Old 12-02-2013, 12:38 PM   #26
VTL
Member#: 345791
07 GD
Grey
any manual rental car
VTL is offline   Reply With Quote
Old 12-02-2013, 01:09 PM   #27
Abismo
Member#: 99707
2010 WRX
CWP
civic was pretty forgiving when I learned.
Abismo is offline   Reply With Quote
Old 12-02-2013, 01:53 PM   #28
point78
Member#: 344329
2008 Wrx, 6mt
I learned on a old dirt bike.
point78 is offline   Reply With Quote
Old 12-02-2013, 02:29 PM   #29
manticus
Member#: 162857
I learned on an old grain hauling truck with a double axle. For added challenge I forgot to disengage the airbrakes once in a while. When you finally stop and the smell catches up to you, you know you've done good.
manticus is offline   Reply With Quote
Old 12-02-2013, 03:40 PM   #30
SW21MR2
Member#: 60135
2005 Kona Stink-E
My suggestion is, like what many have suggested above, ANY manual transmission car you can get your hands on.
If you have the money, you can pick up an older late 80s/early 90s tuner car for around a grand or less. Romp on it for a few months, then turn around and sell it for the same amount you got it for.
SW21MR2 is offline   Reply With Quote
Old 12-02-2013, 04:57 PM   #31
jdm_wrx95
Member#: 366509
2003 wrx
blue
Originally Posted by jakedademon View Post
Ill teach you right now. Push in clutch (far left pedal). Start Car. Put car into 1st gear or reverse. Follow the directions on the shifter knob. It has a map. Push gas down to floor (far right pedal). Let clutch out fast, keep holding down gas pedal. Reap rewards. Make sure you have on seatbelt, check mirrors, much gas in tank.
And also make sure there is no kids around and what he said ^ is the easiest way
jdm_wrx95 is offline   Reply With Quote
Old 12-02-2013, 06:25 PM   #32
mziol
Member#: 254234
2015 WRX
Originally Posted by GregorcichWRX View Post
After about an hour of trial and error, you should hopefully have the basics down...
An hour? 15-20 minutes if you have a good teacher
mziol is offline   Reply With Quote
Old 12-02-2013, 06:32 PM   #33
tico556
Member#: 362086
BEWARE of anyone who says to use "an older car" or an "easier car". Because going from an "easy" manual to my 2013 WRX was night and day. The clutch is very finicky and I basically had to relearn stick on it. My WRX was my first MT car but I had been practicing on an older outback for a few weeks before buying/test driving my WRX.
It also depends on the teacher. I taught my GF in an afternoon. Took me a few days to get the hang of it (with no teacher). Its not as scary as you think. Just practice. GL its totally worth it, theres been more than a few situations where knowing manual has saved me lol
I broke it down in to 2 steps. Practice hovering the throttle (in neutral) from 1000-2500 RPMS. Once youre able to get between the two smoothly, practice getting into first without using the gas (possible if you let the clutch out very very gently). once you can do those two things well, just combine them and you know how to drive standard! The rest is getting over the fear of traffic haha.
tico556 is offline   Reply With Quote
Old 12-02-2013, 06:57 PM   #34
deadstockpomp
Member#: 292520
13 WRX STI limited
Anything anyone is willing to let you drive. Mini cooper s was the first standard i drove. Then my friends converted pt cruiser. And my first stick car i owned was an evo 8 with a 6 puck and lightweight flywheel now own an sti and the clutch is simple.
deadstockpomp is offline   Reply With Quote
Old 12-02-2013, 06:58 PM   #35
Jewbaru
Member#: 1994
2013 Impreza WRX
I learned in a 96 Ford Escort. Stalled it 6 times trying to pull away from the drive up window at the bank after pulling the cash to pay for it. I was 19, she was cute, and both she and my mom, who was in the passenger seat, were laughing their asses off.
All cars behave differently, so I would start with basically anything you can get your hands on. You'll learn as you go on that you have to adapt to the car you're driving. It's pretty common for someone used to driving X car to slip the hell out of the clutch, or stall out, in Y car.
Kudos for wanting to learn though, makes driving much more engaging and entertaining.
Jewbaru is offline   Reply With Quote
Old 12-02-2013, 07:05 PM   #36
Rex A. Peel
Member#: 85007
2005 Impreza WRX STi
Aspen White Stage 2
Something with a heavier flywheel so the revs will not move up and down as fast. This will reduce stalling out to some degree.
Rex A. Peel is offline   Reply With Quote
Old 12-02-2013, 09:22 PM   #37
imprezaowner72
Member#: 372009
2015 WRX
CWP
Thanks for all the responses the closest relative with a manual is a wrx with stage 1 tuning. I understand the mechanics of a stick its just getting in and doing it
imprezaowner72 is offline   Reply With Quote
Old 12-02-2013, 10:20 PM   #38
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Whatever you will be driving regularly. Learn on that...because every manual car is different. Even if you had been practicing all week on Car A, and get in Car B...you'll likely stall it out. Clutch engagement and gas input point is different in every car so it's hard to tell.
Simply take it slow in when learning. Start on a flat surface and let the clutch out very slow. So slow that it begins to lurch forward on it's own. If you do it slow enough you do not need to use any gas input to get it rolling forward with the clutch all the way out. Keep doing this until you have a good idea of the engagement point. Then you can start doing this with gas input to move forward quicker.
After that, then it's hill drills. Find a slight incline and let the clutch out while giving it gas input like you just got down...but do it a little faster. Learn to do it this way...not the way with the handbrake. Master this and you will be extremely comfortable with the engagement point of the clutch in your car ready for any situation.
Large apartment complexes are good places to practice this in.
MF-DIF is offline   Reply With Quote
Old 12-03-2013, 06:56 AM   #39
Mike.J
Member#: 174522
08 STI
I’m not kidding. Go to a Penske or Hertz rental and rent a 5 ton truck with manual transmission and low range. Have a friend drive it to a large empty parking lot and then you take over. Put it in low range and you can’t bog it down and it will be very forgiving. After you have mastered that, shift to high range and practice some more. When you have that down pat, move to a jeep like 4x4, again put it in low range till you master that then go to high range. Then Bob’s your uncle.
Mike.J is offline   Reply With Quote
Old 12-03-2013, 09:06 AM   #40
Abismo
Member#: 99707
2010 WRX
CWP
Originally Posted by Mike.J View Post
Iím not kidding. Go to a Penske or Hertz rental and rent a 5 ton truck with manual transmission and low range. Have a friend drive it to a large empty parking lot and then you take over. Put it in low range and you canít bog it down and it will be very forgiving. After you have mastered that, shift to high range and practice some more. When you have that down pat, move to a jeep like 4x4, again put it in low range till you master that then go to high range. Then Bobís your uncle.
or just try learning on something even remotely close to what he will be driving instead?
Old 12-03-2013, 09:18 AM   #41
Meat Supply
Member#: 137902
---- so good
it sucks....
It's a great skill to learn for sure. I learned on my dad's old 81 ford f350... Not too bad, but you had to have a pretty strong left leg.
Meat Supply is offline   Reply With Quote
Old 12-03-2013, 12:44 PM   #42
MUscooby
Member#: 86019
2002 WRX Stg 1
World Rally Blue
Originally Posted by Preludicrous View Post
Old Toyotas are good.
This. They VERY forgiving (generally speaking, of course).
MUscooby is offline   Reply With Quote
Old 12-03-2013, 01:51 PM   #43
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Besides the real world experience everyone is talking about, I think you also need to understand what is happening mechanically. Check out:
http://auto.howstuffworks.com/transmission4.htm
Many people learn stick as a bunch of "do this"; which doesn't tell you why you're doing it and you lose important info. Understanding the above teaches you why the engagement point of the clutch feels like it does and it's significance, why rev matching is important, etc.
chimchimm5 is offline   Reply With Quote
Old 12-03-2013, 01:51 PM   #44
Mike.J
Member#: 174522
08 STI
The hard part is developing the muscle memory and timing. That is easier to develop in a truck that is not as temperamental or prone to stall. There are slight differences from car to car, but that is easy once you have the muscle memory down to the point that you donít have to consciously think ďease off clutch, ease on gas, yes, yes, NO!Ē
Old 12-03-2013, 06:09 PM   #45
Daniel Dudley
Member#: 307610
2004 WRX Wagon
You really need a car you can put some time in on. It's all about stick time.
Daniel Dudley is offline   Reply With Quote
Old 12-03-2013, 06:32 PM   #46
J_mythsuby
Member#: 292113
'15 cwp rex
'12 DGM rex sold
OP said he gets the mechanics of driving stick, yet (and this is something I've had to try and deal with myself), driving hydraulic clutch versus cable clutch can be a little off putting for sure.
I'd definitely recommend learning on whatever car will be closest to what you will be driving. Stop and go traffic will definitely teach you the hard way (as well as strengthening that left calf), and try to have fun with it. Subaru's with stock clutches are very easy to learn manual on.
And remember, you're going to stall. It's going to happen. Eventually you'll learn when you're about to, and catch it to keep the engine going. Best of luck to you OP!
J_mythsuby is offline   Reply With Quote
Old 12-03-2013, 09:57 PM   #47
imprezaowner72
Member#: 372009
2015 WRX
CWP
I plan on getting a wrx evo or sti even maybe a 2.5rs if I can get my hands on one
Old 12-04-2013, 01:51 AM   #48
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
Originally Posted by Loyale93 View Post
Any car with a manual transmission.
Originally Posted by Spenk View Post
The answer is always "Miata".
Truer words have hardly ever been spoken.
Originally Posted by Jack View Post
If you have a friend with a hopelessly slipping clutch, that would be an easy way to learn the basics. Then get in a car with a good clutch and you'll at least have the mechanics down.
Try for a car with a good clutch. If you go from broken to working, you'll either burn out the good one or end up burning out every time you leave a parking space.
See above @ Miata. Just try for one with some low end torque. V6 or V8, because if you can take off without using the gas pedal, you'll learn how to better modulate the clutch. You'll feel it before it stalls and compensate better.
I vote for early-90's Chevy S-10.
AWDmonk is offline   Reply With Quote
