Old 12-03-2013, 11:01 PM   #1
KornShaDoW097
Member#: 313618
2004 WRX
Default Rattling device in trunk
04 wrx
There is this box that rattles when I turn off my ignition. It's in the wall in my trunk. I'm thinking its for fuel since my turbo timer kicks in and I heat this device rattle and my AFR fluctuates for a few seconds.
Anyone know what it is?
KornShaDoW097 is offline   Reply With Quote
Old 12-04-2013, 06:37 AM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
There is a plastic vent in the trunk that is a common rattle.
Are you talking in the trunk itself, or on the underside? Have you tried looking for it?
Old 12-04-2013, 01:15 PM   #3
OldManRed04
Member#: 356635
2005 STI
WR Blue
I think you should remove the completely worthless turbo timer to start...
OldManRed04 is offline   Reply With Quote
Old 12-04-2013, 11:35 PM   #4
Andrewxxcarlson
Member#: 316415
2006 WRX
True, yet doesn't help his problem.
Old 12-05-2013, 12:12 AM   #5
OldManRed04
Member#: 356635
2005 STI
WR Blue
It's not a problem. The noise he hears is most likely the flapper on the trunk vent.
Old 12-09-2013, 07:03 AM   #6
mcmikecruz
Member#: 162177
Where the hell is that flapper ? It's been bugging me for 6 years
mcmikecruz is offline   Reply With Quote
Old 12-09-2013, 10:34 AM   #7
OldManRed04
Member#: 356635
2005 STI
WR Blue
Drivers side, behind the carpet crap below the jack. Fire up the car and let it idle. Open the trunk and you will hear it. Pull the cover off the jack and you'll see it. You can't remove it, so in not sure what your after. You want it there to equalize pressure in the cabin and for airflow.
Old 12-09-2013, 11:10 AM   #8
mcmikecruz
Member#: 162177
Yeah I hear it all the time it rattles when my subwoofer hits I don't want to remove it just find a way to dampen the sound some maybe with some Foam tape or something
Old 12-09-2013, 07:19 PM   #9
KornShaDoW097
Member#: 313618
2004 WRX
Yea I know the vent you're talking about. But it's on the passenger side In the trunk, it's a little electronic box that makes noise. Like its attempting to regulate fuel
Old 12-09-2013, 07:20 PM   #10
KornShaDoW097
Member#: 313618
2004 WRX
It's worthless? It's for oil coke prevention and warm down... Why would it be worthless?
Old 12-09-2013, 10:57 PM   #11
Andrewxxcarlson
Member#: 316415
2006 WRX
Huh? Did I say worthless? I don't recall that.
Old 12-09-2013, 11:40 PM   #12
OldManRed04
Member#: 356635
2005 STI
WR Blue
Not sure what oil "coke" and "warm down" you are referring to, but if your running a turbo timer on these cars, you clearly don't understand the system. There is no need for a turbo timer due to the design of the system.
Please, read the following and educate yourself. When your done, go remove the turbo timer and help yourself out.
http://forums.nasioc.com/forums/show...hreadid=465156
Old 12-11-2013, 02:50 AM   #13
KornShaDoW097
Member#: 313618
2004 WRX
Sorry quoted the wrong person old man said that
Old 12-11-2013, 02:57 AM   #14
KornShaDoW097
Member#: 313618
2004 WRX
My timer came with the car and was already wired so its more of a hassle to uninstall it since I never wired it in the first place. Besides it only stays on a 30sec -min anyways so it doesn't really matter. Oil coking is in the article you linked, so read it.
I guess a timer is not needed since we have water coolant lines, oh well.
My main concern is the weird noise I hear in the trunk, what is this device?
Old 12-11-2013, 10:46 AM   #15
OldManRed04
Member#: 356635
2005 STI
WR Blue
I've already stated what the device in the trunk is.
Oil cooking is not an issue with these cars due to the design of the cooling system. Water is still circulating through the turbo through convection.
Old 12-11-2013, 12:55 PM   #16
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Anyways, 30 to 60 seconds won't give you any considerable cool down on oil or water, so it's not doing anything but wasting gas.
Old 12-11-2013, 01:02 PM   #17
midwest impreza
Member#: 369017
OK Houston
we have an impreza
theres a flapper on both sides of the trunk under the side carpets. to stop the noise you just grap the rubber flap and pull it in through one of the holes so its jammed and can't flap anymore.
midwest impreza is offline   Reply With Quote
Old 12-11-2013, 09:01 PM   #18
KornShaDoW097
Member#: 313618
2004 WRX
It varies based on load or driving. 30sec-2min. It's been disabled. So no worries. It has an off button
Old 12-11-2013, 09:04 PM   #19
KornShaDoW097
Member#: 313618
2004 WRX
I'll double check but I doubt it's the flappers. I mean I literally turn the key off on a cold night and as soon as I do the noise triggers 1-2seconds after turbo timer activation.
But ok, my timer has an off button so it's off now. I still don't know what that box is though....
Old 12-13-2013, 10:44 PM   #20
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
i always had a rattle of some kind in the trunk.
I always thought it was this mini screwdriver that i dropped between the bumper a long time ago.
with i could find out what it is though. ive learned to just accept it at this point.
David Medina is offline   Reply With Quote
