Old 06-01-2013, 11:33 PM   #726
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Thanks for holding his hand. I guess a detailed post, by model year, with bullet points was not clear enough
I figured this out with years ago using far less concise info from others who had done this swap well before me.
Right now, your best bet is to get an old 02-05 WRX 3.54 r160 and put the car together. Gather up the parts you need to either do a complete swap or swap in some hybrid axles.
If you go the r180/ hybrid axle route follow the advice in the above post. Driveshaft Shop was considering making some budget r180/ wrx hub axles a while ago nut i dunno whether they ever did.
aboothman is offline   Reply With Quote
Old 06-02-2013, 02:03 AM   #727
Ripper68
Member#: 150880
2006 WRX TR
World Rally Blue
Earlier today I replied to Sneaky's advice but it has not posted yet. Thanks for clearly explaining it Sneaky.
I get it now. Appreciate the hand holding thing.
Maybe it was my mistake I did not clearly explain that I already had all of the parts from a 2006 STI (except brakes/rotors) so I didn't want to toss out the components I already had like the R180 rear diff/drive shafts/etc.
Also, I wanted to keep my existing WRX R160 Hub/Brake/Wheel set up.
Super Dave's write up on the races was excellent reading and I will go that route. It looks like an easy task to make up my own hybrid axles for under $200 as opposed to around $1k for custom axles.
BTW - It was really special to log in and see your kind responses. There just aren't many kind, caring & patient people like you around anymore.
Thanks again for everyone's help. It truly will make the swap go so much easier.
Ripper68 is offline   Reply With Quote
Old 06-02-2013, 02:48 AM   #728
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
I've learned today if it ain't broke don't fix it.. Me spending nearly 6k for this stupid swap is just as much as I paid for that pos out in my driveway. I think if it goes on me then I'm just gonna get what I always wanted. A 240 or civic
SubieSnacks02 is offline   Reply With Quote
Old 06-02-2013, 02:49 AM   #729
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
I made everyone on here who helped me go nuts and think I'm retsrded. That I apologize for lol
Old 06-02-2013, 07:44 PM   #730
upuhrs19
Member#: 358257
2003 WRX
so I just did a 2005 6 speed swap in my 03 wrx now I have a p0500 speed sensor code and thus makes my car go into limp mode and wont let me go over 5k rpm and I have no speedo how can I make it so I don't need to reflash my ecu to disable the p0500 and have a speedo??? thanks
upuhrs19 is offline   Reply With Quote
Old 06-03-2013, 02:04 PM   #731
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Did you plug in the speed sensor?
If so try swapping in the speed sensor from your wrx tranny.
Old 06-03-2013, 06:37 PM   #732
upuhrs19
Member#: 358257
2003 WRX
ok ill try it I just didn't want to be missing anything like wiring or anything thanks ill let you kno how it turns out
Old 06-03-2013, 09:53 PM   #733
upuhrs19
Member#: 358257
2003 WRX
tried swapping it out and no change what else could it be???
Old 06-05-2013, 07:07 PM   #734
Ripper68
Member#: 150880
2006 WRX TR
World Rally Blue
Did you clear the code after the swap? If so, how long after clearing it did the code reappear?
If immediately, did you look into your wire harness connectors to make sure you didn't bend or break off any pins?
Also look for any wire harness damage or loose connections.
Just my 2 cents - look for the usual suspects.
Old 06-05-2013, 11:48 PM   #735
Procom Racing
Member#: 315449
Question about the information about the 2004 STi trans... We have a wrx in the shop, with a 2004 STi trans, automatic driveshaft, and r160 rear (3.54 ratio) according to the information given, that shouldn't work?? Is the information correct, because it's working here.
Procom Racing is offline   Reply With Quote
Old 06-05-2013, 11:53 PM   #736
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
How long has it been "working"? USDM parts? Unless the 2004 DCCD unit was swapped to a 2006-07 DCCD unit, which I highly doubt. That vintage USDM 6MT requires a 3.90 rear diff.
**So was this more so a post (in the tech section) to garner advertisement rather than resolve your question?**
V - ohh yea that could be a possibility too. Don't ID the rear diff mearly by the external markings.
Old 06-06-2013, 09:34 AM   #737
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Betcha they swapped the ring and pinion. Did you crack the rear diff open and confirm its ratio.
Old 06-09-2013, 01:49 AM   #738
SxVxH06
Member#: 344234
2006 Impreza Wrx TR
is it the same of the 2006 wrx tr??
SxVxH06 is offline   Reply With Quote
Old 06-10-2013, 08:23 AM   #739
SneakySh0rty
Member#: 280516
03 WRX v9 trans
pretty much, aboothman breaks it down extremely well in post #713.
SneakySh0rty is offline   Reply With Quote
Old 06-20-2013, 08:10 PM   #740
04wrxdan
Member#: 338240
2004 v39'd wrx
if my 04 wrx has female axles, could i just use wrx front male axles instead of the stubbs for the 6 speed swap??
**trying to keep my hubs**
04wrxdan is offline   Reply With Quote
Old 07-02-2013, 03:38 PM   #741
sackytar
Member#: 149262
PrimerGrey
Hey boys finally getting around to doing the rear diff and hub swap from a 05 Sti into my bugeye to match the 05 6 speed I put in.
Got a line on some 07 Sti struts front and back, I know the knuckles will mount to the struts but what I cant remember if the top hats will line right up?
I thought they would without changing the tophats!
But cant find any info on the super sticky and it doesn't really apply to us who are swapping hubs anywho.
School a brotha! So I can rock this out.
Old 07-07-2013, 01:32 PM   #742
ajd2011wrx
Member#: 312411
2011 sti
Red
hello guys I have a 09 wrx hatch. im looking to do the sti trans swap in mine very soon. Can someone please help me out with my parts list need for a 09 wrx hatch, so I can start to get everything together thanks!!
ajd2011wrx is offline   Reply With Quote
Old 07-15-2013, 04:01 PM   #743
sackytar
Member#: 149262
PrimerGrey
If anyone needs some axle stubs for this swap. I have a set less than 5000 miles literally. I am going R180 and hubs so I have no use for them.
Old 08-10-2013, 06:49 PM   #744
Ripper68
Member#: 150880
2006 WRX TR
World Rally Blue
Originally Posted by SneakySh0rty View Post
haha, I guess he didnt trust the information I gave him earlier. I even gave him the link for suberdave races. But sweet detailed layout, Hopefully people will take the time to read through these posts to limit redundant questions.
Suberdaves races WON'T work for the 2006 WRX. So much for trust and sweet detailed "but wrong" layout. Redundant questions help to clarify where some people are ASSuming they know what the facts are.
People who don't want to bother with helping others should put a cork in it and not jump down others throats. Just let patient members help out as opposed to you slamming those who need questions answered.
TO ALL who have a 2006 WRX and want to keep their rear wheels, rotors, brakes, etc. you will need hybrid axles. Suberdave can help you. Just ask him. He is great.
Old 08-15-2013, 04:50 AM   #745
GDAryder
Member#: 184753
2005 WRX
There are a variety of ways to do this depending on years of car and transmission
02-03 WRX
- 3.54 rear diff and female front axles
- Pull type clutch
EASIEST SWAP (6MT ONLY)
- 06-07 6 speed
- All Shifter components from 6MT
- Axle stubs and seals
- OR 05-07 WRX male front axles (make sure these axles have the correct spline count to fit in your hubs!!)
- Auto Impreza driveshaft
OR STI driveshaft and R180 companion flange for r160 (my preference)
- STI clutch, flywheel, pressure plate
- OR reuse your complete 5MT setup
EASY (6MT ONLY)
- 05 6 speed
- 05-07 WRX male front axles
- OR STI driveshaft and R180 companion flange for r160
STILL EASY (6MT ONLY)
- 04 6 speed
- Keep your female front axles as long as 6MT has stubs in it still. Just make sure the inner splies match as I have heard of issues with different size stubs. I prefer male axles and 05+ trans
SEMI-COMPLETE (6MT and R180)
- Any year 6MT and appropriate front Axles
- Shifter assembly
- STI Driveshaft
- R180 that matches 6MT (3.90 for 04-05 and 3.54 for 06-07)
- Legacy Spec-B rear axles with YOUR WRX Outer-CV swapped onto the the Spec-B axles (There is a thread on this, search for Spec B) (EXPENSIVE)
- SuperDave custom inner CV race and STI axles to mix/match the WRX and STI CV assembly so R180 works with WRX hubs (possible outer spline count issues
- DSS rear axles (PRICEY)
- Keep your hubs/knuckles, wheels, and brakes
COMPLETE (6MT, R180, Brembos, Wheels, etc) THIS GOES FOR 02-07 WRX
- 04-07 6MT with matching ratio R180 (3.90 for 04-05 and 3.54 for 06-07)
- Shifter assembly
- STI Driveshaft
- STI front and rear axles (Male or female fronts that match your year 6MT)
- All hubs/knuckles
- 5x114 wheels unless you get an 04 STI or JDM 5x100 setup
- Reuse your front and rear control arms, as they are the same length, unless you want the added front caster and aluminum arm upgrades.
- Brembos with rotors. Brake lines are the same, although it is a good time for an upgrade
- OR 4/2 Pots (they bolt up to STI hubs) with rear rotors that fit the larger STi e-brake assembly, and 5x114 lug pattern if you go 05-07. Look for "gravel rotors" as this is a common swap in the rally world where STIs use 15 and 16" wheels.
- Front struts for 05-07 as the bolt holes are farther apart. 04 can reuse WRX suspension IIRC. Rear struts bolt up the same.
04-05 WRX
Same as 02-03 with the following exceptions:
- Male front axles on 05, possible 04.
06-07 WRX
Same as earlier WRX with following exceptions:
- Definitely has male front axles. Perfect for use with 05-07 6MT
- 3.70 final drive, so you have to swap your rear diff regardless of the year 6MT you go with.
- Has a push type clutch. Earlier WRX and ALL STI have a pull type clutch, so you will need to swap your clutch, flywheel, pressure plate, slave cylinder and clutch line regardless which 6MT you go with.
- 06-07 6 speed
- 02-05 WRX R160 with 3.54 ratio
- Keep your front axles
- OR STI driveshaft and R180 companion flange for r160 (my preference)
- STI clutch, flywheel, pressure plate, slave cylinder and clutch line
EASY (6MT ONLY)
- 05 6 speed
- 99+ Impreza R160 with 3.90 ratio (Google SPDA Transmission Chart for a list of applicable donor vehicles)
- 04 6 speed
- Female WRX front axles as long as 6MT has stubs in it still. Just make sure the inner splies match as I have heard of issues with different size stubs. I prefer male axles and 05+ trans
- Shifter assembly
- STI Driveshaft
- Legacy Spec-B rear axles with YOUR WRX Outer-CV swapped onto the the Spec-B axles (There is a thread on this, search for Spec B) (EXPENSIVE and somewhat rare axles)
- SuperDave custom inner CV race and STI axles to mix/match the WRX and STI CV assembly so R180 works with WRX hubs (possible outer cpline count issues)
- Shifter assembly
- STI Driveshaft
- STI front and rear axles (Male or female fronts that match your year 6MT, 05-07 is easiest)
- All hubs/knuckles
- OR keep your brakes 4/2 Pots (they bolt up to STI hubs) with rear rotors that fit the larger STi e-brake assembly, and 5x114 lug pattern if you go 05-07. Look for "gravel rotors" as this is a common swap in the rally world where STIs use 15 and 16" wheels.
Saving for later reference, thanks.
GDAryder is offline   Reply With Quote
Old 11-07-2013, 07:31 PM   #746
thejaredhuang
Member#: 86206
2006 WRX Wagon
I'm not sure if it was mentioned in this thread but I think if you get an old Type 1 R160 (late 80s to mid 90s i think) you can run SVX axles which fit the R180 rear hubs.
Please tell me if I'm wrong.
thejaredhuang is offline   Reply With Quote
Old 11-07-2013, 08:09 PM   #747
sackytar
Member#: 149262
PrimerGrey
Originally Posted by thejaredhuang View Post
I'm not sure if it was mentioned in this thread but I think if you get an old Type 1 R160 (late 80s to mid 90s i think) you can run SVX axles which fit the R180 rear hubs. Please tell me if I'm wrong.
Prob kinda hard to find SVX axles though.
Old 12-04-2013, 05:51 AM   #748
Ditch64
Member#: 169903
07 WRX Limited
CGM
oooooook, so after reading 80% of this thread... I'm going to post a question because there's so much damn info, I can't process it.
I have an 07 wrx... I want to put an sti trans in it... To my understanding, if I were to pick up ANY year of sti trans (currently looking at an 09), I would need the following.
- Trans...
- sti clutch+flywheel+slave (because I have a push type, and ALL sits are pull type? this sucks because my clutch is new)
- sti shifter linkage
- R180 of the correct ratio (I plan on doing stuff that would roast an r160)
- Auto driveshaft or sti driveshaft
- 04 sti rear hubs + wheel bearings + seals to press into my wrx rear knuckles. ( I have too many sets of 5x100 wheels, and I would just like to still be able to use them) THIS IS MY MAIN CONCERN.
- 04 sti rear axles....
- Some sort of DCCD controller.
I can reuse my front axles, assuming the trans has female plugs.
I can use my clutch master cylinder.
Thank you, and awesome thread btw.
Ditch64 is offline   Reply With Quote
Old 12-04-2013, 08:52 PM   #749
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
- Trans...
If im not mistaken I heard the 07 sti swap is the most desired and easiest especially considering u have an 07. Is you lug patter 5x114? And you do not need the DCCD unless you plan to dyno it ever.
tjmmason93 is offline   Reply With Quote
Old 12-04-2013, 09:58 PM   #750
Ditch64
Member#: 169903
07 WRX Limited
CGM
My wrx is 5x100, I just bought an 09 swap today. But it doesnt come with axles or hubs, tranny and r180.
STi 6 speed into WRX swap clutch options? Bayley Subaru Conversions 13 03-30-2014 03:02 PM
FOR SALE 06 STI 6 speed transmission wrx swap!!! felixwankel88 Drivetrain 10 09-06-2009 09:26 PM
Nuts and Bolts of a 07 STi 6 Speed into an 04 WRX knakai1 Transmission (AT/MT) & Driveline 11 05-13-2008 11:04 PM
FS: MD brand new exedy twin disc for 04-06 sti 6 speed $1200 sr55stiguy Drivetrain 14 09-02-2007 04:03 PM
SPT short throw shifter for 04/05 STi 6-speed tranny JDM addict Private 'For Sale' Classifieds 28 09-17-2004 02:53 PM
