Old 12-01-2013, 12:44 AM   #1
Wrxstage2yukon
Member#: 371966
Default TIPS on wrx engine pull
Hey guys, pulling my engine tomorrow on 03 wrx. I know there's lots of threads already out there on the whole process, but each one seems to vary and aren't to to specific.
Thought it was worth asking if there is anything " funny " or " surprising " a guy should know about, on the pull and when it goes back in. Anything specific to keep an eye on. That's All
Cheers
Wrxstage2yukon is offline   Reply With Quote
Old 12-01-2013, 08:59 AM   #2
WWC
Member#: 374436
Very straight forward, and actually a quick process. Biggest pain will be sliding forward the engine from the tranny to clear the bottom studs going into the bell housing.
WWC is offline   Reply With Quote
Old 12-01-2013, 10:43 AM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
label hoses if its your first time
Old 12-01-2013, 10:59 AM   #4
Wrxstage2yukon
Member#: 371966
Will do, thanks guy.
Old 12-01-2013, 11:49 AM   #5
OldManRed04
Member#: 356635
2005 STI
WR Blue
Raise the engine with the hoist with the tranny unbolted. Slide a jack stand with a block of wood on top under the tranny once you get the engine as far up as will allow. Lower the tranny into the jackstand and then the engine will very easily slide forward. Don't forget to remove the pin for the release fork and disengage the release for from the throw out bearing. If you don't, the tranny and engine will still be attached. First time took me 2 hours to pull. It's very basic.
OldManRed04 is offline   Reply With Quote
Old 12-01-2013, 12:01 PM   #6
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Lots of threads, most fairly in depth, plus youtube. AKA you're lazy.
Old 12-01-2013, 06:04 PM   #7
Wrxstage2yukon
Member#: 371966
Engines out.
Old 12-02-2013, 04:03 PM   #8
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Remove the front o2 sensor BEFORE you remove the engine.
Zephyr is offline   Reply With Quote
