Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 11-03-2013, 06:52 PM   #26
lukeslick
Member#: 314564
SRP
im looking at replaceing the boost control solenoid what one should i go with?
should i go with after market? or stick with a new oem one?
lukeslick is offline   Reply With Quote
Old 11-05-2013, 04:03 PM   #27
lukeslick
Member#: 314564
SRP
Any way to check to see if it's broke before I go out and buy one
Old 11-07-2013, 04:31 PM   #28
lukeslick
Member#: 314564
SRP
any help would be awesome and thank you for everyone that has helped
Old 11-07-2013, 05:46 PM   #29
hudsonvalleybugeye
Member#: 295068
2001 forester
there is, but you need a way to closely monitor your boost.
you would take the hose off of your wastegate actuator (coming from your actuator) and go for a drive while watching your boost like a hawk, stay out of boost. find a place where you can get into boost, while still watching your boost like a hawk, see if you can make more than 8lbs, dont go past 12-13lbs. If you can make more than 8lbs, its your actuator. a stock actuator is plug and play, an aftermarket unit like grimmspeed's requires a custom tune. you decide.
Good luck and please do not do this without a way to monitor your boost.
hudsonvalleybugeye is offline   Reply With Quote
Old 11-07-2013, 06:00 PM   #30
the suicidal eggroll
Member#: 51961
2005 STi
Not necessarily, he could have a low DAM and the ECU has disabled boost control to protect the engine.
Old 11-07-2013, 07:41 PM   #31
hudsonvalleybugeye
Member#: 295068
2001 forester
Wouldn't this result in a check engine light? Knock correction/learning etc. even if there was a bad knock sensor, it would throw a cel and put you into limp mode (making about 8 lbs of boost and smelling like gasoline) O.p. do you have any check engine lights?
Old 11-07-2013, 08:02 PM   #32
Member#: 51961
2005 STi
No, low DAM doesn't throw any CELs or put the car in limp mode, it just disables boost control.
CELs are generally reserved for problems that affect emissions, lack of a CEL doesn't mean the car is running correctly, it doesn't even mean that the car thinks it's running correctly.
Old 11-07-2013, 08:41 PM   #33
mephistomarius
Member#: 330895
2002 Impreza wrx
blaze yellow
Stick with the stock ebcs for now, u can get a working used one really cheap. Get the car smoke tested, I had lots of dry rotted vaccum lines and some fuel return issues when my car had the same problem with boost
mephistomarius is offline   Reply With Quote
Old 11-07-2013, 09:48 PM   #34
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
check your Bpv make sure that its not sticking in any way, check for rotted vac lines..
check for that bleeder nipple the guys posted previously ..
check your up pipe make sure it does not have a crack or hole, check inter cooler piping review anything that has been recently replaced within the last few thousand miles.
very hard to troubleshoot my friend via internet :-s could be a bad injector rubber o ring allowing air into the intake manifold..
white guys wrx is online now   Reply With Quote
Old 11-08-2013, 09:45 AM   #35
nmlittlebigman
Member#: 321409
2015 WRX LTD
Personally I would use the tactrix cable to pull a Learningview and check your DAM and your fuel trims and then proceed from there. Like Eggroll said a reduced DAM will disable boost. That would be the first thing that I would do BEFORE buying anything else.
Old 11-08-2013, 10:12 AM   #36
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
to check the solenoid, you will need a way to blow through it and a way to actuate it electrically.
no power = air is blocked
power applied through coil = should feel a click, and air passes through
the coil is not polarized, meaning you can connect either side to + to actuate. the solenoid runs off battery voltage (not 5v).
Old 11-08-2013, 12:37 PM   #37
lukeslick
Member#: 314564
SRP
I have a cobb accessport so i will be able to watch my boost and i can data log any information that would help find the source.
Old 11-09-2013, 12:38 AM   #38
GJPP
Member#: 369340
2002 Impreza WRX Wag
SRP
let us know what kind of numbers your putting up after the Cobb AP install
GJPP is offline   Reply With Quote
Old 11-09-2013, 02:44 AM   #39
Th3_On3_Wrx
Member#: 343144
2013 STI
Crystal Black Silica
8psi is stock wastegate ... so worth out a time you are going to hit 8psi. With the mods you have now. Hey a tune asap
Th3_On3_Wrx is offline   Reply With Quote
Old 11-09-2013, 08:56 AM   #40
lukeslick
Member#: 314564
SRP
What stuff should I data log. So I could make a table
Old 11-10-2013, 03:45 PM   #41
lukeslick
Member#: 314564
SRP
I put stage 2 on my car through the accessport, I have no check engine likes on at all. The dam I am getting is 16.
Old 11-11-2013, 09:35 AM   #42
lukeslick
Member#: 314564
SRP
the cobb is reading a target boost of 14.6psi while i have a boost rating of 6.8psi
Old 11-11-2013, 09:57 AM   #43
hudsonvalleybugeye
Member#: 295068
2001 forester
Isn't the cobb ots map for stage 2 at 16lbs of boost? anyway like stated before, My knowledge of tuning and dam is limited, but after a little research, its seems that a dam of 16 is normal for your setup. take this for what its worth, but I'm still pointing at your solenoid.
Old 11-11-2013, 11:02 AM   #44
Member#: 51961
2005 STi
16 is normal for DAM on the 16-bit ECUs (02-05 WRX), so it's not the ECU cutting boost due to knock. As long as your WGDC logs normal, then the solenoid looks like a good place to check next.
Old 11-11-2013, 11:10 AM   #45
lukeslick
Member#: 314564
SRP
yeah im thinking of buying a solenoid seems to be what must of you guys are sayin. if any more data numbers could help i could get you readings on them
Old 11-11-2013, 11:20 AM   #46
hudsonvalleybugeye
Member#: 295068
2001 forester
do you have any close friends with wrx's? you could see if anyone close has a suitable solenoid and willing to come over and let you swap it out to see if it fixes your problem.
Make sure all of the contacts in the solenoid plug are clean as well.
Old 11-11-2013, 11:24 AM   #47
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
get your hands slightly dirty and do this already ^^^
Old 11-11-2013, 12:26 PM   #48
lukeslick
Member#: 314564
SRP
How could i actuate it electriacally?
Old 11-12-2013, 06:15 AM   #49
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
take 2 pieces of wire. attach one end of one piece to battery +, one end of the other piece to battery -. Then put the two loose ends across the coil connections of your solenoid. You should hear and feel it click. additionally you should be able to blow through it while actuated.
Old 11-12-2013, 03:34 PM   #50
lukeslick
Member#: 314564
SRP
i toke a data log but i dont know how to post it on here. and one know how to do that its in a excel file right now but i could covert it to anything that is needed.
