Old 04-12-2011, 05:55 PM   #1
bluesubie
Member#: 767
04 FXT
Default Pennzoil Ultra 5W-40 Used Oil Analysis, 5997 miles, '04 FXT
UOA by Oil Analyzers Inc.
Driving conditions: Oil in use since Sep 2010; 7 mile daily commute each way; spirited driving with a few WOT's here and there on days where I have a 30 minute drive. In October, a trip to RI and to the White Mountains of NH (fun mountain driving). Most of my consumption is usually on trips if I'm driving on the Interstate at steady highway speeds. Temps down into the single digits F this past winter. Wear looks pretty good, IMO, although I did only go 767 miles after the last quart of make-up oil.
The last quart of make-up oil used was PU 5W-30. Went to the local Ferrari dealer and they didn't even sell PU 5W-40 since they use the Quaker State version. Ended up going to Wal-Mart to get the 5W-30.
Comments: Lubricant and filter change is suggested if not done at sampling time; Infared results indicate NITRATION is significantly high; Viscosity is SLIGHTLY LOW
Equipment make: Subaru
Equipment model: 2.5L Turbo
Oil use interval: 5,997 miles
Oil type & Grade: Pennzoil Ultra Euro 5W-40
Make-up oil added: 2 qts. (1 qt @ 2,037 miles into OCI; 1 qt at 5,230 miles )
Miles on unit: 105,639
Air filter: Amsoil Ea panel filter
Oil filter: Mobil1 EP
Overall severity of report = 3 abnormal
(newest to oldest, left to right)
PU 5W40; M1 0W40; SSO; SSO;
Iron 8 7 11 11
Chromium 0 0 0 0
Nickel 0 0 0 0
Aluminum 2 0 3 3
Copper 8 15 5 6
Lead 1 0 10 4
Tin 0 0 1 0
Cadmium 0 0 1 0
Silver 0 0 0 0
Silicon 7 8 10 11
Sodium 10 22 28 90
Potassium 0 3 2 2
Titanium 0 0 0 0
Molybdenum 24 123 2 1
Antimony 1 2 0 0
Manganese 0 0 4 0
Lithium 0 0 3 0
Boron 117 112 7 7
Magnesium 19 30 17 17
Calcium 2347 2805 3497 3423
Barium 0 0 0 0
Phosphorus 824 880 654 677
Zinc 1050 1061 717 755
Lube chg N
Filter chg N
Fuel <.5% <.5% <.5% <.5%
Soot <.1% <.1% .1% <.1%
Water <.1% <.1% <.1%
Vis @ 100C: 12.1 13.2 10.1 9.6
TBN 3.78 1.99 4.35 4.01
Oxidation 15 37 43 38
Nitration 27 27 32 27
I'm a little concerned about the nitration, but there really isn't much change over the past four OCI's. In between the run on SSO and M1 0W-40, there was one run on Red Line 5W-30 which I didn't have a uoa done on since it was right after a turbo failure at ~80,000 miles.
Considering switching to Red Line or Motul since I can get $100 off with my Subaru bucks. I'm thinking the esters in Red Line, 300V, or X-Lite might be ideal. I'm also thinking of just going with Motul Eco-nergy 5W-30 because of the high price of fuel!
Comments?
-Dennis
Old 04-12-2011, 05:58 PM   #2
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
...added 2 qt in 6k miles......
no as in thanks, ceeya later, as in not
Old 04-12-2011, 06:39 PM   #3
bluesubie
Member#: 767
04 FXT
Switching oil brands every change probably has a bit to do with the consumption.
-Dennis
Old 04-12-2011, 08:56 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Add some sawdust or chunky peanut butter to your next change to deal with the consumption. But I have no idea what I'm talking about, so I'll just view this on the OTHER FORUM and see what the real grown-ups have to say.
Old 04-12-2011, 09:03 PM   #5
bluesubie
Member#: 767
04 FXT
Originally Posted by Unabomber View Post
... so I'll just view this on the OTHER FORUM and see what the real grown-ups have to say.
Not many responses since my thread title isn't "This oil sucks!" or "I ran Wal-Mart SuperTech and it pwnz"!
-Dennis
Old 04-12-2011, 11:46 PM   #6
only1agam
Member#: 56183
kinda dissappointed about the results, but it seems as though the t6 is still the ideal budget oil that doesn't get swallowed. thanks Dennis for doing this.
Last edited by only1agam; 04-12-2011 at 11:47 PM. Reason: EDIT: dissappointed in the amount of top up.. 2 quarts is a lot even if using different oils every time.
only1agam is offline   Reply With Quote
Old 04-13-2011, 12:37 PM   #7
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
-Dennis
How so?
Mind is offline   Reply With Quote
Old 04-13-2011, 02:00 PM   #8
bluesubie
Member#: 767
04 FXT
Due to different oil chemistries (base stocks and addtives). After a couple of runs on the same oil, consumption usually subsides.
When I used Red Line 5W-30, I actually consumed two quarts in 5k miles. It could have been due to the esters cleaning my engine.
-Dennis
Old 11-27-2013, 12:33 AM   #9
Unit562
Member#: 371848
1986 Civic
Pennzoil is VERY detergent heavy. That **** could run the chrome off a trailer hitch. For some reason the Ultra Euro 5w40 and Ultra 5w30 are different, the Euro seems to get ate up by everything, while the 5w30 doesn't vanish as quick.
Unit562 is offline   Reply With Quote
Old 11-27-2013, 10:25 AM   #10
Uncle Scotty
OK buy Nates beans
d0000000000000d...dont bump long dead threads like this....to add...nothing....really.
Used Oil Analysis on M1 0W-40, 6,034 miles, FXT bluesubie Service & Maintenance 5 09-15-2010 09:39 PM
Used Oil Analysis - Pennzoil Platinum 5W-30 - 2005 Subaru WRX STi AndyH Service & Maintenance 16 03-10-2008 09:30 PM
Used Oil Analysis, German Castrol 0W30, 7,946 mi., '04 FXT bluesubie Service & Maintenance 16 01-17-2008 10:22 AM
German Castrol 0W30 used oil analysis, 7,478 miles, '04 FXT bluesubie Service & Maintenance 0 06-11-2006 08:09 AM
Used oil analysis FXT 6,144 miles German Castrol Syntec 0W30 bluesubie Service & Maintenance 4 11-19-2005 08:21 AM
