Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 06-14-2013, 12:04 PM   #51
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Someone take lots of pictures, I'm not going to be able to make it this year. Very curious to see it on the scales and see which heavey Subaru parts have been swapped out for lighter aftermarket.
Snowphun is offline   Reply With Quote
Old 06-14-2013, 12:07 PM   #52
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Originally Posted by skimobile View Post
I'm curious as to what prevents the track version from being registered as a kit car? I hope this build takes off for them but wonder how many people who would have considered purchase of the road version will instead opt for a BRZ...especially if they release the turbo version.
The track version has no windshield, not sure if that is a requirement for road legal? Otherwise it may just be a question of how uncomfortable you're willing to be on the street. I've seen a couple Nevada registered Radical SR3s, those are absolutely awful to use in real life.
I would buy a turbo BRZ and still consider building one of these, especially with Thomspon Speedway opening up next year.
Old 06-14-2013, 12:16 PM   #53
JeromeS13
Member#: 222815
Dollar for dollar, a BRZ will not compete with this car. And most states require a full windshield to register a car to be driven on the streets.
JeromeS13 is offline   Reply With Quote
Old 06-14-2013, 12:56 PM   #54
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
You can't compare a car that you have to spend a couple hundred hours building with one that you spend 2 minutes writing a check for.
Without a windshield, it can be registered as a motorcycle.
Old 06-14-2013, 01:44 PM   #55
spaceywilly
Member#: 174268
yeah I look at the BRZ as a DD that you can also take to a track once in a while. The 818S is a track toy you can DD once in a while. The 818 won't have AC, a roof, windows, door locks, a radio, power steering, ABS, a dealer with a service department... etc. etc. (but you can always build those things yourself if you want to). But the BRZ won't do 0-60 in 3.8 seconds, weigh 1800lbs, and have the engine in the correct spot and Koni damped double A-arm suspension. If you're building an 818, it's because you want to be able to drive something you can say you built yourself. There are probably more logical options out there if all you want is to go fast around a track (used Corvette or Lotus), but then you don't get the experiences and knowledge that comes with building it.
The track version would not make a good street car. It's about an inch off the ground and has very stiff suspension. There is a different set of suspension mounting points for the street version suspension that raises the ride height, and it has softer springs and dampers.
spaceywilly is offline   Reply With Quote
Old 06-14-2013, 07:16 PM   #56
spaceywilly
Member#: 174268
Old 06-15-2013, 10:13 PM   #57
spaceywilly
Member#: 174268
Old 06-16-2013, 05:50 AM   #58
2subiesinyard
Member#: 139562
2015 Launch Edition
Pollen Green Pearl
Soooo SECKSEY !!! Want.
2subiesinyard is offline   Reply With Quote
Old 06-16-2013, 10:58 AM   #59
skimobile
Member#: 92114
03 WRX (Neon Blue)
in"Special Ed." Run Group
I'm really liking the track-ready model.
Surprised that they're using hood pins to retain the body panels instead of flush mount body clips.
skimobile is offline   Reply With Quote
Old 06-16-2013, 07:07 PM   #60
bstuke
Member#: 354575
2013 818R
One of the first home built 818's is coming to the Southeast and Huntsville AL. It was picked up at the Open House. Can't wait to start seeing progress and feedback.
bstuke is offline   Reply With Quote
Old 11-28-2013, 09:08 AM   #61
Scargod
Member#: 260314
2008 STI hatch
Default My 818R is ordered...
I put down a deposit for an R on 11-27.
See 818R "Glynman style" in the FFR forum.
Scargod is offline   Reply With Quote
Old 11-28-2013, 10:45 AM   #62
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Do you have a delivery date yet? Last time I checked they were pretty far out. Keep us in the loop on your progress!
