Old 11-27-2013, 05:11 PM   #1
G2
Member#: 5559
1963 Schwinn
Sky Blue Pearl-metallic
Question EJ20K in '02 WRX...what's in store for me?
Looking to replace my stock EJ205 with another engine. Found a EJ20K locally, and if I could make it work I'd love to.
Just curious as to what I'll be needing to do to make it all work out.
So far this is what I know for sure:
  • Tune (Tactrix or AccessPort (seller has tune specs and some baseline maps to work from))
  • Crank Sensor
  • MAF sensor (I can use the MAF/Intake Tube from my current engine, correct?)
I want to make sure I have a complete list, so I can be sure to have a complete list of parts that are needed before I purchase. Things like rad hoses, sensors, IM, Coil Packs, etc. Anything else anyone can glean some light on, that would be great!
TIA!
G2 is offline   Reply With Quote
Old 11-27-2013, 06:28 PM   #2
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
I would rather go for an ej207 or a ej255
alexandern05 is offline   Reply With Quote
Old 11-27-2013, 06:52 PM   #3
G2
Member#: 5559
1963 Schwinn
I would too, but they're few and far between in stock and unabused form.
And for the price, this one is a fresh rebuild, has some built internals that can take it where I'd like to be HP wise, without a problem, and is considerably less in the end doing some conversions, over finding a replacement EJ205/7 or EJ255 and rebuilding myself.
I know I'm going to pay up front in hassle for the short-cut but worth it IMO for a bolt-in ready set-up (w/ as little downtime as possible).
If it turns out I'm getting in way over my head I don't have to move on it, but I'd like to move past this dying engine and get on with things.
Old 11-27-2013, 07:07 PM   #4
alexandern05
Member#: 266954
04 wrx v7 sti swap
Are you planning on using your ej205 heads and intake manifold? If not you will have to get the ecu for the engine you want to buy and look into if everything bolts up do you know what year the engines from I'm not to familiar with pre 2000 jdm engines
Old 11-27-2013, 09:28 PM   #5
2000 legacy b4
Member#: 374768
I was going to say use your complete intake manifold off the 205 and put it on the 20K long block how ever I think the 205 is a phase 2 motor so the manifold bolt patterns will be different, I believe the CR is different between the motors as well.
2000 legacy b4 is offline   Reply With Quote
Old 11-28-2013, 09:31 AM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
There is a lot more to it to make the EJ20K work in a newer car and frankly it is not worth it. Your intake manifold will NOT work on this engine. Your ECU will NOT run this engine.
Zephyr is offline   Reply With Quote
Old 12-02-2013, 03:36 PM   #7
G2
Member#: 5559
1963 Schwinn
thanks guys!
The seller said my IM would work...but now I'm not sure. And he said I'll need the cam gears/timing trigger and CAS from my engine, but sounds like I'll need more.
might have to walk away from this one.
it's a shame, since it has a nicely built head and forged pistons/rods and is completely rebuilt. Only ran on the dyno stand to ensure it runs.
Old 12-02-2013, 03:45 PM   #8
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
I wouldn't just walk away, I would RUN!
Old 12-02-2013, 06:17 PM   #9
G2
Member#: 5559
1963 Schwinn
yup....looks like my best option at this point.
finally was able to get the right combination of search terms to find this:
http://forums.nasioc.com/forums/show...29&postcount=8
back to buying a wrecked '02 and grabbing the stock unit out of that one.
