Old 10-22-2013, 12:59 PM   #276
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by Commander Keen View Post
I've put about 15,000 miles on several PL14459s and about 5,000 on an M1-104. The PSL14459 has the same specs and filters almost as well as the PL filter, but both should do a great job.
These filters have a greater diameter and more can volume than the TR filter. If someone opens up a spent TR, we could compare the media area.
You think the PL filter is better than the PSL? The PSL is the synthetic filter, and costs twice as much as the PL. Shouldn't the PSL be the better filter?
Old 10-22-2013, 01:11 PM   #277
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I don't know about cost, but the PL removes smaller particles from the oil than the PSL. If it's also cheaper, then it's a win-win. Check the efficiency specs on Purolator's site.
The PL is easy to find at most auto parts stores, but it never seems to make it to competitors' bar graphs for some reason.
Old 10-22-2013, 01:19 PM   #278
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I just wish it was listed as a compatible filter for our Imprezas.
Old 10-23-2013, 08:31 AM   #279
Crash00527
Member#: 367123
2013 Impreza Premium
Marine Blue Pearl
Anyone figure out the fram ultra equivelent to m1-104?
Crash00527 is offline   Reply With Quote
Old 10-23-2013, 10:16 AM   #280
CLL_OBP
Member#: 310435
'12 Sp Limited
M1 EP 0W20 104,640 miles
On my iPhone so hopefully this shows. These are the Fram XG filters that are 20mm x 1.5. The M1-104 is 3.14" O.D. and 3.08" tall. The closest Fram Ultra equivalent would be the XG9688 or XG3593A. The ones highlighted in green will fit. Any filter wider than 3 1/4" O.D. will not.
CLL_OBP is online now   Reply With Quote
Old 10-23-2013, 10:31 AM   #281
Crash00527
Member#: 367123
Marine Blue Pearl
Thank You. Very much appreciated. Good job
Old 10-23-2013, 11:25 AM   #282
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Cant find any M1-401 prices.
Old 10-23-2013, 11:27 AM   #283
Crash00527
Member#: 367123
Marine Blue Pearl
Ok..do just get m1-104 instead. Still bigger than stock.
Old 10-23-2013, 11:31 AM   #284
myrt1987
Member#: 323103
2012 Limited 2.0i
Idk, prices still hard to find for m1-104. Only prices I can find are expensive.
Old 10-23-2013, 11:55 AM   #285
Commander Keen
Member#: 319157
It looks like the M1-401 might be discontinued.
Old 10-23-2013, 05:42 PM   #286
shredjesse
Member#: 369265
2013 Impreza 2.0L
Pearl White
I've been going with Napa gold filters. Curious if anyone knows if it's all that wise of a choice to go with these. I found a screaming deal so i bought 4 oil changes worth of supplies all at once.
shredjesse is offline   Reply With Quote
Old 10-23-2013, 06:05 PM   #287
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Made by wix...can't go wrong.
jsteg is offline   Reply With Quote
Old 10-23-2013, 06:07 PM   #288
jsteg
Member#: 329271
Ice Silver Metallic
The XG7317 is what fram says fits our cars...I was actually hoping for something bigger (taller).
Old 11-18-2013, 12:55 AM   #289
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
Originally Posted by jsteg View Post
So when might an engine build enough pressure to open a filter's bypass valve?? In theory, never, unless there is a problem or maintenance is neglected.
A little Engine Oiling 101 for ya.
New vehicles have full flow oil systems, where 100% of the oil flows through the filter. To prevent oil starvation in the event of a clog, the bypass allows oil to continue to flow. some dirty oil is better than no oil.
general standard for engine oil pressure is ~10psi per 1000 rpm. figure at least 20psi at idle. so really anywhere over 2-3000rpm with the oem specified bypass spring rating, SOME oil will be flowing around the filter element.
with the lower psi rating spring found in some aftermarket filters, it is possible that almost all of the oil is bypassing the filter element, almost all of the time. New it may allow flow fine, but as it starts to fill up with particles.... that sounds bad to me.
Ditto, Wix makes some of the best filters on the market.
FunkMasta is offline   Reply With Quote
Old 11-18-2013, 01:05 AM   #290
sco0bydo0
Member#: 288166
Looks like the M1-108 and M1-110 fits also. Decisions decisions.
sco0bydo0 is offline   Reply With Quote
Old 11-18-2013, 01:08 AM   #291
Commander Keen
Member#: 319157
That's not how it works.
The bypass valve in the filter operates on the pressure differential between the clean and dirty side of the element.
Say at 3000 RPM, your oil pressure gauge (after the filter) measures 30 PSI.
If you install another gauge between the oil pump and filter, it may read 34 PSI, indicating a 4 PSI differential across the element. If the bypass rating on the filter is 15 PSI, it will not be letting any oil past the element, as it's only seeing a 4 PSI delta.
Old 11-19-2013, 08:42 PM   #292
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
you're correct.
and i'd still rather have full filtration at 14 psi, than what a cheaper filter provides. it doesn't matter how good a filter element is if after a 2-3000 miles all the oil is going around it.
Old 11-19-2013, 11:34 PM   #293
shahsmerdis
Member#: 374109
Hey guys, I'm a new user here and new to cars in general. I bought my first 2013 Subaru, and my first oil change is coming up. So what is the general consensus* here? Which oil filter is preferred?
edit 1: Spelling mistake
shahsmerdis is offline   Reply With Quote
Old 11-20-2013, 01:10 AM   #294
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
Originally Posted by shahsmerdis View Post
Hey guys, I'm a new user here and new to cars in general. I bought my first 2013 Subaru, and my first oil change is coming up. So what is the general concisest here? Which oil filter is preferred?
i think you mean consensus... which will be hard to find as filters, like oil, tend to be very polarizing and everyone has their own opinion.
I use Wix filters, or Napa Gold.
realistically any filter listed as compatible for your car should be OK. If you're worried about warranty, the OEM filter isn't a bad idea. But realistically if you stick to the major names you shouldn't have any problems.
the only suggestion i would make is that you get a filter with an anti-drainback valve, as it's mounted upside down.
Old 11-20-2013, 02:40 AM   #295
shahsmerdis
Member#: 374109
Yes, opss. Typo from auto correct on my phone.
I'm trying my best to follow this thread and connect everything together. But it seems like as long as you replace them before they are do, it shouldn't make a difference?
are these aftermarket products being mentioned here generally better or worse then getting an OEM from the dealer?
Old 11-20-2013, 08:01 AM   #296
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Here's what I would do if I were you:
Go to Walmart and buy the 5-quart jugs of Pennzoil Platinum 0W-20 oil. When Walmart has this oil on sale, and when Pennzoil offers rebates on this oil, stock up.
http://www.pennzoil.com/promotions/
At the moment, all of their promotions are for having your oil changed by someone else. But they often have DIY promotions/rebates too. I can typically buy a 5-quart jug of Pennzoil Platinum at Walmart for $15 when they have a DIY promotion in effect. But even the regular $25 price for the jug isn't bad.
Then go to eBay and buy something like this:
http://www.ebay.com/itm/Fram-XG7317-...7c6688&vxp=mtr
The FRAM XG7317 is a great filter, and the $7/filter price in this auction is very good (Walmart charges something like $10 or so for this filter). So find a good multi-pack auction like this one (with free shipping), and stock up on a great filter for a good price.
Finally, buy one of these and install it during your first oil change:
http://www.amazon.com/Fumoto-F-108N-Engine-Drain-Valve/dp/B003VCB9WC/ref=sr_1_1?ie=UTF8&qid=1384952094&sr=8-1&keywords=fumoto+f-108nhttp://www.amazon.com/Fumoto-F-108N-Engine-Drain-Valve/dp/B003VCB9WC/ref=sr_1_1?ie=UTF8&qid=1384952094&sr=8-1&keywords=fumoto+f-108n
Connecting a tube to the valve's nipple makes it easy to prevent a mess. As you will see when you remove the drain plug for the first time, hot 0W-20 oil dumps out of the car FAST. This valve gives you control, prevents you from getting hot oil on your hands, makes it so that you don't have to buy a new crush washer for each oil change, and eliminates the risk of accidentally stripping the threads out of your aluminum oil pan by over-tightening the drain plug (the valve stays in place once it's installed).
Have fun!
Old 11-20-2013, 09:37 PM   #297
jsteg
Member#: 329271
Ice Silver Metallic
Originally Posted by sgoldste01 View Post
Here's what I would do if I were you: Go to Walmart and buy the 5-quart jugs of Pennzoil Platinum 0W-20 oil. When Walmart has this oil on sale, and when Pennzoil offers rebates on this oil, stock up. http://www.pennzoil.com/promotions/ At the moment, all of their promotions are for having your oil changed by someone else. But they often have DIY promotions/rebates too. I can typically buy a 5-quart jug of Pennzoil Platinum at Walmart for $15 when they have a DIY promotion in effect. But even the regular $25 price for the jug isn't bad. Then go to eBay and buy something like this: http://www.ebay.com/itm/Fram-XG7317-...7c6688&vxp=mtr The FRAM XG7317 is a great filter, and the $7/filter price in this auction is very good (Walmart charges something like $10 or so for this filter). So find a good multi-pack auction like this one (with free shipping), and stock up on a great filter for a good price. Finally, buy one of these and install it during your first oil change: Video Link: http://www.amazon.com/Fumoto-F-108N-Engine-Drain-Valve/dp/B003VCB9WC/ref=sr_1_1?ie=UTF8&qid=1384952094&sr=8-1&keywords=fumoto+f-108n Connecting a tube to the valve's nipple makes it easy to prevent a mess. As you will see when you remove the drain plug for the first time, hot 0W-20 oil dumps out of the car FAST. This valve gives you control, prevents you from getting hot oil on your hands, makes it so that you don't have to buy a new crush washer for each oil change, and eliminates the risk of accidentally stripping the threads out of your aluminum oil pan by over-tightening the drain plug (the valve stays in place once it's installed). Have fun!
Agree completely! All of the mentioned things are what I have done and been doing for quite a while now. I do believe walmart's price is only $9 though but either way...
Old 11-20-2013, 10:02 PM   #298
mr. nosidda
Member#: 302959
2014 Impreza 2.0i
Ice Silver Metallic
Possible alternatives from largest to smallest. I have not tried all of these, so confirm the specs and use at your own risk:
L30165 - 97.5% at 20 microns, bypass is 25-35 PSI, anti-drainback valve, no PL or PSL counterpart.
Bosch 72158 - Crosses to L30165
Mann ML 1002 - Crosses to M1-104
L20073 - Same as the L30165, but with a 12-15 PSI bypass. No reason to choose this filter.
Wix 51287 - Bypass is 27-33 PSI, has an anti-drainback valve, same size as L30165, unknown efficiency.
Fram PH6941 - Crosses to L30165
PL24458 - Possibly discontinued. 99.9% at 20 microns, anti-drainback valve. Bypass is 12-15 PSI.
PL14459 - Larger than the TR part, 99.9% at 20 microns, anti-drainback valve. Bypass is 12-15 PSI. This is probably the highest efficiency option for our cars.
Mobil 1 M1-104 - Crosses to PL14459, 99.6% efficiency at 25 microns.
PL14610 - Small can, 99.9% at 20 microns, anti-drainback valve, bypass is 14-18 PSI.
PL14620 - Specs appear identical to the PL14610.
PL14612 - A shorter (possibly too short) version of the PL14610. No reason to choose this filter.
Notes:
-The PureOne (PL) parts often have Synthetic (PSL) and Classic (L) counterparts. PL outperforms PSL, which outperforms L.
-A PL30165 would be perfect for our cars, but it doesn't exist.
-The stock filter needs a high bypass pressure because it's tiny. Lower bypass pressure isn't a big concern for larger filters.
-The L30165, 51287 72158, ML 1002 and PH6941 are larger than the stock TR filter by ~0.25 quarts. The first two have known high bypass pressures, though this rating is less important for filters of this size.
these should work on a 2014 impreza right? just want to make sure.
mr. nosidda is offline   Reply With Quote
Old 11-20-2013, 10:21 PM   #299
Commander Keen
Member#: 319157
I've run the M1-104 and PL14459. Both are excellent.
The others should work based on their specs, but data is sometimes flawed.
Old 12-27-2013, 12:40 PM   #300
Crash00527
Member#: 367123
Marine Blue Pearl
Stupid question... Again. I just noticed the m1-104 is smaller than the specified m1-110. Now it's said that the bigger filter will compensate the high bypass pressure. But how is that so when the 104 is the smaller one?
