Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 12-03-2013, 10:31 AM   #1
Joaot
Member#: 211425
1999 Subaru Impreza
Default My99 impreza overboosting
Hello Guys!!
Need some help here..
My car is making overboosting, when switching gears, mainly from 3trd to 4th gear and also 5gear...
Im using, a dual dsbc Blitz controler, with 44m external wastegate and TBO td06 20g turbo (ebay one). The ecu is a apexi fc, with all supporting mods, injectors 810cc and Z32 maf etc etc..
This boost spiking or overboosting (sorry i donīt know the right way to describe) was noticed when i dynoed the car last week and in the graphs my lines came with some curves.. i assume that was because of this.. i allready talk with my tuner to remap the car, since i made some modifications from the last time he tuned it.like ewg.. boost controler etc.. the car is runing fine. Also the car made only 290hp with a 370tq ?? the guy on the dyno says my ecu isnīt good and that i should buy and motec?? (He is a EVO lover)..........
Can you guys give me a little help/opinions ?
Regards
PS: sorry for my bad english
Joaot is offline   Reply With Quote
Old 12-03-2013, 10:38 AM   #2
Joaot
Member#: 211425
1999 Subaru Impreza
PS: i tryed, all settings and ratios. Now im runing with a 60 ratio, 5gain and 1.73bar limit with -10 redution. The highest peak is from 1.88bar
Old 12-03-2013, 10:58 AM   #3
Joaot
Member#: 211425
1999 Subaru Impreza
PS2: forgot to say that i only disconected the oem valves from vaccum lines.. only the valve behind the intake manifold is contected to the throtle body
Old 12-03-2013, 06:57 PM   #4
Pjn826
Member#: 367986
2002 Subaru WRX
Could be your Wastegate Actuator. And290hp/370tq...???? Personally, I would rather have the HP and TQ Almost Close to the same. I think your car will push hard but not go fast enough.
Pjn826 is offline   Reply With Quote
Old 12-04-2013, 07:38 AM   #5
Joaot
Member#: 211425
1999 Subaru Impreza
yes is very strange this numbers.. i was not expecting this... :\ 290hp with 370tq is very strange.. The car fells very strong. i donīt know may be it needs a retune ?
No my boost problem changed.. im making boost like crazy, have tryed everything .. i can hear the wastegate open.. because i have a dumping tube to athmosphere... i tryed to shut off my blitz boost controler, tryīd with a mbc and i have allways the same overboost..
Im thinking to check if some vaccum line is leaking and the EWG doesent recive pressure from the turbo and it donesenīt open.. im a right?? .. Can you guys please give some advices?? help needed !!!!!
Old 02-26-2014, 11:27 AM   #6
Joaot
Member#: 211425
1999 Subaru Impreza
