Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 10-24-2013, 03:51 PM   #1
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Default Running lean under boost, have datalogs
I finally finished my WRX swap into my 94 Impreza. The swap was everything out of my old WRX with only a few differences. Now I am in the phase of "working out the kinks" and have some issues with consistent bucking/stumbling/hesitation under acceleration.
The set up I am running in my 94 is almost exactly what I ran in my 2003 WRX for years without any problems. Again, everything came directly out of my old WRX and put in the 94, with a lot of work of course. All of the mods on my old WRX were on the car when I bought it, including the tune. Again, I drove the car for years with no issues.
Here's what I am running as far as drivetrain/engine stuff:
03 USDM WRX engine, trans, ecu, intercooler
MRT catless uppipe
A very large catted downpipe, no brand markings on it
Stock airbox, regular air filter
TurboXS UTEC and manual adjustable boost controller, tuned to 16.5psi
Here is what is different between my old WRX and the setup in my 94:
-No airbox snorkus/silencer - running only the airbox
-Exhaust manifolds were wrapped with DEI titanium wrap
-Merged the 94 and WRX harnesses
-02 gas tank and fuel pump - I have not checked the pump myself but the guy who I got the tank from said it was a Walboro 255 pump. The car that the tank was in was running a V7 motor. Honestly I don't know what pump I was running in my 2003 because I never checked it.
-I'm using the WRX fuel lines and all of the emissions crap
-I'm using the fuel filter from the same car as the tank, it looks brand new - Edit - I replaced the fuel filter.
When I first got the car running and driving I was having issues reaching target boost. I have meticulously performed several boost leak tests; I found a small leak at the BPV gasket so that was replaced yesterday, along with the two gaskets on the underside of the intercooler for good measure. I did not find any other leaks anywhere besides the BPV gasket.
Now I do not have an issue building boost but am having some serious bucking/hesitation/stumbling in all gears. It is not as bad in 4th and 5th gear but I am not pressing it too hard because I don't want to damage anything.
I did some quick datalogging on my lunch break and hope I can get some help. I have not adjusted any maps on the UTEC, ever. The only thing I have adjusted so far was the Max TPS threshold as last night I saw that the UTEC was fluttering between 99-100% TPS reading at WOT. So I bumped that figure up 0.1 to ensure the UTEC wasn't struggling to figure out which map to use at WOT.
As far as maintenance, all of the engine maintenance is up to date and performed by me, including timing belt and spark plugs. These were changed not too long ago but when the engine was still in my old WRX.
Since I got the car all put together and on the road I have put about 140 miles on it. The only code I am getting is P1446 which I got pretty much as soon as I got the engine running. Through some research I have learned that this code is because I am using an 03 ECU with an 02 harness/gas tank. Apparently the 03 ECU is looking for some sensor that was not on the 2002s.
I am running 93 octane gas. I have ran through about a half a tank and am at about 1/4 tank now, so I add some more gas this afternoon and see if that makes any difference.
Below is a link to the datalog I did on my lunchbreak. I am glad to do more logging if need be. This was from a rolling start, 1st through 5th gears, shifting at the points where the hesitation started in each gear.
https://www.dropbox.com/s/397tr8iu4jm3lca/log1.csv
I appreciate any help. I have been putting this car together for the past 10 months and this is very frustrating. Thanks in advance.
Ben
Seahawk is offline   Reply With Quote
Old 10-24-2013, 03:56 PM   #2
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
PHP Code:
                                Load    Knock                                 Mod      Mod               Mod
 RPM      MAP     MAF    TPS    Site    Count     AFR     Ign
#1     Inj#1     Ign      Fuel    Boost     MAF
psia     V      %                                deg      duty      deg       %      (OL)
  742
-9.8    1.2      0     00       00      14.8    12.2       1.0    ECU.      +0.0    ECU.      1.2
  738
-9.8    1.2      0     00       00      14.8    12.4       1.0    ECU.      +0.0    ECU.      1.2
  721
-9.8    1.2      0     00       00      14.8    13.3       1.0    ECU.      +0.0    ECU.      1.2
  686
-9.8    1.2      0     00       00      14.7    15.5       1.0    ECU.      +0.0    ECU.      1.2
  706
-9.8    1.2      0     00       00      14.8    16.6       1.0    ECU.      +0.0    ECU.      1.3
0      14.7    13       1.0    ECU
.      +0.0    ECU.      1.3
  716
-9.6    1.3      0     00       00      14.9    13.3       1.0    ECU.      +0.0    ECU.      1.2
  735
-9.6    1.3      0     00       00      15.0    12.5       1.0    ECU.      +0.0    ECU.      1.2
  734
-9.4    1.2      0     00       00      15.0    11.8       1.0    ECU.      +0.0    ECU.      1.2
  734
-9.6    1.2      0     00       00      15.1    11.4       1.0    ECU.      +0.0    ECU.      1.2
  749
-9.8    1.2      0     00       00      15.0    11.7       1.0    ECU.      +0.0    ECU.      1.2
  746
-9.8    1.2      0     00       00      15.1    11.6       1.0    ECU.      +0.0    ECU.      1.2
  735
-9.8    1.2      0     00       00      15.0    11.9       1.0    ECU.      +0.0    ECU.      1.2
  733
-10    1.2      0     00       00      14.8    12.6       1.0    ECU.      +0.0    ECU.      1.2
  736
-10    1.2      0     00       00      14.7    13.1       1.0    ECU.      +0.0    ECU.      1.2
  731
-10    1.2      0     00       00      14.8    11.8       1.0    ECU.      +0.0    ECU.      1.2
  707
-9.8    1.5      0     00       00      14.9    11.6       0.0    ECU.      +0.0    ECU.      1.4
 1004
-8.7    2.2     15     00       00      14.7    15.9      13.0    ECU.      +0.0    ECU.      2.1
 1635
-7.1    1.4      0     00       00      rich    10.3       4.0    ECU.      +0.0    ECU.      1.3
 1454
-6.7    1.6      1     00       00      15.4    21.8       3.0    ECU.      +0.0    ECU.      1.8
 1259
-6.3    1.9      3     00       00      13.3    25.5       3.0    ECU.      +0.0    ECU.      1.9
 1216
-6.3    1.9      2     00       00      17.8    19.3       4.0    ECU.      +0.0    ECU.      1.9
 1423
-6.7    1.9      3     00       00      14.9    21.6       4.0    ECU.      +0.0    ECU.      1.9
 1573
-5.9    1.9      3     00       00      15.4    24.5       5.0    ECU.      +0.0    ECU.      1.9
 1567
-5.5    1.9      3     00       00      15.0    26.1       5.0    ECU.      +0.0    ECU.      1.9
 1514
-5.7    1.9      3     00       00      14.1    25.1       5.0    ECU.      +0.0    ECU.      1.9
 1408
-5.7    2      3     00       00      14.2    23.1       6.0    ECU.      +0.0    ECU.      1.9
 1242
-5.7    1.9      3     00       00      13.4    20.6       5.0    ECU.      +0.0    ECU.      1.9
 1443
-5.3    1.9      3     00       00      12.9    19.6       5.0    ECU.      +0.0    ECU.      1.9
 1508
-5.1    1.9      3     00       00      rich    23.9       5.0    ECU.      +0.0    ECU.      1.9
 1713
-5.1    2      4     00       00      12.6    26.6       5.0    ECU.      +0.0    ECU.      2
 1800
-5.3    2      4     00       00      13.4    27.6       5.0    ECU.      +0.0    ECU.      2
 1947
-5.5    2.2      7     00       00      13.8    30.3       6.0    ECU.      +0.0    ECU.      2.2
 2104
-5.1    2.2      9     00       00      15.1    31.6       7.0    ECU.      +0.0    ECU.      2.2
 2275
-4.9    2.2      9     00       00      15.7    33      15.0    ECU.      +0.0    ECU.      2.3
 2470
-4.0    2.4     14     00       00      15.0    29.8      11.0    ECU.      +0.0    ECU.      2.4
 2664
-3.2    2.5     15     00       00      13.0    29.5      14.0    ECU.      +0.0    ECU.      2.5
 2896
-2.8    2.6     15     00       00      13.1    29.4      15.0    ECU.      +0.0    ECU.      2.6
 3156
-2.4    2.7     22     00       00      13.8    27.9      19.0    ECU.      +0.0    ECU.      2.9
 3505
-1.0    3     57     00       00      14.4    26      26.0    ECU.      +0.0    300    3.1
 3792
+0.8    3.3    103     20       00      rich    20      39.0    18.2     +0.5    300    3.4
 4284
+3.7    3.6    103     40       00      rich    13.8      60.0    20.4     +0.9    300    3.7
 4681
+7.8    3.9    102     60       00      14.8    13.1      87.0    17.8     +2.3    300    4
 4714
+9.6    3.5    103     70       00      lean    15.4      63.0    19.8     +2.3    300    3.7
 4629
+8.8    2.1      0     00       00      24.5    11.3      14.0    ECU.      +0.0    LCM.      2
 4208
+4.1    2      0     00       00      24.2    11.2      11.0    ECU.      +0.0    LCM.      2.1
 3930
-1.8    2.1      3     00       00      24.5    11.7      26.0    ECU.      +0.0    LCM.      3.1
 3646
-4.0    3.1     63     10       00      23.7    25.8      29.0    18     +0.6    300    3.1
 3138
-3.2    3.2    103     20       00      rich    17.1      33.0    17     +0.6    300    3.2
 3159
+1.1    3.1    103     40       00      rich    14.3      35.0    17     +1.8    300    3.3
 3205
+5.7    3.3    103     50       00      rich    13.2      41.0    16     +2.5    300    3.4
 3408
+8.4    3.4    103     60       00      rich    10.8      52.0    16     +3.6    300    3.5
 3667    10.6    3.6    103     70       00      rich
+7.8      66.0    15     +3.8    300    3.8
 3813    12.5    3.7    103     80       00      rich
+9.6      75.0    14.8     +3.7    300    3.8
 4050    13.9    3.8    103     80       00      13.1    11.1      79.0    16.2
+3.3    300    3.9
 4301    14.9    3.8    103     80       00      12.2    11.2      85.0    17
+2.9    300    3.9
 4409    15.7    3.9    102     90       00      15.2    10.4      90.0    17
+3.0    300    4
 4528    15.7    3.9    103     90       00      23.2    11.2      94.0    18.4
+2.8    300    4
 4755    15.5    3.9    103     80       00      20.6    11.2      98.0    20.2
+2.0    300    4
 4694    14.7    3.6    103     70       00      lean    14.4      74.0    20.4
+0.7    300    3.8
 4782    13.3    3.8     84     70       00      24.5    16.4      72.0    ECU
.      +1.5    LCM.      2.3
 4504
+8.2    2      0     00       00      24.5    11.1      11.0    ECU.      +0.0    LCM.      2.1
 4198
+2.3    2.1      0     00       00      lean    11.3      11.0    ECU.      +0.0    LCM.      2.1
 3871
-3.4    2.1      0     00       00      24.5    11.6      47.0    ECU.      +0.0    LCM.      3
 3671
-5.9    3.1     95     10       00      24.5    25.7      29.0    18     +0.6    300    3.1
 3508
-3.4    3.1    103     20       00      rich    20.9      34.0    17     +0.6    300    3.3
 3501
+1.1    3.4    103     40       00      rich    14.6      43.0    17     +1.7    300    3.5
 3588
+6.2    3.6    103     60       00      rich    11.6      59.0    16     +3.4    300    3.7
 3711
+9.6    3.7    103     70       00      rich     +9.3      71.0    15     +3.8    300    3.9
 3805    12.9    3.7    103     90       00      15.3    10.4      76.0    14.4
+3.8    300    3.9
 3940    15.1    3.8    103     90       00      15.3    11.7      78.0    15.4
+3.7    300    3.9
 4006    16.4    3.8    103     90       00      17.1    12.4      79.0    16.3
+3.5    300    3.9
 4156    17    3.8    103     90       00      15.3    12      82.0    16.6
+3.3    300    3.9
 4214    17    3.8    103     90       00      17.0    11.6      82.0    16.6
+3.3    300    3.9
 4251    15.9    3.4    103     80       00      lean    15.8      59.0    16.9
+2.9    300    3.6
 4317    14.9    3.6    103     70       00      24.2    13.9      74.0    17
+2.9    300    3.8
 4284    14.1    3.8     73     70       00      13.3    11.8      80.0    ECU
.      +2.9    LCM.      2.3
 3871
+9.2    2      0     00       00      24.5    11.3       7.0    ECU.      +0.0    LCM.      2.1
 3646
+3.9    2.1      0     00       00      lean    11.4       7.0    ECU.      +0.0    ECU.      2.1
 3336
-1.0    2.1      0     00       00      lean    11.5       7.0    ECU.      +0.0    ECU.      2.1
 3486
-4.9    3     69     10       00      24.2    23.4      24.0    18     +0.6    300    3
 3075
-3.2    3.2    103     10       00      12.1    20.3      29.0    18     +0.6    300    3.1
 3162
+0.2    3.1    103     30       00      rich    16      34.0    17     +1.5    300    3.2
 3177
+4.5    3.2    103     50       00      rich    13.7      40.0    16     +2.5    300    3.4
 3177
+7.8    3.3    103     60       00      rich    12.1      47.0    16     +3.8    300    3.5
 3267    10.6    3.5    103     70       00      rich
+9.1      55.0    15     +4.3    300    3.7
 3330    12.9    3.5    103     80       00      rich
+8.8      59.0    14     +4.4    300    3.7
 3401    14.5    3.5    103     90       00      rich
+8.8      61.0    14     +4.5    300    3.8
 3384    15.9    3.6    103     90       00      rich
+9.5      63.0    14     +4.3    300    3.7
 3443    16.6    3.6    103     90       00      rich
+9.4      64.0    14     +4.1    300    3.7
 3505    17.2    3.6    103     90       00      rich
+9.5      65.0    14     +4.0    300    3.7
 3516    17.6    3.6    103    100       00      15.3
+9.4      67.0    14     +4.0    300    3.8
 3538    17.6    3.6    103     90       00      17.8
+9.0      68.0    14     +4.0    300    3.7
 3534    17.4    3.7    103     90       00      19.4
+8.8      69.0    14     +3.9    300    3.8
 3699    17.4    3.7    103     90       00      18.0
+9.7      72.0    14     +3.9    300    3.9
 3753    17.2    3.7    103     90       00      15.2
+9.7      73.0    14     +3.9    300    3.8
 3753    17.2    3.7    103     90       00      17.5    10.8      74.0    14
+3.8    300    3.9
 3827    17.6    3.7    103     90       00      15.2    10.5      75.0    14.4
+3.8    300    3.8
 3875    17.4    3.8    103     90       00      19.7    11.6      76.0    15
+3.8    300    3.9
 3862    17.4    3.8    103     90       00      18.6    11.6      76.0    15.4
+3.7    300    3.9
 3912    17.4    3.7    103     90       00      19.9    12.3      77.0    15.2
+3.7    300    3.9
 3954    17.6    3.8    103    100       00      18.0    12.9      78.0    15.8
+3.7    300    3.9
 4020    17.4    3.8    103     90       00      15.7    12.9      78.0    16
+3.6    300    4
 4035    17.8    3.8    103     90       00      19.2    13.1      80.0    16
+3.5    300    3.9
 4074    17.6    3.8    103     90       00      20.1    12.7      80.0    16.4
+3.6    300    3.9
 4151    16.8    3.8    103     90       00      18.0    13.1      81.0    16.2
+3.3    300    4
 4140    16.8    3.9    103     90       00      24.0    13.2      82.0    ECU
.      +3.3    300    3.9
 4020    13.9    1.8      0     00       00      14.4    11.4      16.0    ECU
.      +0.0    LCM.      1.9
 3736
+8.2    2      0     00       00      21.4    11.3       1.0    ECU.      +0.0    LCM.      2.1
 3479
+2.1    2.1      0     00       00      lean    11.5       1.0    ECU.      +0.0    ECU.      2.1
 3177
-4.0    2.1      0     00       00      lean    11.7       1.0    ECU.      +0.0    ECU.      2.1
 2916
-7.7    2      0     00       00      lean    11.8       1.0    ECU.      +0.0    ECU.      2
 3049
-8.1    2      0     00       00      lean    11.8       1.0    ECU.      +0.0    ECU.      2
 2989
-8.3    2      0     00       00      lean    11.6       1.0    ECU.      +0.0    ECU.      1.9
 2973
-8.9    1.8      0     00       00      lean    11.7       1.0    ECU.      +0.0    ECU.      1.8
 3013
-9.8    1.8      0     00       00      lean    11.7       1.0    ECU.      +0.0    ECU.      1.7
 2947
-10.4    1.7      0     00       00      lean    11.7       1.0    ECU.      +0.0    ECU.      1.6
 2931
-11    1.6      0     00       00      lean    11.8       1.0    ECU.      +0.0    ECU.      1.6
 2936
-11.2    1.5      0     00       00      lean    11.6       1.0    ECU.      +0.0    ECU.      1.5
 2931
-11.6    1.4      0     00       00      lean    11.7       1.0    ECU.      +0.0    ECU.      1.4
 2936
-12    1.3      0     00       00      24.5    11.6       1.0    ECU.      +0.0    ECU.      1.4
 2517
-10.8    1.8      1     00       00      13.3    31.5       5.0    ECU.      +0.0    ECU.      1.8
 2519
-10.8    1.8      1     00       00      14.0    31.9       5.0    ECU.      +0.0    ECU.      1.8
 2500
-10.8    1.7      1     00       00      13.4    30.4       5.0    ECU.      +0.0    ECU.      1.7
 2491
-11    1.8      1     00       00      13.3    30.4       4.0    ECU.      +0.0    ECU.      1.8
 2529
-11    1.8      1     00       00      14.1    31.6       5.0    ECU.      +0.0    ECU.      1.8
 2491
-11    1.8      1     00       00      13.7    32.2       5.0    ECU.      +0.0    ECU.      1.8
 2470
-11    1.7      1     00       00      13.5    31.5       5.0    ECU.      +0.0    ECU.      1.8
 2529
-10.8    1.8      1     00       00      13.8    32.2       5.0    ECU.      +0.0    ECU.      1.8
 2500
-10.8    1.8      1     00       00      13.9    33.6       5.0    ECU.      +0.0    ECU.      1.8
 2513
-10.6    1.9      2     00       00      13.8    34.2       5.0    ECU.      +0.0    ECU.      1.9
 2544
-10.4    1.9      2     00       00      14.1    36       6.0    ECU.      +0.0    ECU.      1.9
 2564
-10.2    1.9      3     00       00      13.8    37.5       6.0    ECU.      +0.0    ECU.      1.9
 2600
-9.8    1.9      3     00       00      13.5    37.5       6.0    ECU.      +0.0    ECU.      1.9
 2610
-9.8    2      3     00       00      13.8    38.6       6.0    ECU.      +0.0    ECU.      2
 2718
-9.4    2.2      7     00       00      13.3    35.7      10.0    ECU.      +0.0    ECU.      2.3
 2815
-8.3    2.4     13     00       00      14.1    33.3      30.0    ECU.      +0.0    ECU.      2.6
 3046
-6.5    2.7     23     00       00      14.1    32.1      18.0    ECU.      +0.0    ECU.      2.8
 3297
-3.8    3     49     00       00      12.4    29.3      22.0    ECU.      +0.0    300    3
 3658
-0.8    3.2     92     20       00      13.7    23.2      87.0    17     +0.6    300    3.3
 4060
+2.5    3.6    103     40       00      13.5    16.9      60.0    19.4     +1.1    300    3.7
 4224
+6.4    3.9    103     60       00      18.8    13.4      83.0    17.5     +2.8    300    3.9
 4380    10    3.8    102     80       00      24.2    13.4      76.0    17
+2.9    300    3.7
 4171
+9.6    2      0     00       00      24.5    11.3       2.0    ECU.      +0.0    LCM.      2.1
 3822
+5.9    2.1      0     00       00      lean    11.3       2.0    ECU.      +0.0    LCM.      2.1
 3588
+0.6    2.1      0     00       00      lean    11.4       2.0    ECU.      +0.0    ECU.      2.1
 3306
-5.3    2.1      0     00       00      lean    11.5       2.0    ECU.      +0.0    ECU.      2.1
 3258
-7.3    2.8     22     00       00      lean    19.6      18.0    ECU.      +0.0    ECU.      2.9
 3022
-5.3    2.9     39     00       00      16.7    24.9       7.0    ECU.      +0.0    300    3
 2770
-2.0    3     52     00       00      14.4    21.4      23.0    ECU.      +0.0    300    3
 2856
+1.7    3     96     30       00      rich     +1.7      27.0    17     +1.4    300    3.1
 2957
+5.1    3.2    103     40       00      rich    15.7      33.0    17     +1.6    300    3.2
 3038
+7.4    3.3    103     50       00      rich    13.6      43.0    16     +2.5    300    3.4
 3271
+9.4    3.5    103     60       00      rich    10.1      53.0    16     +3.8    300    3.6
 3472    11.9    3.6    103     80       00      13.4    10.7      66.0    14
+3.8    300    3.8
 3370    13.9    2.9    103     90       00      23.2    12.7      39.0    14
+3.9    300    3.8
 3749    14.7    3.7    102     80       00      17.6    10.3      58.0    ECU
.      +3.6    LCM.      3.1
 3835    11.5    2      0     00       00      15.6    11.2      41.0    ECU
.      +0.0    LCM.      2.1
 3603
+5.7    2.1      0     00       00      lean    11.4      41.0    ECU.      +0.0    ECU.      2.1
 3287
-0.6    2.1      0     00       00      24.5    11.7      41.0    ECU.      +0.0    ECU.      2.1
 3075
-5.9    2.2      6     00       00      lean    16.4      11.0    ECU.      +0.0    ECU.      2.9
 3229
-5.5    3     66     10       00      21.9    27.2      42.0    18     +0.6    300    3
 2579
-2.4    3    103     20       00      12.0    18.2      24.0    17     -0.2    300    2.9
 2690
+1.1    3    103     30       00      12.5    16.3      27.0    17     +1.0    300    3.1
 2839
+4.7    3.1    103     40       00      12.8    15.5      32.0    17     +1.4    300    3.2
 2878
+7.2    3.3    103     50       00      rich    13.3      37.0    16     +2.0    300    3.3
 2944
+9.2    3.3    103     60       00      rich    10.7      45.0    16     +3.7    300    3.5
 3135    11.3    3.4    103     70       00      rich    10.8      52.0    15
+4.3    300    3.6
 3171    13.5    3.5    103     80       00      12.6    10.8      57.0    14
+4.5    300    3.6
 3306    15.1    3.6    103     90       00      14.4    10.2      61.0    14
+4.6    300    3.8
 3422    16.6    3.7    103    100       00      17.0    10.3      65.0    14
+4.3    300    3.7
 3457    17.4    3.6    103    100       00      20.9    10.8      67.0    14
+3.9    300    3.7
 3549    17.4    3.7    103     90       00      18.6    10.4      69.0    14
+4.0    300    3.9
 3553    17.6    3.8    103     90       00      23.2    11.4      73.0    14
+4.0    300    3.9
 3691    17.4    3.8    103    100       00      22.1    11.4      75.0    14
+3.9    300    3.9
 3580    16.6    3.8    103     80       00      13.8    10.1      69.0    14
+3.8    300    3.9
 3770    14.7    2.2      0     00       00      22.4    22.1      17.0    ECU
.      +0.0    LCM.      1.8
 3749
+8.6    2      0     00       00      lean    29.5      17.0    ECU.      +0.0    ECU.      2.1
 3454
+2.3    2.1      0     00       00      lean    17.8      17.0    ECU.      +0.0    ECU.      2.1
 3183
-3.0    2.1      0     00       00      lean    11.5      17.0    ECU.      +0.0    ECU.      2.1
 2952
-7.5    2.1      0     00       00      lean    11.7      17.0    ECU.      +0.0    ECU.      2
 2827
-7.1    2.8     28     00       00      24.2     +4.5      17.0    ECU.      +0.0    ECU.      2.9
 2752
-4.7    2.9     63     10       00      16.8    25      22.0    18.2     -0.1    300    2.9
 2721
-1.8    2.9    103     20       00      12.7    21.1      23.0    17     +0.0    300    2.9
 2741
+1.9    3    103     30       00      12.8    18.2      27.0    17     +1.4    300    3
 2808
+4.9    3.1    103     40       00      rich    15.4      30.0    17     +1.3    300    3.2
 2817
+7.0    3.2    103     50       00      rich    13.8      36.0    16     +2.1    300    3.3
 2878
+9.0    3.3    103     60       00      rich    11.5      42.0    16     +3.5    300    3.4
 2891    10.6    3.4    103     70       00      rich    11      46.0    15
+4.0    300    3.5
 2968    12.5    3.4    103     80       00      rich    10.8      50.0    14
+4.4    300    3.6
 3000    14.3    3.5    103     80       00      rich    10.8      52.0    14
+4.5    300    3.6
 3066    15.5    3.5    103     90       00      rich    10.8      53.0    14
+4.6    300    3.7
 3095    16.6    3.4    103     90       00      rich    10.8      55.0    14
+4.6    300    3.6
 3156    16.8    3.5    103     90       00      rich    10.8      56.0    14
+4.6    300    3.6
 3226    17    3.5    103     90       00      12.1    10.7      58.0    14
+4.6    300    3.7
 3306    16.8    3.6    103     90       00      12.4    10.2      59.0    14
+4.6    300    3.7
 3330    16.8    3.6    103     90       00      15.6    10.1      62.0    14
+4.6    300    3.7
 3380    17    3.7    103     90       00      15.3    10.2      64.0    14
+4.1    300    3.8
 3429    17.4    3.7    101    100       00      13.8    10.8      66.0    14
+4.3    300    3.8
 3588    16.8    2.7      0     00       00      12.7    19.2      27.0    ECU
.      +0.0    ECU.      2
 3898    11.3    2      0     00       00      19.4    30.8      15.0    ECU
.      +0.0    LCM.      2.1
 3553
+4.9    2.1      0     00       00      lean    18.4      15.0    ECU.      +0.0    ECU.      2.1
 3313
-2.0    2.1      0     00       00      lean    11.5      15.0    ECU.      +0.0    ECU.      2.1
 3019
-7.3    2      0     00       00      lean    11.8      15.0    ECU.      +0.0    ECU.      2
 2791
-8.3    2      0     00       00      lean    11.7      15.0    ECU.      +0.0    ECU.      2
 2546
-8.3    2      0     00       00      lean    11.9      15.0    ECU.      +0.0    ECU.      1.9
 2294
-8.5    1.9      0     00       00      24.5    12.1      15.0    ECU.      +0.0    ECU.      1.9
 2072
-8.9    1.8      0     00       00      lean    12.1      15.0    ECU.      +0.0    ECU.      1.8
 1865
-9.1    1.7      0     00       00      lean    12.2      15.0    ECU.      +0.0    ECU.      1.7
 1638
-9.4    1.6      0     00       00      lean    12.5      15.0    ECU.      +0.0    ECU.      1.6
 1429
-9.4    1.5      0     00       00      lean    12.9      15.0    ECU.      +0.0    ECU.      1.5
 1202
-9.4    1.5      0     00       00      lean    20.7       3.0    ECU.      +0.0    ECU.      1.5
 1323
-9.6    1.3      0     00       00      lean    10.6       2.0    ECU.      +0.0    ECU.      1.3
 1228
-9.8    1.3      0     00       00      21.9    18.9       2.0    ECU.      +0.0    ECU.      1.3
 1140
-10.2    1.3      0     00       00      16.2    21       1.0    ECU.      +0.0    ECU.      1.3
 1054
-10.6    1.2      0     00       00      15.7    21       1.0    ECU.      +0.0    ECU.      1.3
  984
-10.8    1.3      0     00       00      15.3    21.3       1.0    ECU.      +0.0    ECU.      1.3
  925
-10.6    1.3      0     00       00      14.8    21.3       1.0    ECU.      +0.0    ECU.      1.2
  872
-10.4    1.2      0     00       00      14.3    21.6       1.0    ECU.      +0.0    ECU.      1.2
  798
-10.4    1.2      0     00       00      14.0    21.7       1.0    ECU.      +0.0    ECU.      1.2
  786
-10.2    1.2      0     00       00      14.1    21.7       1.0    ECU.      +0.0    ECU.      1.2
  755
-10    1.2      0     00       00      14.0    21.7       1.0    ECU.      +0.0    ECU.      1.2
  739
-9.8    1.2      0     00       00      14.0    21.8       1.0    ECU.      +0.0    ECU.      1.2
  742
-9.6    1.2      0     00       00      14.0    21.7       1.0    ECU.      +0.0    ECU.      1.2
  703
-9.6    1.1      0     00       00      13.6    21.9       1.0    ECU.      +0.0    ECU.      1.2
  677
-9.6    1.2      0     00       00      13.5    22       1.0    ECU.      +0.0    ECU.      1.2
  637
-9.4    1.2      0     00       00      13.4    22.2       1.0    ECU.      +0.0    ECU.      1.2
  668
-9.4    1.2      0     00       00      13.5    21.7       1.0    ECU.      +0.0    ECU.      1.3
  717
-8.9    1.3      0     00       00      13.4    21.2       1.0    ECU.      +0.0    ECU.      1.2
  741
-8.7    1.2      0     00       00      13.6    12.2       1.0    ECU.      +0.0    ECU.      1.2
  737
-8.5    1.2      0     00       00      13.9    10.9       1.0    ECU.      +0.0    ECU.      1.2
  750
-8.5    1.2      0     00       00      14.1    12.5       1.0    ECU.      +0.0    ECU.      1.2
  751
-8.9    1.2      0     00       00      14.1    13.4       1.0    ECU.      +0.0    ECU.      1.3
  715
-8.9    1.2      0     00       00      14.5    13.7       1.0    ECU.      +0.0    ECU.      1.3
  716
-9.1    1.3      0     00       00      14.6    14.1       1.0    ECU.      +0.0    ECU.      1.2
Old 10-24-2013, 05:09 PM   #3
art@grimmspeed
Member#: 301037
2004 Forester XT
That log is impossible to read. Can you load it into a Google spreadsheet or something similar so we can see what value goes where?
art@grimmspeed is offline   Reply With Quote
Old 10-24-2013, 07:26 PM   #4
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Here is the file on Google Docs:
https://drive.google.com/file/d/0B9W...it?usp=sharing
Also, I talked to the guy I got the tank from and he swapped the fuel pumps before I got the tank, so the fuel pump in my 94 actually is the same one from my old WRX.
For what it's worth, the story of my swap is basically this: I sold my car to a guy who wrecked his, then bought back my engine, trans, and other stuff. He had an 02 that had a V7 engine in it, so he swapped his engine in my old car, then I got my old engine/etc back along with his shell so I could get all the parts I needed for my swap. That's why some of the stuff is from my old car and some from his old shell. Both cars worked fine before all of the swapping.
Old 10-25-2013, 06:12 AM   #5
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Sorry about the bad log posts, I edited the post above to clean it up a bit.
It looks like the AFR is going way lean under boost. I'm going to clean the MAF and see if that helps, maybe it got a little dusty from sitting around the garage while working on the swap. Also I'll double check for boost leaks and pre-turbo post MAF air leaks, and also the lines to the FPR.
Old 10-25-2013, 08:31 PM   #6
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Well it must have been some bad gas or some dirt in the line. Weirdest thing happened today, I got about a half tank of ethanol free Shell 93 on the way to work today. About an hour later I took the car next door to get inspected. About mid afternoon I walked over and got the car, drove it back to my office parking lot and parked it, no problem. Then, about 2 hours later after work I started the car and even though the gas gauge was still reading about a half a tank, the low fuel warning light came on and the gas needle started going down. I thought either the inspection station siphoned my tank or I had a serious gas leak somewhere. So I drove around a big parking lot a little bit, gas needle went back to normal, and everything was fine. After that I drove to the parts store and picked up a new fuel filter. On the way home I stretched the legs a little and the hesitation was gone! I put the new fuel filter on and have been test driving it for about the past 2 hours...all is good.
Old 11-30-2013, 11:04 AM   #7
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
All is not good. The problem returned shortly after my last post, I am just getting some time to look into it.
  • I replaced the vacuum line to the FPR and zip tied both ends.
  • I don't believe I have any vacuum leaks from the intake manifold. My idle rpm and vacuum readings are good. There is no trouble building boost either.
  • I checked the fuel pressure. It was 38psi with the FPR vacuum line attached, and 45 with it disconnected.
I did some better logging this morning. I think these are all 3rd gear pulls but the first one may be a 4th gear pull.
PHP Code:
 3411
-2.2    3.3     95     20       00      rich    18.9      33.0    17     +0.6    300    3.4
 3436
+1.9    3.5    103     40       00      rich    12.9      51.0    17     +1.8    300    3.7
 3512
+7.2    3.8    103     70       00      rich    10.7      65.0    15     +3.8    300    4
 3549    11.9    4    102     90       00      rich    10.8      79.0    14
+4.0    300    4.1
 3658    15.7    3.9    103    100       00      rich    11      80.0    14
+3.9    300    4
 3720    18.2    3.9    103    100       00      rich    11.6      79.0    14
+3.7    300    4
 3770    19.6    3.9    103    100       00      rich    11.8      80.0    14.2
+3.8    300    4
 3853    19.4    4    103    100       00      rich    12.6      81.0    14.6
+3.7    300    4
 3907    19.4    3.9    102    100       00      rich    13.5      82.0    15.4
+3.8    300    4
 3954    20    3.9    102    100       00      rich    14.1      83.0    15.4
+3.7    300    4
 4065    19.4    4    103    100       00      rich    14.4      86.0    16.2
+3.6    300    4.1
 4095    19.6    4    103    100       00      rich    14.2      88.0    16.3
+3.4    300    4.1
 4161    19.2    4    103    100       00      rich    14.3      89.0    16.5
+3.3    300    4.1
 4198    18.6    4    103    100       00      rich    14.1      90.0    16.7
+3.2    300    4.1
 4246    19    4    102    100       00      12.7    14      93.0    16.9
+3.1    300    4.1
 4351    18.8    4.1    102    100       00      rich    13.6      96.0    17
+3.1    300    4.2
 4351    18.6    4.1    103    100       00      rich    13.4      98.0    17
+3.1    300    4.2
 4450    19.2    4.1     58     00       00      rich    11.7      98.0    ECU
.      +0.0    300    3.8
PHP Code:
 4214
-5.3    3.5     75     10       00      rich    20.5      46.0    21     -0.1    300    3.6
 4438
-0.2    4    103     40       00      rich    14.5      76.0    20.6     +0.9    300    4.1
 4553
+6.6    4.1    103     70       00      rich    13.9      98.0    17     +2.8    300    4.2
 4604    12.3    4.1    102    100       00      15.4    14.4      98.0    18.4
+2.9    300    4.3
 4789    15.9    4.1    102    100       00      15.1    14.7      98.0    19.1
+2.7    300    4.1
 4837    18.4    4.1    102    100       00      14.3    13.7      99.0    19.3
+1.5    300    4.2
 4982    18.2    4.2    102    100       00      15.4    14.1      98.0    19.9
+0.2    300    4.2
 5065    17.8    4.2    102     90       00      16.0    16.3     100.0    20.2
+0.0    300    4.2
 5249    17.8    4.2    103     90       00      16.8    17.4     100.0    20.8
-0.3    300    4.2
 5385    16.6    4.3    103     90       00      18.0    17.7     100.0    21
-0.3    300    4.2
 5446    16.8    4.3    103     90       00      16.1    18.8     100.0    21
-0.7    300    4.2
 5583    16.6    4.3    103     90       01      16.7    16.6     100.0    13
-0.7    300    4.2
 5555    16.4    4.3    102     90       00      17.5    17     100.0    13
-0.6    300    4.3
 5659    17    4.3    102     90       00      17.8    16.9     100.0    13
-0.4    300    4.3
PHP Code:
 3229
+3.7    3.5    103     40       00      rich    11      45.0    17     +1.8    300    3.6
 3353
+8.0    3.8    103     70       00      rich     +9.2      60.0    15     +4.3    300    3.9
 3425    11.9    3.8    103     90       00      rich    10.8      73.0    14
+4.2    300    4
 3534    15.3    3.8    102    100       00      rich    10.6      73.0    14
+4.0    300    3.9
 3683    17.6    3.9    103    100       00      rich    11.3      77.0    14
+3.9    300    4
 3853    19    4    103    100       00      rich    12.5      82.0    15
+3.8    300    4
 3930    19.6    3.9    102    100       00      12.1    13.4      83.0    15.8
+3.7    300    4
 4025    19.4    3.9    102    100       00      rich    14.2      87.0    16.1
+3.6    300    4.1
 4079    19.4    4    103    100       00      12.4    13.9      89.0    16.7
+3.3    300    4.1
 4246    19.4    4    102    100       00      14.0    13.6      94.0    17
+3.1    300    4.2
 4391    19.2    4.1    102    100       00      13.4    13.1      98.0    17
+3.1    300    4.2
 4535    19.2    4.1    102    100       00      15.0    13.8     100.0    17.6
+3.1    300    4.2
 4547    19.2    4.1    102    100       00      15.5    13.7     100.0    18.2
+3.0    300    4.3
 4803    19.2    4.1    102    100       00      15.5    14.4     100.0    19
+2.0    300    4.2
 4844    18.6    4.1    102    100       00      18.4    14.9      99.0    19.1
+2.2    300    4.2
 4887    18.6    4.2    103    100       00      16.5    13.5      99.0    19.4
+1.0    300    4.2
 5035    18.4    4.1    103    100       00      21.9    15.2     100.0    20.3
+0.0    300    4.2
 5065    17.4    4.2    103     90       00      21.6    15.8      99.0    19.9
+0.1    300    4.2
 4997    17.4    4.2    102     90       00      lean    15.3      99.0    20.2
+0.1    300    4.2
 5216    16.4    4.2    102     90       00      22.9    17      99.0    21
-0.2    300    4.2
 5274    16.4    4.2    102     90       00      21.6    17      99.0    20.7
-0.3    300    4.2
 5224    16.6    4.2    102     90       00      22.7    16.3      99.0    21
-0.1    300    4.2
PHP Code:
 3168
-8.9    2.9     52     00       00      18.6    29      75.0    ECU.      +0.0    300    3
 3202
-5.5    3.1    103     10       00      13.4    24.4      26.0    18     +0.6    300    3.1
 3267
-1.0    3.3    103     20       00      12.0    15.8      34.0    17     +0.6    300    3.4
 3394
+3.5    3.5    103     40       00      rich     +6.9      48.0    17     +1.8    300    3.7
 3483
+7.8    3.7    103     70       00      rich     +6.5      62.0    15     +4.0    300    3.9
 3642    11.7    3.9    102     90       00      rich
+6.4      77.0    14     +4.0    300    4.1
 3724    15.3    4    103    100       00      13.5
+6.7      81.0    14     +3.7    300    4
 3875    18.6    4    103    100       00      14.4
+8.3      82.0    15.2     +3.8    300    4
 4030    19.6    3.9    102    100       00      13.8
+9.4      85.0    15.8     +3.6    300    4.1
 4095    20.2    4    103    100       00      13.5
+9.7      90.0    16.5     +3.5    300    4.1
 4214    20    4    102    100       00      13.8
+9.7      92.0    17     +3.1    300    4.1
 4357    19.2    4.1    102    100       00      15.0
+8.9      97.0    17     +3.1    300    4.2
 4474    19.2    4.1    102    100       00      15.0
+9.2      99.0    17     +3.1    300    4.2
 4585    18.8    4.1    102    100       00      18.0    10.5      99.0    18
+3.0    300    4.2
 4636    18.8    4.1    102    100       00      17.3    11.2      99.0    18.4
+2.9    300    4.3
 4810    18.8    4.1    103    100       00      18.0    11.3     100.0    19.4
+2.2    300    4.3
 4960    18.2    4.2    103     90       00      18.6    12.7     100.0    19.5
+2.1    300    4.2
 4901    18.4    4.2    102     90       00      19.9    13.4     100.0    19.8
+0.1    300    4.2
 5065    17.6    4.2    102     90       00      23.7    14.8      99.0    20.3
+0.1    300    4.2
 5120    17.4    4.2    102     90       00      23.4    15.6      99.0    20.8
+0.0    300    4.2
 5224    17.6    4.2    103    100       00      23.2    16.3      99.0    20.8
+0.1    300    4.2
 5120    17.6    4.2    102    100       00      24.2    16.2      99.0    21
-0.1    300    4.2
 5265    18.4    4.3    103    100       00      21.9    16.2     100.0    21
-0.2    300    4.2
 5350    18    4.3    103    100       00      lean    16.5     100.0    21
-0.2    300    4.2
 5420    17.6    4.3    103     90       00      24.2    18.6     100.0    21
-0.4    300    4.2
 5537    17    4.3    102     90       00      24.2    18.6     100.0    21
-0.4    300    4.3
PHP Code:
 2878
-1.6    3.1    103     20       00      12.1    19.8      27.0    17     +0.4    300    3.1
 2970
+2.3    3.3    103     30       00      12.1    13.8      33.0    17     +1.3    300    3.4
 3086
+5.3    3.4    103     50       00      rich    10.4      43.0    16     +2.5    300    3.6
 3180
+8.8    3.6    103     70       00      rich     +9.8      56.0    15     +4.3    300    3.9
 3271    12.1    3.7    103     80       00      rich
+9.6      67.0    14     +4.4    300    3.9
 3429    15.1    3.8    103    100       00      rich    11.3      73.0    14
+4.2    300    4
 3580    17.6    3.8    103    100       00      13.8    11.2      76.0    14
+3.9    300    3.9
 3720    18.6    3.8    103    100       00      13.8    11.5      77.0    14
+3.9    300    4
 3835    19    4    103    100       00      14.1    12.7      81.0    14.8
+3.8    300    4.1
 3935    19    3.9    102    100       00      14.7    13.9      85.0    15.8
+3.2    300    4
 4084    18.6    4    103    100       00      15.4    14      88.0    16.2
+3.5    300    4.1
 4120    18.8    4    103    100       00      14.9    14.2      89.0    16.8
+3.3    300    4.1
 4278    18.2    4    103    100       00      15.3    13.6      93.0    17
+3.1    300    4.1
 4415    18.2    4    103     90       00      17.6    13.5      97.0    17
+3.0    300    4.2
 4409    18.2    4.1    103    100       00      18.8    13.4      99.0    17
+2.8    300    4.2
It looks like it's starving for fuel. The UTEC doesn't log fuel pump duty cycle so I am going to have to rig a voltmeter up to read while driving. I also don't have a way to read fuel pressure while driving so I may have to order a gauge.
Any ideas? Would a wonky O2 or MAF cause this? Looks like the readings from each are consistent.
Additionally, when I first set out for the test drive before logging everything was running great at WOT, I did about three pulls a few minutes apart and it was on the third one that the bogging started again.
Old 12-03-2013, 08:51 PM   #8
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
I pulled and visually inspected the fuel pump this evening, it's the OE pump and probably the original with 180k miles on it. But, everything looked fine, as did the gas and gas tank innards. I checked the three lines and back blew the return line just to make sure that wasn't clogged.
After that, I put it all back together then topped the tank with fresh gas. All of the above issues were with the tank around 1/4 full. After I got gas I went for some test driving, and it's fine again. No issues at all, drives great.
All I can think is that the pump is on the way out. Seems unusual to be intermittent like that but maybe it's getting too hot when it was at 100% duty cycle with only 1/4 tank of gas.
Old 12-08-2013, 01:52 PM   #9
George77
Member#: 375617
2000 IMPREZA GT...
BLUE
Default fuel pump
How about fuel pressure?
George77 is offline   Reply With Quote
Old 12-08-2013, 02:26 PM   #10
rocketperson7
Member#: 283968
MBP
fwiw, logging afr in boost is useless with the stock sensor/sensor location
you need a wideband, or at least move the stock sensor to somewhere post turbo, but pre-cats if there are any in your downpipe
