59 AM   #31
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Originally Posted by ride5000 View Post
that's tranny rattle noise. perfectly normal, and due to gear lash.
if that's the tranny rattling then he should hear it when revving in neutral. Or at least hear something
Old 11-08-2013, 12:37 PM   #32
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ummm.
you are misunderstanding the rattle.
the engine must be compression braking in order for the gear lash to chatter.
it's EXACTLY the same as "lightweight flywheel decel" noise, just a little less loud.
Old 11-08-2013, 01:34 PM   #33
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
ummm. you are misunderstanding the rattle. the engine must be compression braking in order for the gear lash to chatter. it's EXACTLY the same as "lightweight flywheel decel" noise, just a little less loud.
okay so you say it's "tranny rattle noise" but what is tranny rattle noise, you say it's normal but my car/tranny doesn't make that sound. I'm just trying to understand what your saying it is bc I have never heard that before and I really doubt it's normal
Old 11-08-2013, 03:04 PM   #34
AspenScoob255
Member#: 217405
2006 WRX
^^^^I think he is referring to gear "whine"
Check your up pipe heat shield, seriously, mine made the same noise and i pulled my hair out for 2 weeks trying to find the cause. Turns out the spot welds failed and allowed the heat shield to move around when engine braking.
AspenScoob255 is offline   Reply With Quote
Old 11-08-2013, 07:36 PM   #35
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Originally Posted by AspenScoob255 View Post
^^^^I think he is referring to gear "whine" Check your up pipe heat shield, seriously, mine made the same noise and i pulled my hair out for 2 weeks trying to find the cause. Turns out the spot welds failed and allowed the heat shield to move around when engine braking.
that is not gear whine. If it is then that gear box is about to explode bc that would be the loudest gear whine I ever heard lol
Old 11-08-2013, 10:24 PM   #36
DansSpace
Member#: 157029
'13 Mazdaspeed3
ummm.
My LGT came from the factory with a dual mass flywheel. I switched to a lightweight single mass flywheel from a wrx. My car on decel sounded exactly like the car in the video, but a bit louder.
A bit of crunchy noise, a bit of kurkurkur mixed together.
DansSpace is offline   Reply With Quote
Old 11-08-2013, 10:47 PM   #37
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
Originally Posted by DansSpace View Post
My LGT came from the factory with a dual mass flywheel. I switched to a lightweight single mass flywheel from a wrx. My car on decel sounded exactly like the car in the video, but a bit louder. A bit of crunchy noise, a bit of kurkurkur mixed together.
so then maybe he needs to have his flywheel machined and some new bearings. Maybe that will help
Old 11-08-2013, 11:03 PM   #38
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
ive never experienced tranny noises like that in any of my subarus. If my tranny ever sounded like that I would replace it. That's just me
Old 11-09-2013, 03:24 AM   #39
Subbie n00b
Member#: 324558
2004 Impreza WRX
So.... did anyone come with a general consensus of what the hell is up with my car? Im located at Winter Park FL if there are kind souls near there willing to take a look. only 20 so cant buy beer :P
I can share my other talents in other fields lol
Subbie n00b is offline   Reply With Quote
Old 11-09-2013, 06:59 AM   #40
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
So.... did anyone come with a general consensus of what the hell is up with my car? Im located at Winter Park FL if there are kind souls near there willing to take a look. only 20 so cant buy beer :P I can share my other talents in other fields lol
if I were you I would find a reputable shop that is good with subaru's, or even better one that specializes with subaru's. Take it to them and see what they say. That's what I would do
Old 11-09-2013, 07:52 AM   #41
Subbie n00b
Member#: 324558
2004 Impreza WRX
I took it to the shop already and they told me its either shaft play or loose cat. just wondered if anyone here encountered something like that. I don't want to pay like $200 for them just to take my downpipe out and see if there's shaftplay
Old 11-09-2013, 08:12 AM   #42
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
The only way to "fix" it is to put on a heavier flywheel.
As fhi did between my02 and my03 wrxs...
but if you insist on parting with your money on a witch hunt, I'm certain the shop will be more than happy to take it.
Old 11-09-2013, 08:13 AM   #43
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
(btw the shop that says it's shaft play don't know wtf they're doing)
Old 11-09-2013, 08:43 AM   #44
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
you didn't take it to a shop you took it to a dealership. That tried telling you the noise is shaft play in the turbo...dude if your turbo was making all that noise it wouldn't make it 15ft down the road. Just bc the dealership told you something doesn't mean they have the slightest clue what they're talking about or have any idea on modifications of subarus and building and all that. I'm saying to take it to a real shop that builds these cars, they should be able to help you.
Old 11-09-2013, 08:44 AM   #45
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
or do what ride is saying and replace the flywheel. I wouldn't pay the people that told you it's shaft play to replace your flywheel though
Old 11-09-2013, 08:49 AM   #46
cream1316
Member#: 332279
2012 wrx hatch
dark grey metallic
Sounds like the normal sound of gears inside the tranny. Do a trans and diff flush first cheapest way to find out and plus looks like your overdue for one since you havent changed it.make sure you put the correct amount of fluid. GL
cream1316 is offline   Reply With Quote
Old 11-09-2013, 09:43 AM   #47
booSTin-scoobs
Member#: 340148
2004 wrx - 18g
305whp - 282wtq
your like the second or third person to say it sounds normal. Does your tranny sound like that?
Old 11-09-2013, 10:03 AM   #48
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i do not believe there is a bolt on heavier flywheel option available.
the comment was tongue in cheek.
my car is about 4x louder due to the act streetlite i put on when i changed my clutc h the first time, ~7 years ago. 02s and some early 03s had light(er) weight flys right out of the factory. when fhi got complaints, they issued a TSB which replaced the flys in those cars with a heavier one (along with a couple of other associated changes like TOB, etc).
a flud change can dampen the sound somewhat. as i said, the issue is due to the great number of gears and diffs inside the tranny, each mesh point having a tiny amount of lash or play. the issue only occurs on decel, in gear, with clutch out, and is most noticable when engine braking is strongest (ie lower gears).
but hey, i've only been here over a decade with ~100k miles on my car, so take it fwiw.
Old 11-09-2013, 03:57 PM   #49
cream1316
Member#: 332279
2012 wrx hatch
dark grey metallic
Yea it does and i have a 2012 . The exact way he is doing it i do it too and i hear it i mean i dont know if his is louder bcz im not physically there but im sure if i stick my phone down near the footwell tranny area i would here the same thing. . To me if his car is running good and his tranny works normal the car is fine.
Old 11-09-2013, 04:00 PM   #50
cream1316
Member#: 332279
2012 wrx hatch
dark grey metallic
Change you fluid for a start kid its the cheapest way . Plus your overdue anyway. Observe the fluid for chips and fillings from the gears. As ride5000 said
