Old 10-25-2013, 12:26 AM   #226
skeates
Member#: 301674
Great work! No you've just got to keep the momentum going. That is a fantastic powerplant for the 912 BTW.
skeates is offline   Reply With Quote
Old 10-25-2013, 12:06 PM   #227
CptTripps
Member#: 371033
I've been watching this one on 914world.com too. Great looking build man.
CptTripps is offline   Reply With Quote
Old 10-25-2013, 01:03 PM   #228
RonW
Member#: 103663
1968 Porsche 912
STi v8 Spec-C conversion
Ya, I've taped into all the individual communities to get advise where I can, nasioc for the obvious suby motor swap info, 914world for breadth of experience w suby into Porsches and then the shoptalkforum for the swaps onto bugs w the reverse ring pinion for the trans along w swaps into similar orientated cars. All have been quite helpful and no way this swap would have happened wo everyone's input!!!
RonW is offline   Reply With Quote
Old 11-12-2013, 12:03 AM   #229
robeod7
Member#: 373420
Great build! Here's a pic of my swap. No turbo, just trying to make a cool daily driver, 1969 912.
robeod7 is offline   Reply With Quote
Old 11-12-2013, 11:13 AM   #230
RonW
Member#: 103663
1968 Porsche 912
Rob,
Nice build, looks great in the pic. Is it on the road now? you should start a build thread so we can see some of your details
BTW for any lurkers planning on this swap with a 901:
FOR SALE
Outfront Motorsports Adapter plate
Kennedy Engineering Adapter Flywheel
Sachs Stage 2 Pressure Plate and Clutch
necessary bolt hardware for flywheel and pp and pilot bearing
<1000 miles on the parts and in very good condition.
new parts are $1200 - asking $900 plus shipping and any paypal fees. gladly meet you if driving distance is not crazy.
Old 11-15-2013, 07:42 PM   #231
RonW
Member#: 103663
1968 Porsche 912
Received an order of OEM hardware to bolt the flywheel and pressure plate and clutch disc alignment tool as well as proper bolts for the transaxle to motor. Bolted everything together and slide everything back in place. Needed to trim here and there around the stock suby starter and for the stock suby clutch slave. Looks like she was born there. Made a little adapter to connect the Subaru shift rod to the Wevo shift coupler so I can use the Porsche shift rod (will likely need to be shortened slightly though). I’ll start on the pedestool for shift tower soon. Started in next project…new pedal cluster for hydraulic clutch and improved braking biasing. Need to make a run to get some material and start fabricating!
Old 11-16-2013, 12:44 AM   #232
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Looks great!
RSti_Spyder is offline   Reply With Quote
Old 11-17-2013, 01:53 PM   #233
RonW
Member#: 103663
1968 Porsche 912
Originally Posted by RSti_Spyder View Post
Looks great!
still plugging away
Had to address the fact that I needed to shifter housing had to be elevated so got some material and fab a pedestool up. welds arent professional but getting more and more comfortable with tigging aluminum.
mounted the Tilton pedal cluster to some aluminum and mounted that in place without much issue. i'll make short flexible hydraulic line to go from the each brake mc to the stock hard line and one long flexible hydraulic line to make the run to the rear for the stock clutch slave. I did mount the seat for a test fit and wow the positioning feels great!
Old 11-17-2013, 08:12 PM   #234
RonW
Member#: 103663
1968 Porsche 912
quick mod to the shift rod due to it being about 1.5cm too long and needed to angle mid rod so it would enter the shifter at a flat angle so avoid binding. time to order 930 CV's and take measurements to determine axle length for Sway away to make custom units.
Old 11-17-2013, 10:44 PM   #235
HougieBear
Member#: 347748
2003 Impreza WRX
Midnight Black Pearl
What is the shift pattern going to be like since the transmission is nowflipped around?
HougieBear is offline   Reply With Quote
Old 11-17-2013, 10:52 PM   #236
B-85
Member#: 60628
1994 Sti.94,Sold 96.
Nice Build!
Working on a 1962 VW Bug with a plan to go Subaru. Have a JDM 220 /2.0. Having been their,what would be a good VW trans? Some how I don't think the 36HP trans is up to the power?
thanks and keep up the good work !
B-85 is offline   Reply With Quote
Old 11-17-2013, 10:54 PM   #237
B-85
Member#: 60628
Old 11-17-2013, 11:14 PM   #238
RonW
Member#: 103663
1968 Porsche 912
the pivot of the shifter reverses it again to normal shift pattern in its normal orientation. this incidentally is the same as a 915 shift pattern.
B-85, thanks. if you are going to put a suby in, id highly recommend just going with a suby 5 speed with a reverse ring pinion as well if the budget allows. no adapters needed to connect motor/trans. even motor and tranny mounts out there too. on a side note, i have a Subamount that is designed for subaru to vw mount that i was going to try to modify but opted not to so if you are interested in it, i paid $150 in a group buy and its yours for the same +shipping. look forward to seeing your build at some point as well.
cheers,
ron
Old 04-19-2014, 10:57 AM   #239
RonW
Member#: 103663
1968 Porsche 912
been a while lurking and wrenching until i had anything to really substantial to post
-rented a brake flare tool from FedHillUSA and enough lines and fitting to essentially redo all the brakes lines. got the Cunifer stuff which is so easy to work with.
-got a set of VB911R rear calipers and Porterfields all around from Eric at PMBperformance, things are sweet.
-designed a VSS trigger wheel since 2011 trans stopped using the internal one to the tranny of course...
-had Mario and thedubshop.net laser cut it for me and then tig it to the boot flange
-lubed and bolted the 930 CVs and Sway away axles up
-fund a early '66 single master reservior and ran 7mm hose to the masters
-filled the trans with Motul 300 75-90wt
-bleed the system and since wife and kids were out of town, no one around for a leg work out to pump for me so i got a Motive and love that thing.
-burped the coolant system, pita
-turn the key and she started up after her winter slumber To my delight, clutch engaged, went into gear and pulled right out. but after a few feet i heard a POP and i stopped, pulled forward and POP again, i thought $HIT i broke a cv! what happened was some bubble wrap that the calipers were shipped in were under the car when i was pulling out
anyway, slow short jaunts around the hood and everything seems to be fine. gonna have to get use the the shift pattern now lol the trans shifts oh so buttery smooth!!! just a nudge and click, click, click.
at this point, the only thing i'll need to redo is the brake masters. they are too big of a bore and the pedal is just too heavy and almost no stroke. im currently running 13/16" and i think i'll drop it down to 7/10" and that will give me better pedal feel i think with the 48mm piston SC calipers fronts and 38mm piston caliper VB911R rears.
Old 04-23-2014, 12:04 PM   #240
Mitcheg33
Member#: 388719
looking great man
you may have mentioned this but is there any reason you decided to go with the wevo link instead of a cable shifted setup?
I have a 914 that's getting an eg33 right now so I am curious.
cable shift setup is a daunting task for someone new to fab
thanks
mitch
Mitcheg33 is offline   Reply With Quote
Old 04-23-2014, 01:58 PM   #241
RonW
Member#: 103663
1968 Porsche 912
mitch,
thanks, im glad to be wrapping this up. need to do an alignment and corner balance (buddies and i bought scales/hub stands/camber-caster gauge/strings) in the next few weeks so that is next on the list.
i HAD to go with this approach because there is no room for cable shift. you will HAVE to go cable shift in the 914 if you go with the suby trans. you have to fab nothing. check out Ian at coldwater914.com he as developed a cable shift brackets/hardward for drop in install. he has conversion axles and engine/trans cradles that use the stock pick up points. its a now brainer.
best of luck
ron
Old 08-09-2014, 12:03 PM   #242
FoxtrotVIII
Member#: 398575
Which Conversion Plate setup did you use when you initially had your EJ20T married to your 901/2? Im looking to do the same, but having trouble finding the right one. Im not exactly sold on the Subaru transmission, and im thinking the conversion to my Porsche transmission is a more cost effective way then all the conversion it would take to spin the Subaru transmission the right way.
Ive been following your thread for sometime and it has inspired me to retire the Air cooled, it has earned some shelf time. Im in the process of getting my hands on an early 2000's EJ20TT, non STI. I have no intentions to race it, just looking to make a nice daily driver.
Ill have to start my own thread once i begin the whole process.
Here's a picture while she is still on the road.
FoxtrotVIII is offline   Reply With Quote
Old 08-10-2014, 01:55 AM   #243
RonW
Member#: 103663
1968 Porsche 912
Looks like shes got 'great bones'. I was running the outfront adapter plate and the kennedy stage 2 conversion flywheel/clutch/sachs pressure plate. running the 901/2 is fine but you will need to run taller gears for the EJ for freeway cruising. At a MINIMUM, 3/4/5th from a 914 trans. That 5th is a ZD gear seat, the tallest made for the 901/915. BUT... you can take a lower gear seat (I've read on the 914 sites who run chevy motors) and then swap their position so you get an effect taller gear than the ZD. This was something I had contemplated if I were to have kept the 901. It still left 1st gear vulnerable. I think the best set up if not going with a suby trans (and its expense, esp in a SWB car) is to put in a 915 trans geared appropriately.
good luck, I havent post much lately because I'm simply enjoying her.
Old 01-06-2015, 03:39 PM   #244
Corbic
Member#: 85201
Awesome build.
Sent from my iPhone using this horrific ad filled Tapatalk knock-off app.
Corbic is offline   Reply With Quote
Old 01-06-2015, 04:58 PM   #245
RonW
Member#: 103663
1968 Porsche 912
[quote=Corbic;42946915]Awesome build./QUOTE]
Thanks Corbic. everything been running fine so not much to report back .
Old 01-06-2015, 06:00 PM   #246
Corbic
Member#: 85201
Default '68 Porsche 912 converstion - 2005 STi EJ20T
Originally Posted by RonW View Post
Originally Posted by Corbic View Post
Awesome build.
I came across it as I'm researching options to fix this unfortunate incident.
Total loss basically.
Old 01-06-2015, 06:58 PM   #247
RonW
Member#: 103663
1968 Porsche 912
oh man that sucks!!!. is that a SC with a G50? do some research on here, jcaz put a ez30 in an SC and it scooted! that was a great build.
Old 01-06-2015, 07:24 PM   #248
Corbic
Member#: 85201
'85 3.2 with a 915.
I read that whole thread on Pelican as well. In thinking about a EZ30.
Old 01-25-2015, 02:28 AM   #249
RX-78 Gundam
Member#: 378812
This is an awesome build. I hope to one day do something like this with a 914!
RX-78 Gundam is offline   Reply With Quote
Old 02-23-2015, 10:51 AM   #250
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
Badass build!
Just one thing that's bothering the hell out of me:
Used to.
Supposed to.
not
Use to
Suppose to.
SubasaurusWrex is offline   Reply With Quote
- 2005 STi - 352whp / 400 wtq - 18G on Meth - worksti Proven Power Bragging 68 06-04-2010 12:28 AM
FS:CT - 2005 sti doors, interior, 2005 wrx seats Ctracer911 Complete Car Part-Out 16 06-20-2009 07:42 PM
NJ - 2005 STI - Metalic gray, HKS exhaust, Not abused or raced, MINT - $20500 rustyvegas Private Vehicle 'For Sale' Classifieds 17 09-24-2008 11:15 AM
FS - 2005 STi - White/Gold - SLC ibis RMIC Private Classifieds 5 04-13-2006 12:39 PM
FS - 2005 STi - gauging interest UncleMeat Mid West Subaru Owners Club Forum -- MWSOC 12 09-04-2005 12:52 PM
