Old 12-01-2013, 03:01 AM   #1
MassSTI
Member#: 372843
Default 2006 STI all performance fitment?
I have a 2006 STI with about 500awhp on stock wheels and bridgestone potenza's. I'm looking into buying a set of wheels right now and I was just wondering what size you would go with for strictly performance gains? wider than stock 17's or 18's, and what tire you would use. Also what wheels you recommend need to be lightweight.
MassSTI is offline   Reply With Quote
Old 12-01-2013, 09:19 AM   #2
17x9 +42 with a 245/40 or 255/40...something light like an rpf1
Old 12-01-2013, 12:35 PM   #3
MassSTI
Member#: 372843
Ok thanks for the input!
Old 12-01-2013, 08:11 PM   #4
oh...and saying 'bridgestone potenzas' says NOTHING
'potenza' is a whole line of tires....from **** as tires to the top of the line MAX performance, re-11
dont put some **** AS tires on it thinking ya got something good
Old 12-04-2013, 01:43 PM   #5
boardinjorden
Member#: 349610
06 STI
18x10 2753518 advan neova
boardinjorden is offline   Reply With Quote
Old 12-04-2013, 02:06 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Tire Rack still sells some Potenza RE-92 in certain sizes... There's nothing quite like THOSE Potenzas... High Performance all season... yep.
225/45/17 is $286 a tire. That's how "special" those Potenza RE-92s are. (Short bus special.) Classic Potenzas... Probably will never be another tire quite like them.
In all seriousness though, I think when he said stock wheels and Potenzas he meant stock Potenzas... as in the RE070 that came stock on STI of that vintage.
Old 12-04-2013, 02:09 PM   #7
xirallicgdb
Member#: 247850
2007 SWP STi
CGM '07 Forester
17x9 with a 255. Beware of offsets and wheel designs. Some wheels you may think will fit, will not due to the spoke design. For instance a 17x9 +45 rpf1 needs an 18 mm spacer iirc to clear brembos.
xirallicgdb is offline   Reply With Quote
Old 12-04-2013, 05:46 PM   #8
Mach V Dan
Member#: 12029
Mach V Awesome 17x9 +42 fits, no spacers.
--Dan
Mach V
FastWRX.com
Old 12-05-2013, 09:38 AM   #9
--Dan
Mach V
FastWRX.com
i know there isnt as much demand...but i really wish you had them in 17x8 or 17x8.5 in 5x100
but i know it jus aint k000 to run such small rimzzzz
oh well
Old 12-05-2013, 02:22 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
You can get 5x100 Kosei K4R 17x8 +36 at Tire Rack if you tell them you have a BRZ. Within a couple ounces of RPF1 weight, but sits a little wider than the standard +45 17x8 RPF1. It's ~6mm inboard of a 17x9 +42. I wouldn't really want my wheels sticking out more than they are with these K4R 17x8 +36.
Brake clearance doesn't appear to be a problem. I put the 332x32 stoptech template into my wheels before mounting them. There was so much clearance I didn't even feel I needed to get a real accurate measurement. Eyeballing with parallax and such it was over 20mm clearance to the spokes at the narrowest point. I don't know how much wider Brembos are, but I doubt it's 20mm more than 332 stoptechs.
Fits fine no rub on my 02 sedan with 235/45/17 RE11A (-1.3F / -0.9R camber). I had already rolled the rear, but I'm not even sure that was necessary. Not a bad performance fitment for 5x100, and they're cheaper than RPF1. IMO they look better than RPF1 too. Those who don't have a 4.44 tranny should opt for a 235/40, which would give even more fender room.
8.5 wide would probably be better, but this appears to be a very unpopular width, since every wheel that comes along at 17x8.5 gets discontinued in short order.
Old 12-09-2013, 11:59 AM   #11
defthand
Member#: 374901
im running 17x9+45 RPF1 with 5mm hubcentric spacers and extended studs...car handles amazingly with my suspension setup.
defthand is offline   Reply With Quote
