Old 12-02-2013, 04:21 PM   #1
Lefortsubi
Member#: 350505
2010 wrx
white pearl
Default Rode with axle bolt loose....
So I did a tranny swap and rode 50 miles with axle bolt lose.. In and 1/4 bolt.. somehow my abs sensor got rubbed against.. Which made my car go into limp mode.. Bought 3 new sensors and I've realized that's not the problem.. The actual wheel bearing/ hub must have moved with the axle being lose. How can I get this back into spec or what should I do? Looking at the other side it looks flat when u look at the wheel bearing, this side there about a few mm difference between the plastic and the metal. Please help need to get this right!
Lefortsubi is offline   Reply With Quote
Old 12-02-2013, 04:22 PM   #2
Lefortsubi
Member#: 350505
2010 wrx
white pearl
If anyone wants to see pics txt me 302-632-5109
Old 12-02-2013, 04:24 PM   #3
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Axle nut.
And loose or off?
The wheel bearing is likely toast as it needs the axle nut to maintain pressure to hold the tapered bearing together under load.
Old 12-02-2013, 06:18 PM   #4
aperson
Member#: 273649
2002 WRX Wagon
Originally Posted by Psychoreo View Post
Axle nut.
And loose or off?
This +1.
You likely killed the bearing.
aperson is offline   Reply With Quote
Old 12-02-2013, 06:33 PM   #5
Lefortsubi
Member#: 350505
2010 wrx
white pearl
Axle but was on but loose, yeah it looks like the bearing moved a little or something. Is a wheel bearing something I could replace????
Old 12-02-2013, 07:30 PM   #6
Psychoreo
Member#: 79643
2015 WRX STI
On what car?
Old 12-02-2013, 08:03 PM   #7
Bikelok
Member#: 254851
2002 WRX wagon 5mt
At this point you probably need a new bearing, seals, axel nut (you are not supposed to reuse axel nuts) and hub.
If you drove it with loose axel nut and it moved enough to damage the ABS, then you probably messed all the stuff I mentioned up.
Also, if you are not familiar with how the wheel bearing works, then your options are:
Take it to some one to fix ($$$$).
Read up on what it takes to repair it all (not hard to do, but several very special tools are required). Depending on the repair method you may or may not need an alignment.($$-$$$).
Get a junkyard knuckle/hub assembly ($). The junkyard route is easy, but its all used so you don't know how long the used bearing will last and you will need an alignment too.
Oh, and fill out your profile, so we know what kind of car, year, model etc, etc.!
Bikelok is offline   Reply With Quote
Old 12-02-2013, 08:09 PM   #8
Psychoreo
Member#: 79643
2015 WRX STI
Should be about $300 plus parts if you use the stealership.
