Old 11-29-2013, 03:06 AM   #1
rsdog
Member#: 215687
2002 STI
Default flashing ecu /engine light
Howdy guys
Weird problem ... well for me
I have enough tools to check engine codes etc, but the light does not stay on, it just keeps flashing the whole time, even when just turning the car on without starting it. Like I said, no error codes ?
I changed the rpm limit to 2500 rpm with ecuflash a week ago when I took the car to the panel shop for some scratches to be fixed. The reason I put the rpm limit on 2500 rpm is to prevent the clowns from taking my car for a joyride.
When I was done (setting rpm limit), I took the car to them and hit the rpm limiter to test. From there the car started doing it and hasn't stopped.
I thought it would reset itself but it did not. Green test connectors etc has been disconnected as well, so not that. Any idea ? How to test for misfire, it does sometimes feel like that ?
It is a 2001 JDM WRX STI, fully rebuild engine. Checked and fixed all codes after rebuild ... but no this
rsdog is offline   Reply With Quote
Old 11-29-2013, 03:52 AM   #2
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
flashing cel means you've got a miss fire. Its very possible one of your coil packs took a dive. You should be able to pull a code telling you which cylinder is missing, at least i was able to with my old accessport. With that info i made sure it was bad coil pack by swapping it with another cylinder, and sure enough the miss fire moved to that cylinder.
04wrxhart is offline   Reply With Quote
Old 11-29-2013, 03:57 AM   #3
rsdog
Member#: 215687
2002 STI
Hi there
Should it surely not leave an error code then?
Old 11-29-2013, 05:19 AM   #4
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
That is whats throwing me off, when I had a flashing cel it did leave an error code. Was a miss fire in cylinder 3, what ever that code was.
Old 11-29-2013, 06:52 AM   #5
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
Flashing check engine light is a misfire try scanning it and it should come up if not have a shop try scanning it
alexandern05 is offline   Reply With Quote
Old 11-29-2013, 07:30 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That's not from a misfire. Sounds like it's in test mode even though the green connectors are unplugged. Are the fans and solenoids cycling?
Not sure if your non-USDM ECU will behave the same as ours, perhaps you should contact Ecutek and ask them about it.
Mulder is offline   Reply With Quote
Old 11-29-2013, 10:22 AM   #7
Pesias
Member#: 367580
check under your dashboard. now there this one male female green plugs that need to be unplug. flashing engine light usually means that the green plug are connected. unplug them and all will be fine.
goodluck
Pesias is offline   Reply With Quote
Old 12-02-2013, 05:47 AM   #8
rsdog
Member#: 215687
2002 STI
Green plugs are not plugged in. Fans not cycling etc ...
HOWEVER
I think I might have found the problem ...
It seems like my knock sensor is over sensitive. We rebuild the engine with the best Forged goodies money can by recently and I think the forged internals creates more noise than what the sensor likes.
Plugged into the ECU again, ran some logs, noticed my AM was on 0 and not 16. So I reset the ECU, AM back on 16, but as soon as I start the engine, AM drops to 0 again and light flashes.
Will remove sensor this afternoon, add a paper washer to try and take some sensitivity off and see if AM stays on 16 and light flashing stops ...
Old 12-02-2013, 08:08 AM   #9
JonnyV2889
Member#: 197384
2006 WRX Ltd
HOWEVER
Your map has you starting with your IAM maxed?
JonnyV2889 is offline   Reply With Quote
Old 12-02-2013, 11:46 AM   #10
rsdog
Member#: 215687
2002 STI
Yes. The default AM is 8 on the JDM model and I have made mine 16, why you asking bud ?
Old 12-02-2013, 11:48 AM   #11
rsdog
Member#: 215687
2002 STI
The plot thickens ....
I have replaced the Knock sensor now as well, but it still does it where I reset the ECU, AM shows 16, but while the engine cranks and starts to AM drops to 0 ???
Engine light flashing constantly still. I guess the two problems are related ? (AM dropping to 0 and flashing ecu light)
Any help?
Old 12-03-2013, 12:15 PM   #12
danger1138
Member#: 279525
04 rex luger!
All sensors connected? Cam, crank, etc..
danger1138 is online now   Reply With Quote
Old 12-04-2013, 05:42 AM   #13
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Check the timing. They may have smacked the rev limiter a few times just trying to move it with that ridiculously low rpm limit. 4500-5000 would have kept them out of trouble. Have you flashed the original map back on?
Old 12-04-2013, 08:03 AM   #14
rsdog
Member#: 215687
2002 STI
Yep all connected. If this were not connected, you will receive a CEL code anyways.
Old 12-04-2013, 08:06 AM   #15
rsdog
Member#: 215687
2002 STI
I will check timing. I have loaded the original MAP back on yes, so Timing should be standard.
The only timing, which is one of the problems, maybe related, is the AM that is at 0.
I will reset the ECU or load original MAP back on, only switch on the car, and AM will be 16. But as soon as I crank the engine, AM drops to 0 ??
Old 12-11-2013, 05:34 AM   #16
rsdog
Member#: 215687
2002 STI
Found the problem !!
The panel beaters in their infinite wisdom connected the two small black connectors to each other, insulation taped other wires to it and hid it right up in the top under the dash ..
Mother of Donkeyballs .....
Just thought I would share
