Alaskan Impreza Club
Go Back   NASIOC > NASIOC Chapters > Alaskan Impreza Club Forum -- AKIC
Old 11-09-2013, 03:15 PM   #1
Kg-lo
Member#: 366660
2007 STI
Default Oil feed line
I purchased a steel braided Bosch oil feed line from rsd. I got it installed last night. And now I have oil dripping from the lower banjo screw. I have did some research and seen that some people have had washer problems. I have both washers on top and bottom going to go get some new ones see if it helps. (Old ones weren't beat)
Wondering if anyone has any tips on how to get the oil from stop leaking or had this problem.
Kg-lo is offline   Reply With Quote
Old 11-09-2013, 03:18 PM   #2
Kg-lo
Member#: 366660
2007 STI
Thanks for the help btw!!
Old 11-09-2013, 03:25 PM   #3
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
You probably should have put new ones on anyway. They do get crimped when you tighten them down. RE-using the same ones results in what you have doing on. You should probably use some sort of copper washer I would think. Also, look up the torque specs and follow them to a "T" with new OEM washers.
Just my 2 cents. We have some pro mechanics in here, who may have other thoughts.
Nomadgene is offline   Reply With Quote
Old 11-09-2013, 03:32 PM   #4
Kg-lo
Member#: 366660
2007 STI
Alright I will thanks for the help. I will go head out get some washers.
Old 11-09-2013, 03:45 PM   #5
Nomadgene
Member#: 22923
You do have a torque wrench…right?
Old 11-09-2013, 05:30 PM   #6
Kg-lo
Member#: 366660
2007 STI
Yeah I have one
Old 11-12-2013, 03:31 PM   #7
Snowy
Member#: 50945
Every tech manual says to always replace crush washers with new, even the oil drain plugs copper washer should be replaced with new every oil change. Continental has the ones you need in stock. I think their about $2.50 a peice.
Snowy is offline   Reply With Quote
Old 11-13-2013, 02:03 AM   #8
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Did you end up installing the new washers... is it still leaking or did it fix the problem?
Racer Dubya is offline   Reply With Quote
Old 11-13-2013, 03:26 AM   #9
Kg-lo
Member#: 366660
2007 STI
Yeah put in new washers. Leak stopped but still see slight smoke from the same area and smell burning smell. Been doing some searching on it and going to check if my cv boot is torn.
Old 11-13-2013, 03:32 AM   #10
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
How long has it been smoking, depending on how much you've been driving in these temps it could take a bit to burn off.
