Old 11-13-2013, 10:29 PM   #1
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Default help!!! external wastegate popping!!
2002 wrx
Cobb sf turbo intake
Cobb turbo inlet (recirculation blocked)
16g turbo
Front mount intercooler
Hks ssqv4 (atmos)
Gruppi catless headers
Catless uppipe
Obx 38mm external wastegate mounted on uppipe.(same as tial if anything exact)
Catless invidia dp (bellmouth)
Straight pipe
Grimmspeed 3 port (just bought)
Walbro 255 pump
New fuel filter
Just replaced vac hoses(everything)
Protuned pushing 21 pounds!
Now to start off. I recently got the car protuned after going with the ewg and 3 port. Night and day difference. I love the feel of 21 lbs. But when in 3rd and 4th at wot the wastegate starts poppin like how two stepping sounds..
Is my car blowing up????!
Please help
codesbugeye is offline   Reply With Quote
Old 11-14-2013, 07:28 AM   #2
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Sounds like you're hitting full boost and it's normal for the waste are to flutter or "bang". Mine sounds like "banging". You will always get some flutter or banging maybe popping sound when using a 3port and not a manual boost controller.
The EWG is opening and closing to maintain boost levels.
Brother EddieJ. is offline   Reply With Quote
Old 11-14-2013, 07:32 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you go with the hybrid boost control the wastegate won't pulse with the PWM signal of the EBC solenoid.
Old 11-14-2013, 08:18 AM   #4
Turd Nugget
Member#: 346017
2013 STi Wagon
Do you have a boost gauge on it? what is the boost doing when you hear this popping? if its staying stable, like others said its probably just the 3 port cycling and your wastegate dumping. I wouldnt say "banging" or "popping" would be a good word to describe how this SHOULD sound. If your boost is jumping around a bunch maybe the wastegate has got a sticky spot in it or you might be hearing compressor surge.
Edit: You should take a video of whats happening and upload it for some better answers.
Turd Nugget is offline   Reply With Quote
Old 11-14-2013, 09:06 AM   #5
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Yeah boost gauges stays at 21lbs and tappers to 19lbs at 6300 rpm. And how should I post the vid on here? I'm using the mobile app at the moment.
Old 11-14-2013, 09:41 AM   #6
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
If you have a Ebc then the sound is gonna be there. Especially with the grimmspeed ebcs.
Its just your ewg controlling boost.
Nothing to worry bout. Takes some time getting use to is all.
cosseywrx is offline   Reply With Quote
Old 11-14-2013, 10:49 AM   #7
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
Copy the YT URL in a post and it should put a thumb nail up. If not the link will be there.
iconone is offline   Reply With Quote
Old 11-16-2013, 11:14 AM   #8
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Now the wastegate sounds as if it is stuck open.. is it because the top port of the wastegate is vented? Running on 3port
Old 11-16-2013, 12:57 PM   #9
cosseywrx
Member#: 276443
I vent mine. Most people do or they plug it. You can recirc it after the Maf but before the turbo.
Old 11-16-2013, 02:28 PM   #10
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
So has it came down to just this wastegate being a piece of s***... :/ since its stuck open
Old 11-16-2013, 02:32 PM   #11
LUMBERZACK
Member#: 340009
2007 STi
48W
This is what mine sounds like. This is all normal and the mod list is in the description. Sorry for vertical video, my friend was filming.
LUMBERZACK is offline   Reply With Quote
Old 11-16-2013, 02:47 PM   #12
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Yeah see mine never sounded like that. It would start screaming then have nasty pops like if it was backfiring harddd while accelerating in full boost. Now I hit boost and the wastegate stuck open.. so now it sounds like I got open downpipe at idle.
Old 11-30-2013, 07:55 PM   #13
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
So this is my problem now!.... my wastegate opens fine. The car is set to 21 lbs but when I try to go into wot I jumps pass 21 lbs... and when around 5000k rpm the car backfires. Like shotguns going off.. I was told it could be my timing.!?!? Please help!
Old 12-01-2013, 10:02 AM   #14
BuckwildWRX
Member#: 372900
Fuel cut, knock? Something is more thank likely cutting your ignition or fuel or one other possibility is a boost leak that is not prevalent till higher rpms.
BuckwildWRX is offline   Reply With Quote
Old 12-03-2013, 11:53 AM   #15
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
The popping only happens when the car boost over 21 lbs.. cause for some reason the tune isn't holding
Old 12-10-2013, 07:20 PM   #16
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
I need help! Is my car like detonating so its pulling the timing cause it to pop
