Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-26-2013, 03:30 PM   #1
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Default 215 vs 235 total grip
I've been thinking about upgrading my tires when my star specs run out, but I'm not sure if I want to stick with my current size 215/40/17 or go to 235/40/17. Would there be a noticeable grip difference by adding the 20mm or would I be better off just sticking with what I have.
I don't track my car but I do like the get the most out of what power I have. I'm running a little shy of 300whp, and have 17x7.5" sparco wheels.
Millhouse_5 is offline   Reply With Quote
Old 11-26-2013, 03:46 PM   #2
sc00by4life
Member#: 97135
Originally Posted by Millhouse_5 View Post
I've been thinking about upgrading my tires when my star specs run out, but I'm not sure if I want to stick with my current size 215/40/17 or go to 235/40/17. Would there be a noticeable grip difference by adding the 20mm or would I be better off just sticking with what I have. I don't track my car but I do like the get the most out of what power I have. I'm running a little shy of 300whp, and have 17x7.5" sparco wheels.
Maybe a 225, I wouldn't do a 235/40 on a 7.5" wheel.
Are you having traction issues right now? Otherwise you're only adding weight.
Old 11-27-2013, 03:15 PM   #3
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
I wouldn't say I'm having issues with traction, I've got lots, just always nice to have more cornering ability and stopping power.
One reason I'm looking at 235/40 is the older JDM sti's ran 205/50/16 from factory so I'm trying to stay closer to OEM size. Also, if I get a wider tire, I might be able to get one that last a little longer than my star specs and provides about the same amount of grip due to the extra surface area.
Old 11-27-2013, 06:24 PM   #4
sc00by4life
Member#: 97135
wider tires won't help you corner any faster than you are now.
and the reason i say i wouldn't do a 235/40 is because its a little short to run on a wheel that narrow. you could do a 235/45, but then you have to deal with softer sidewalls and more roll over.
if you aren't having traction issues, i see no reason to change.
Old 11-27-2013, 08:10 PM   #5
memmek2k
Member#: 324832
2008 WRX
I agree, if you're not at the limits of the current tires, you won't notice a difference with wider tires. 235 mm section width is at the wider limit of recommended sizes for a 7.5" rim.
Also, your current size is... Strange. There's like a 1" overall diameter difference between your current size and what you're considering. Going to throw off your speedo by quite a bit (or it's already off).
memmek2k is offline   Reply With Quote
Old 11-29-2013, 07:03 AM   #6
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
fauly logic....stay with a 225/45 for a 7.5 wide wheel and star specs last a long time for the kind of tire they are
stay with what works
Old 11-30-2013, 02:01 PM   #7
thejaredhuang
Member#: 86206
2006 WRX Wagon
I went from a 245 on a 8" rim to a 225 on the same rim and I could notice the difference. Same tyre, Michelin PS2, all 4 corners. There was less grip and no change in sharpness.
thejaredhuang is offline   Reply With Quote
Old 11-30-2013, 03:09 PM   #8
Radeon
Member#: 105251
13 BRZ,STI
People are installing 235/40 Dunlop ZII on a 7"-wide rim and are going faster in a BRZ. So it's totally sidewall-stiffness dependent. I would totally do it on a 7.5" rim.
Wider rubber will totally give you more grip. However, 235/40 will be taller than 215/40 and you'll have effectively taller gearing and a couple of hp, due to heavier tire.
Radeon is offline   Reply With Quote
