Old 10-18-2013, 03:08 PM   #1
bradze
Member#: 103208
2011 Outback
Azurite Blue
Default will these tires fit?
http://www.tirerack.com/tires/tires....Qty=4&i1_Qty=4
i wanna put taller tires on my wifes '12 impreza sport and are similar to what's on my outback and look like what i want.
bradze is offline   Reply With Quote
Old 10-18-2013, 03:50 PM   #2
Eminaga
Member#: 370430
2013 Impreza Sport
Marine Blue Perl
I would say yes but wait for couple more answers before you order. My plan is to get similar size for my next replacement if possible also. Maybe I will try 225/50/17 if that cant fit then I saw others fit 215/50/17 and looks better then stock.
Eminaga is offline   Reply With Quote
Old 10-18-2013, 05:44 PM   #3
bradze
Member#: 103208
2011 Outback
Azurite Blue
Out of.boredom I swapped the wheels between my impreza and my outback and my 235/55/17s just barely fit on the impreza. I only drove about 20 feet but I think tires that are an inch smaller shouldn't be a problem. Just remembered that
Old 10-18-2013, 06:03 PM   #4
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Can you post a pic of your impreza with the outback tires?
kinger37 is offline   Reply With Quote
Old 11-23-2013, 08:04 PM   #5
bradze
Member#: 103208
2011 Outback
Azurite Blue
Old 11-23-2013, 08:10 PM   #6
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Thanks! Were there any rubbing issues?
Old 11-24-2013, 07:52 AM   #7
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
And in your first pic, is that your Outback with your Impreza wheels installed?
LOL
Old 11-24-2013, 03:29 PM   #8
bradze
Member#: 103208
2011 Outback
Azurite Blue
yup, i actually like those wheels on the outback. and there is no way those 235/55/17 tires would fit the suspension on a stock '12 impreza. if i swapped on new forester or XV struts, theyd fit. i drove the impreza about 20 ft that day
Old 11-24-2013, 03:57 PM   #9
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
Funny that you say that about those Impreza sport wheels, they are actually older Outback wheels painted a different color... I noticed this on the oem wheel thread.
Tha Chakal is offline   Reply With Quote
Old 11-24-2013, 03:59 PM   #10
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Do you guys think a 215/55 tire would be ok on the stock 17's? I was planning on getting 215/50 tires but would prefer a slightly taller tire if possible.
Actually, now that I think of it, maybe a 225/50 tire wouldn't be bad. Tire height should be in between a 215/50 and a 215/55. Right?
Old 11-24-2013, 04:34 PM   #11
Tha Chakal
Member#: 372100
215/55 would add over an inch in height and under a half inch in width with +3 mph @60 mph.
215/50 would add under a half inch height and width with +1 mph @60 mph.
225/50 would add under an inch height and width with +2 mph @60 mph.
I don't see any of them adding enough size to be a problem, maybe your first choice.
I'm planning on going the same route whenever I replace my tires. 215/55 16's if I stick with my stock wheels, 225/50 17's if I upgrade to new wheels.
Old 11-24-2013, 04:38 PM   #12
grnmchn
Member#: 368331
2013 impreza sport
Diameters
Stock= 25.07"
215/50= 25.46"
215/55= 26.31"
22/50= 25.86"
I to want to run 225/50's as well on a 13' 5dr but I can't find anyone that has. I have RA mudflaps and it's a sport so there is less clearance behind the front tires.
Anyone?
grnmchn is offline   Reply With Quote
Old 11-25-2013, 07:57 PM   #13
ans2k
Member#: 315631
2012 Impreza Sport
Originally Posted by grnmchn View Post
Diameters
Stock= 25.07"
215/50= 25.46"
215/55= 26.31"
22/50= 25.86"
Anyone?
They should fit. There was an earlier model Impreza with XV rims and tires on. The XV tires measure out to be 225/55/17 which is about 26.8 inches in diamter. 225/60/16 also measures out to be 26.8 inches.
http://forums.nasioc.com/forums/show...2417083&page=3
Old 11-28-2013, 11:01 AM   #14
bradze
Member#: 103208
2011 Outback
Azurite Blue
not surprising, the 235/55/17s almost fit, they're 27.2" in overall diameter
