Old 12-03-2013, 10:37 AM   #3276
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Originally Posted by justspeed29 View Post
I am getting wedssport wheels 18x9 +36. I will also be putting on coilovers to lower car just to eliminate some of the wheel gap but will not be slamming. I also will be rolling fenders. My only question is, what is the ideal tire size for this setup? I have a '13 wrx sedan. Thanks!
Depends. Im guessing you dont want the hella flush crap. I would at least put a 255 or a 265/35/18 if you can fit it. You probably will have to run more negative camber and maybe pull your finders. You will at least have to roll your fenders completely flat.
rudymcskoody is offline   Reply With Quote
Old 12-03-2013, 09:20 PM   #3277
paulmess7
Member#: 371142
PLEASE HELP!
Want to make a 17x8.5 fit a 2013 sedan. Offset is only 35.
I know it's not ideal, but what modifications will I need to make this work.
I see a lot of people making 18's fit with 40 offset, I'm hoping 17's allow enough wiggle room for 35.
Let me know, thanks!
paulmess7 is offline   Reply With Quote
Old 12-03-2013, 09:56 PM   #3278
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Originally Posted by paulmess7 View Post
PLEASE HELP!
Depends on tires. A little roll a little camber. Should be fine
Old 12-04-2013, 01:45 AM   #3279
sc00by4life
Member#: 97135
PLEASE HELP! Want to make a 17x8.5 fit a 2013 sedan. Offset is only 35. I know it's not ideal, but what modifications will I need to make this work. I see a lot of people making 18's fit with 40 offset, I'm hoping 17's allow enough wiggle room for 35. Let me know, thanks!
Lol.
Wheel diameter means nothing in terms of fitment.
Old 12-04-2013, 06:48 PM   #3280
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Aspen White, WRB interior
Need some help although I think I figured it out
2002 Wrx
Tein Flex Coilovers
18x10 +28 offset
235/40 tire
Fenders Rolled and Pulled
The rears are slightly rubbing my coilovers. I have searched already and found that camber is not adjustable in the rear for my car so I ordered the H&R triple C camber bolts to correct the camber. Am I missing something, because I can't find a thread that mentions this issue or how they corrected it.
coqui2004miguel is offline   Reply With Quote
Old 12-05-2013, 03:34 AM   #3281
sc00by4life
Member#: 97135
Originally Posted by coqui2004miguel View Post
Need some help although I think I figured it out 2002 Wrx Tein Flex Coilovers 18x10 +28 offset 235/40 tire Fenders Rolled and Pulled The rears are slightly rubbing my coilovers. I have searched already and found that camber is not adjustable in the rear for my car so I ordered the H&R triple C camber bolts to correct the camber. Am I missing something, because I can't find a thread that mentions this issue or how they corrected it.
Spacers or bolts to dial less negative camber.
The only reason you should be having inner clearance issues with that setup is by having too much negative camber.
Old 12-05-2013, 08:54 AM   #3282
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Awesome that's what I figured. The camber bolts came in yesterday so I'll be adjusting it tonight.
Old 12-06-2013, 10:02 PM   #3283
FourWeeks
Member#: 363670
1990 Nissan 240SX
Alpine White
Wahhh
FourWeeks is offline   Reply With Quote
Old 12-06-2013, 10:53 PM   #3284
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Originally Posted by FourWeeks View Post
Hello all. Currently have an 04 WRX with a version 8 transmission and Fortune Auto 500 Series Coils. This summer, I want to get a set of TE37 SL's for autox. Would 17x8.5 +40 on 235/45 clear my brakes or rub? I already have an appointment set for fender rolling. (I don't think I'll be needing to pull my fenders with those specs)
You will be fine. In fact a 235/40 might be better and you won't even have to roll your fenders
Old 12-06-2013, 11:01 PM   #3285
FourWeeks
Member#: 363670
1990 Nissan 240SX
Alpine White
Cool thanks. I haven't heard of any STI's running a 8.5s +40 so I thought I would ask.
Ninja Edit: And by that I didn't see any in the -/+ 10 pages I went back to.
Old 12-07-2013, 01:34 PM   #3286
DARTH MAGNUS
Member#: 285248
2014 PBP GR WRX
2006 STi - SOLD :(
I know this is OT, but we need some help!
Hey guys,
Admiral1942 and I have put together a Toys 4 Tots charity meet/caravan/cruise in Orange County, CA which will take place on the 21st of this month. If anyone is interested or can think of someone who is, click on this link, please! http://forums.nasioc.com/forums/show....php?t=2566300
Please share it on other sites too if you want to help!
DARTH MAGNUS is offline   Reply With Quote
Old 12-07-2013, 09:44 PM   #3287
mephistomarius
Member#: 330895
2002 Impreza wrx
blaze yellow
I have an 02 wrx lowered on prodrive springs right now I'm running 225/40/18 on my 18x8 Prodrive pff7 et+51 wheels. Will a 235 fit without rubbing? Thanks.
mephistomarius is offline   Reply With Quote
Old 12-08-2013, 12:29 AM   #3288
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Idk how low those springs are but I ran a 235/40/18 for 2 years with vary little rubbing.
Old 12-08-2013, 12:51 AM   #3289
sc00by4life
Member#: 97135
should be ok unless you're running a lot of negative camber.
Old 12-08-2013, 04:53 PM   #3290
.bucky.
Member#: 317943
2011 STi
2011 WRX STI
ISC Coilovers
18x9.5j et35 (But I need to run a 15mm adapter)
Open for opinions on tire size.
I'm not against negative camber and stretched tires.
I understand this is a pretty aggresive setup and I was just wondering how much it would take to make it fit.
.bucky. is offline   Reply With Quote
Old 12-08-2013, 05:58 PM   #3291
sc00by4life
Member#: 97135
Originally Posted by .bucky. View Post
2011 WRX STI ISC Coilovers 18x9.5j et35 (But I need to run a 15mm adapter) Open for opinions on tire size. I'm not against negative camber and stretched tires. I understand this is a pretty aggresive setup and I was just wondering how much it would take to make it fit.
18x9.5 +35 with an additional 15mm spacers?
It's going to take more work than you are ready for. You need to find something closer to stock.
Old 12-08-2013, 11:03 PM   #3292
mike06tr
Member#: 136810
2002 Impreza
Midnight Blue??
I was thinking about getting some Diamond Racing Wheel for my 02' Bugeye. I want a 16x8 or 16x9 and would like to mount a 245/50/16
tire. What offset will I need +45?? I don't want to lower the car but
would like to fill up the wheel well a little bit more.
mike06tr is offline   Reply With Quote
Old 12-09-2013, 12:21 AM   #3293
Hushfortheturbo
Member#: 369235
2005 STI
Wanting to know what all I would need to do to fit:
2009 WRX Sedan
Wheels: 18x10 XXR 521's +25mm offset
Suspension: Coilovers
Tires: 245/40/18
Hushfortheturbo is offline   Reply With Quote
Old 12-09-2013, 12:44 AM   #3294
P3t3
Member#: 375379
2016 STi
Default 2014 WRX Hatch
I’ve browsed all the pages in this topic that might pertain to my WRX. I’m more confused about what I should do than when I first began. This is what I have:
year: 2014
model: WRX Hatch
wheel model: stock
wheel size/offset: 17x8 gunmetal gray 15 spoke alloys +53?
tire brand/model: Dunlop
tire size: 235/45R17 94W
suspension: stock
alignment: stock
fender mods: none
spacers: none
This is what I want/think I can do:
wheel model: Volk TE37SL
wheel size/offset: 18x8 +45
tire brand/model: Bridgestone RE970AS Pole Position
tire size: 235/40R18 95W
suspension: lowering springs .6” (brand?)
alignment: ?
fender mods: Really trying not to.
spacers: ?
Or
wheel model: Gram Lights 57C6
Or
wheel model: SSR GTV01
wheel size/offset: 18x8 +44
Any thoughts? I’m wanting to just have a daily driver that has an 18 inch wheel with less gap. I think my set ups will work. A shop I contacted suggested the 57C6’s in an 18x9.5. Too wide for what I’m wanting to do right?
P3t3 is offline   Reply With Quote
Old 12-09-2013, 10:16 AM   #3295
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Year: 07
Model: Wrx Wagon
Tire brand: none selected yet (possibly Bfg kdws)
Suspension: ISC coils (2 finger gap all the way around)
Sti LCAs, truhart adjustable rear lateral links
Alignment specs: still havent gotten a legit alignment, as all my suspension parts arent in quite yet.
Fender mods: not particularly looking to to roll fenders, but will eventually be going F/R sti widebody.
I can get a super good deal on a set of motegi sp10's from a buddy. I could use a new set of wheels as im sick of removing the dents from my wheels.
The wheels are 18x8 + 40. What tire size would I need to run, and would I need to atleast rolll the rear fenders?
Thanks,
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 12-09-2013, 01:03 PM   #3296
sc00by4life
Member#: 97135
Originally Posted by Hushfortheturbo View Post
Wanting to know what all I would need to do to fit: 2009 WRX Sedan Wheels: 18x10 XXR 521's +25mm offset Suspension: Coilovers Tires: 245/40/18 Thanks
What will it take to fit those? Much more than you are ready for. Find something else.
Old 12-09-2013, 02:11 PM   #3297
Hushfortheturbo
Member#: 369235
2005 STI
Thanks for the help! I have a guy that is going to roll and pull my fenders I just was wondering what else would need to be done besides that and some camber adjustment?
Old 12-09-2013, 02:18 PM   #3298
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
Originally Posted by P3t3 View Post
Ive browsed all the pages in this topic that might pertain to my WRX. Im more confused about what I should do than when I first began. This is what I have:
year: 2014
model: WRX Hatch
wheel model: stock
suspension: stock
alignment: stock
fender mods: none
spacers: none
suspension: lowering springs .6 (brand?)
alignment: ?
spacers: ?
Or
Or
Any thoughts? Im wanting to just have a daily driver that has an 18 inch wheel with less gap. I think my set ups will work. A shop I contacted suggested the 57C6s in an 18x9.5. Too wide for what Im wanting to do right?
it looks like you are going for proper fitment, in which case why get an 8.5" wheel to run a 235 tire? I would recommend a 245 or 255, or get a narrower lighter wheel for a 235. everything else looks fine
07VTRex is offline   Reply With Quote
Old 12-09-2013, 02:25 PM   #3299
P3t3
Member#: 375379
2016 STi
Thanks! I was thinking of the 235 because of the drop springs. Do you think a 245 would fit? If so that would be cool. I could go for the same width of my stock wheels (8") but wouldn't go any smaller. Also the wheel choices for an 8" wheel are not very good with my 5x100 bolt pattern.
Old 12-09-2013, 02:37 PM   #3300
sc00by4life
Member#: 97135
It's gunna take a very very heavy pull. Almost t the point of a cut and reseam.
Your little narrowbody can't handle a setup that big. Not to mention its a lot of work for cheap wheels.
And you'll need rear LCA's if you want to even step up to a 9" wheel with a sub 30 offset.
Like I said. More work than you're ready for. Move on.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
