South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 11-18-2013, 05:44 PM   #1
SgtCruz
Member#: 335760
2008 wrx
white
Default suby down!
so i was driving on an incline in 1st gear for about 150 feet then shifted to 2nd gear. i drove for about 100 feet and the pavement leveled out. my car turned off by its self. i used my accessport to scan for code "no codes" so now im trying to turn the car on and it stumbles from 600 rpm to 200 rpm trying to stay running, it cuts off in about 5 to 6 seconds. if i press on the pedal it does nothing unless i floor it then it starts to gain rpm very slowly and after it reaches around 900 rpm it just up to 5000 rpm
what im guessing is the fuel pump, everything in my car has been taken off and replaced including the fuel pump. im getting a strong smell of fuel inside the car but nowhere around the engine compartment
SgtCruz is offline   Reply With Quote
Old 11-18-2013, 08:26 PM   #2
SgtCruz
Member#: 335760
2008 wrx
white
any ideas guys????
Old 11-18-2013, 09:24 PM   #3
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Might be electrical. Check fuses. Probably the easiest thing to cross off. My car did something similar in the past and it was a fuse. Just a thought. Hard to diagnose without seeing the car.
granny is offline   Reply With Quote
Old 11-18-2013, 09:54 PM   #4
NACHO_WREX
Member#: 364900
2004 WRX
Java Black
If you smell fuel id Check all fuel lines ..
NACHO_WREX is offline   Reply With Quote
Old 11-18-2013, 10:35 PM   #5
yman
Member#: 199051
04 sti
psm
FUEL LINES!! Check them asap. Find it.
Also check your oil (sounds stupid but still) and vacuum lines.
yman is offline   Reply With Quote
Old 11-18-2013, 10:38 PM   #6
SgtCruz
Member#: 335760
2008 wrx
white
ill have to tow it to my house and check on it on my day off but i want to say its some portion of the fuel system, i put in a walboro 255 pump and im really pushing it now so many the fuel pressure regulator or some portions of the fuel line system idk ill have to rip it apart again, the vacuum lines every single one has been removed and upgraded with clamps on everything so i just dont see that being the issue maybe even a coil pack maybe idk but the spark plugs are new also
Old 11-18-2013, 11:15 PM   #7
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
99OBSTi 91NSX 06 9-2xAero
What are your cross streets?
JapCarRealGood is offline   Reply With Quote
Old 11-18-2013, 11:17 PM   #8
lox
Member#: 348423
08 FXT swapped
never underestimate the flammability of gasoline, do you have a fire extinguisher?
lox is offline   Reply With Quote
Old 11-18-2013, 11:54 PM   #9
SgtCruz
Member#: 335760
2008 wrx
white
well ill take it to my brothers house at 35th ave and van buren,
LOX!!! help! maybe if you take some really nice pictures of my suby it will return to life
Old 11-19-2013, 03:02 AM   #10
CodeRed30
Member#: 350787
2013 WRX
What mods are on the car, if any? If there are mods, who did the work?
CodeRed30 is offline   Reply With Quote
Old 11-19-2013, 09:09 PM   #11
B.rice85
Member#: 344158
2013 BRZ
Sounds like a clogged fuel filter to me.
B.rice85 is offline   Reply With Quote
Old 11-20-2013, 03:41 AM   #12
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Recent fuel pump upgrade, then this? I'll put my money on that.
KP is offline   Reply With Quote
Old 11-21-2013, 08:30 PM   #13
lox
Member#: 348423
08 FXT swapped
willing to take pics of your injectors, but not the pump
Old 12-05-2013, 10:53 AM   #14
SgtCruz
Member#: 335760
2008 wrx
white
Sorry for the super late response I currently dont have internet at home. So I checked the oil it sticks of fuel so I swapped it out. The car at a cold start sounds as if it has a bend rod but it goes away after its warm. The fuel system I still need to check
Old 12-05-2013, 10:56 AM   #15
SgtCruz
Member#: 335760
2008 wrx
white
Injectors should be ok I replaced every seal and o ring on the intake system including the fuel lines unless the cylinder 1 injector took a dump on me im getting massive cylinder 1 roughness
