Old 11-20-2013, 04:19 PM   #1
BuckwildWRX
Member#: 372900
Default Can't get cel to turn off using 1.3u
Ok guys just recieved my openport 1.3u. downloaded ecuflash, pulled the image from the car. Had the green test connectors plugged up. Opened romraider opened the file I had saved for the image, checked the boxes in my obd2 section for all the tgv codes and disabled them. Then I saved that and pulled it up in ecu flash then wrote it to the ecu. Everything was sent. I turned the ignition off disconnected the green plugs took it for a drive and i;m still in limp mode. I don't know it the wire connector coming off the 1,3u should be plugged into anything. I mean it said everything was succesful. Maybe I should use romraider to send it to the ecu. IDK, I only got one try since i'm about to head off to work. Hopefully I'll get it tonight.
Any ideas,
Thanks,
Jason
BuckwildWRX is offline   Reply With Quote
Old 11-20-2013, 04:20 PM   #2
BuckwildWRX
Member#: 372900
Oh and when I wrote to the ecu I just hit the write to ecu at the top of the bar in ecuflash
Old 11-20-2013, 05:34 PM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
For the 2L wrx, there is an additional checkbox to disable TGV codes besides the P0xxx boxes.
Airboy is offline   Reply With Quote
Old 11-20-2013, 06:21 PM   #4
BuckwildWRX
Member#: 372900
Checkbox in ecu flash or romraider? I did it in romraider clicked the disable bubble and saved and sent it to ecu flash. Where is the box?
Old 11-20-2013, 06:45 PM   #5
Airboy
Member#: 72829
2006 WRX
2015 WRX
In ECUflash, under OBD-II section, there are should be 3 checkboxes for "TGV CEL FIX"
Old 11-20-2013, 10:11 PM   #6
BuckwildWRX
Member#: 372900
I'll try it real quick
Old 11-21-2013, 12:17 AM   #7
BuckwildWRX
Member#: 372900
Well I have tried everything under the sun and still cannot get this mother fer to get out of limp mode. I tried checking all of the boxes in romraider then sending that image to ecuflash. Once in there, instead of tgv fix disabling it will enable. I dont know it was backwards from before. I tried just checking the tgv fix in ecu flash then flashing it to the ecu but I cannot get it out of limp mode. I'm about to freak on this thing.
Old 11-21-2013, 12:23 AM   #8
Airboy
Member#: 72829
2006 WRX
2015 WRX
In ECUflash you have to "enable" the TGV CEL FIX entries.
Old 11-21-2013, 12:34 AM   #9
BuckwildWRX
Member#: 372900
Ok, well I just did some hardcore researching. All i did to prep the system was plug the 1.3u into the obd2 then connect the 2 green wires. Apparently i have to plug the flash block connector into the two wire white connection (2002). I bet that is why it's not actually flashing. What ya think?
Old 11-21-2013, 12:37 AM   #10
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
Yeah you definitely need the flash block. You can make one out of a little piece of wire and two spade connectors.
codesoccer is offline   Reply With Quote
Old 11-21-2013, 12:40 AM   #11
BuckwildWRX
Member#: 372900
Sweet, that's what I was hoping to hear. I have the blue jumper from my cobb.
Old 11-21-2013, 01:32 PM   #12
BuckwildWRX
Member#: 372900
Still didn't work wtf!!!! I'm uninstalling my cobb from it maybe it has this open port locked out
Old 11-21-2013, 01:56 PM   #13
codesoccer
Member#: 179573
2002 MBP Bugeye
You have a cobb map on there? Don't you think that's something you should have mentioned?
Old 11-21-2013, 02:09 PM   #14
BuckwildWRX
Member#: 372900
It didn't dawn on me, it's the stock map married. I just removed it from the car. I pulled the image from the car and now when I go to click on tgv fix it says disabled. I assume that means that the fix is enabled? Can't fathom why my car is still limping.
Old 11-21-2013, 05:38 PM   #15
02nismokiller
Member#: 322963
04 wrx
psm
Well why did the CEL come on for?
02nismokiller is offline   Reply With Quote
Old 11-21-2013, 06:14 PM   #16
BuckwildWRX
Member#: 372900
Tgv valves they are wired open now until I can remove the flapper
Old 11-27-2013, 08:43 PM   #17
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Lol did you reset the ecu after flashing the map ?
BeastianSTI is offline   Reply With Quote
Old 11-27-2013, 08:51 PM   #18
codesoccer
Member#: 179573
2002 MBP Bugeye
Doesn't the ecu reset on a flash?
Old 11-28-2013, 10:25 AM   #19
BeastianSTI
Member#: 310506
2005 WRX STi
I could swear that my fuel trims have carried across after an ecu flash before. I reset afterwards for good measure.
Old 11-28-2013, 01:12 PM   #20
BuckwildWRX
Member#: 372900
Yea guys I got it off but I have an exhaust leak somewhere or my knock sensor is bad bc I'm getting slow spool
