Old 01-31-2004, 09:57 PM   #76
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Yes our OB VDC has 225/60-16's I almost swapped with the wife but she would notice and make me put them back
Peaty is offline   Reply With Quote
Old 06-16-2005, 02:59 PM   #77
subadubdub
Member#: 89368
2001 Legacy
Green w/graphics
I unknowingly had 17x7 Motegi's with a +40 offset. I had some major tire wear on the inside edge of my Kuhmo's -to the point of the rubber breaking to expose the wires. I'm guessing the offset had a lot to do with that. Took me quite a while to figure it out- in fact, I'm still guessing whether or not that's the definitive answer to the tire wear. Anyone have problems with this?
subadubdub is offline   Reply With Quote
Old 06-17-2005, 02:46 PM   #78
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
what about the position of the wheel bearing relative to the wheels mounting surface?
i.e the spindle
would that distance change calculated loads exibited on the bearing?
psyber_0ptix is offline   Reply With Quote
Old 11-07-2013, 09:38 PM   #79
Francis329
Member#: 366344
After reading all this helped me out a lot! But could you guys help me figure out what offset I need to run a 17x9.75 on my 2003 wrx?
Francis329 is offline   Reply With Quote
Old 11-07-2013, 10:20 PM   #80
sc00by4life
Member#: 97135
Obviously it hasn't.
And you haven't provided nearly enough information.
Old 11-29-2013, 03:45 PM   #81
BugEyeBuilder
Member#: 364594
2002 WRX Sedan
I am so confused by all the conflicting infopinions here that I am no further in my understanding than when I started. So, quick question please. I have an 02 wrx sedan. I want to run an 18x8.5, possibly 18x9, but no more than that. I like the concave look, I will favor performance. What offset can I run on a wheel this size and clear struts but not adversely affect handling? I will be running coil-overs and run a functional ride height. Not slammed, track-inspired. Please help. I am a newbie and cant find a straight answer. Thanks Thanks everyone!
BugEyeBuilder is offline   Reply With Quote
Old 11-29-2013, 03:55 PM   #82
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
18x8.5 plus 44 to 48 range with a 235-40-18 or 225-40-18 - you can run those normally with out rolling or pulling the rear.
18x9 plus 38 to 42 range - 245-35-18 and roll the rear.
The above are safe numbers but with coilovers and camber plates to adjust camber you have a little room to play with.
MD04WRX is offline   Reply With Quote
wheel offset difference, which way to go in this situation? irish44j Autocross 5 11-22-2009 11:55 AM
Considering this EVO, good idea on this particular car? MF-DIF Off-Topic 19 03-04-2008 03:39 PM
Anyone know the offset of this wheel? subysouth Tire & Wheel 9 08-28-2005 10:48 PM
what determine wheel offset? can I take vw wheels and rotors? etam Brakes, Steering & Suspension 9 05-27-2002 02:32 PM
WRX wheel offset w/body kit, does this look funny to u? JayGold Newbies & FAQs 1 06-13-2001 08:46 PM
