Old 12-03-2013, 11:55 PM   #1
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
Default Tolerance for difference in treadwear
it's that time of year again, the Blizzaks are going back on the wrx in a couple weeks. one tire developed a bulge last winter, but since they're a relatively new set of tires, I only replaced the bulged one. the new tire arrived via tirerack today, and I measured its circumference vs. the other three (used) tires.
the brand new one has a circumference of 78.0 inches, while the other three are all either 77 3/8 or 77 5/8 inches. should I have the new one shaved down or is it within our cars' tolerance for tread depth difference?
Punk In Drublic is offline   Reply With Quote
Old 12-05-2013, 12:38 AM   #2
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
I believe the tolerance is +-3/16" (.1875") circumference. I've known some people who have just increased the pressure on the "smaller" tire, but .375-.625 is quite a ways beyond that tolerance. I would try to get it shaved.
If you do put it on, put it on one of the fronts since that's an open diff.
Old 12-06-2013, 06:06 PM   #3
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
just spoke to my mechanic, who I consider to be the end-all-be all of subie knowledge, and he didn't seem to think it would be bad to just install with the other three, though he did suggust putting it in the back because of the open differential. my gut was saying put it on the front so it'll be worn down faster but he does have a good point. glad I still have a few weeks to decide...
edit: wait, so the front is an open diff. too?
Old 12-06-2013, 06:48 PM   #4
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
Front is open - rear is LSD.
MD04WRX is offline   Reply With Quote
Old 12-06-2013, 08:55 PM   #5
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
how does limited slip vs. open differential play into the choice of where the new tire should go? obviously I'd just it shaved but no one seems to know of anyone who does that around here...
Old 12-07-2013, 12:09 AM   #6
boricuamepr
Member#: 246244
2003 v7 Limited
STi Clone
Tires are most commonly measured in 32nds.
That being said, 2/32'' is the most difference I would advice; I work as a tire tech.
So if the new tire has 10/32'' new, all the other tires should be 8/32'' or more. If the difference is more, you may or may not be able to get away with it. I see it all the time where people come in with bald front tires and the rears have 6/32'' of tread. Some of the transmissions whine/grind, others have no problems. It is a hit or miss, but at your own risk over the 2/32'' mark.
Take the tires and have the tread depths measured at their lowest spots, go from there. If the difference is more, you can try it out and risk it, or sell the 3 and buy a new set of 4.
boricuamepr is offline   Reply With Quote
Old 12-07-2013, 01:40 AM   #7
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Why not just get the new one from the Tire Rack and have them shave it to match.
Bikelok is offline   Reply With Quote
Old 12-07-2013, 01:58 AM   #8
boricuamepr
Member#: 246244
2003 v7 Limited
STi Clone
Already has the new tire. Read OP
Old 12-07-2013, 12:21 PM   #9
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I don't know how I missed that! Duh!!!
He could have had the Tire Rack shave it for him.
Perhaps the OP should see how much of a pain an exchange would be. Or go to his local chapter on here and ask if there is a shop that can shave it.
Old 12-08-2013, 04:44 PM   #10
Rawpowa89
Member#: 375528
I'm too having an issue where my front two tires are bald and it's time to change them seeing as I never rotated them and also put 20 k miles without doing so. The rear tires tread are in great shape but I've heard of the tranny issues if all four are not changed at once. With the open diff in the front would it be at all possible to get away with putting two front tires on now and purchasing the rear like two weeks later? Also I don't know hat the circumference difference is either.
Rawpowa89 is offline   Reply With Quote
Old 12-08-2013, 06:00 PM   #11
sc00by4life
Member#: 97135
You should get your alignment checked.
If we're talking a difference of a couple of weeks, just do them all at the same time.
sc00by4life is online now   Reply With Quote
Old 12-13-2013, 07:02 PM   #12
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
That's a 1% difference in diameter, and thus a 1% difference in rotational speed. At 100mph your tire undergoes ~46 revs/sec. So the differential would see a 0.4 revs/sec difference. Isn't it negligible?
Bluefoton is offline   Reply With Quote
Old 12-14-2013, 02:24 PM   #13
fizzyl
Member#: 103490
06 STi
I don't really know what it mean practically, but it seems to me like almost half a revolution of the differential "differentialling" every second adds up pretty quickly.
The counterpoint is that we don't just drive our cars straight all the time so pretty much our differentials are working ALL the time...
I added no facts to the discussion
fizzyl is offline   Reply With Quote
Old 02-25-2014, 02:55 PM   #14
Garandman
Member#: 101117
2009 WRX, 06 OBW 3.0
Tiger 1050, WR250R, TW200
I need to buy a Conti ExtremeContact DW as I punched out the sidewall on one. Can they be ordered shaved from Tirerack.
Garandman is offline   Reply With Quote
Old 02-25-2014, 03:51 PM   #15
mpcc82
Member#: 229698
09 WRX Premium 4D
Pearl White
I just had one of my blizzaks punctured and is done. The current ones have about 12,000 miles on it over 3 winters... Do I have to buy 4? or can i get two and put them both together on front or back? get the one and shave it down? recommendation?
mpcc82 is offline   Reply With Quote
Old 02-25-2014, 04:23 PM   #16
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
877-522-8473 ext. 362
Old 02-26-2014, 11:11 PM   #17
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Do not I repeat do not!!!!!!!!!!! Have tire rack shave 1 tire to match tread depth..........
Have them measure OD and shave accordingly if it needs it.
I bought a new DWS tire when my tires were @7/32 left. The shop didnt even have to shave it since it was 1/5th of an inch bigger than all the others.......
If they based it on tread depth they would have shaved 4/32 of tread off.
I had custom alignment do the work. They wouldnt lie to me since I took it in for something they do and they said it didnt even need it.
Be warned! Or Risk frying your center diff!
Scoobiesdoobies is offline   Reply With Quote
Old 02-26-2014, 11:12 PM   #18
Scoobiesdoobies
Member#: 321546
2006 Wrx Limited
Bad advice unless shaving race tires. See above post!
Very strongly advised against. Even by custom alignment. Dave will tell ya.
Even tho bikelok gives some of the best suspension advise in the bay area for not being part of a performance shop!
Old 03-16-2014, 08:05 AM   #19
Garandman
Member#: 101117
Ordered two from TR and then we'll go from there. Two of the tires have minimal treadwear so it should sort out.
Old 03-17-2014, 06:44 PM   #20
flukewrx
Member#: 75081
2003 WRX
Are you saying that you replaced ONE tire and did not have it shaved? You left it at what I am assuming is 11/32" (based on you stating they would have shaved off 4/32" and the others being at 7/32")?
Having the tires at the same Tread Depth should not fry the center diff or are you saying that having ONE tire at more than 2/32" could potentially do that?
flukewrx is offline   Reply With Quote
