View Poll Results: Which Color do you like?
Gold 285 27.56%
Hyper Silver 136 13.15%
Chronium Black (gunmetal'ish) 355 34.33%
Flat black 229 22.15%
Bronze 136 13.15%
Multiple Choice Poll. Voters: 1034. You may not vote on this poll
Old 12-03-2013, 11:18 AM   #7226
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Originally Posted by ej25_TS View Post
Xxrs with streched winters are doing great in this blizzard.
My front lip not so much...
Hahahaha the way the snow packed into the wheels looks hilarious! Clean that out fast I once had a similar experience except I left the snow over night it became ice. Let's just say I had a bad time.
Slow Scoobie is offline   Reply With Quote
Old 12-03-2013, 02:40 PM   #7227
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
I have heated underground parkung luckily
ej25_TS is offline   Reply With Quote
Old 12-03-2013, 02:49 PM   #7228
NWsoobie
Member#: 289516
ISM
Anyone peeped the new 968's? I'm digging them. 18x9 20
NWsoobie is offline   Reply With Quote
Old 12-03-2013, 03:08 PM   #7229
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Yea I like em too in the 17x9 +20 flavor. Sadly the 17x10 doesn't come in the right bolt pattern.
Old 12-03-2013, 04:32 PM   #7230
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
Originally Posted by DPARRETT85 View Post
New to the forum but have went through the entire 289 pages so I'm caught up! I own a 07 STI and it is lowered on RCE yellows. I just ordered 527s 18x8.5 +35 in Chromium with Federal SS595s 225/40/18s.
Based on the consensus I am under the impression I will Need at least a roll in the rear. However, my question for anyone that may know is can you roll the rear while leaving the STI "fender flares" on or must you remove them? And if needed to be removed what is the best way to go about that?
Thanks for reading.
Normally, you would get flamed for that question. However, i feel since you read the ENTIRE thread (because i didnt) you deserve a good answer lol. You must remove the flare piece. Plan on the plastic clips breaking, or being un usable afterwards. Its really a matter of opinion, but i hear a lot of guys just gluing those back on after the job is done. Also, you can't really use a fender roller on the rears because of them being so thick. (i forget what the piece is called) but you have to basically cut it out and then you can roll/pull the fenders. If you stick your finger up in there, you can tell its a different and thicker material. There are various methods to doing all of this, if you check out TehClap's threads/website on IWSTI.com it will help.
Supa LA is offline   Reply With Quote
Old 12-03-2013, 04:59 PM   #7231
Soobie4life
Member#: 337830
I think I'm gonna get some. :P
Soobie4life is offline   Reply With Quote
Old 12-03-2013, 05:38 PM   #7232
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
They also have some Enkei 92 lookalikes. Biggest size they come in is 17x9 tho. However, i bet they would look BALLIN on a subie.
Old 12-03-2013, 06:06 PM   #7233
NWsoobie
Member#: 289516
ISM
Me too. The machined ones are where it's at for me.
Old 12-04-2013, 12:09 AM   #7234
DPARRETT85
Member#: 355367
Ok thanks SUPA. And thanks for the lack of flaming lol
DPARRETT85 is offline   Reply With Quote
Old 12-04-2013, 01:35 AM   #7235
MisterO
Member#: 324734
2013 WRX Hatch
Alright, I've looked through about 100 pages and still cant figure out what size to get, could someone please help me out. I have a 13 wrx hatch and wanted to get xxr527 to run with stock sized tires. So far i know i need them in 17x8.25 (will have a little stretch on the stock tires?), but cant figure out what offset if i want them to sit flush. Do plan to lower it eventually but it will not be low enough to tuck.
MisterO is offline   Reply With Quote
Old 12-04-2013, 12:09 PM   #7236
NWsoobie
Member#: 289516
ISM
Go with the 35's. You will be ok.
Old 12-04-2013, 05:29 PM   #7237
KazaKun7
Member#: 363764
2009 Imnpreza WRX
Rally Blue
Hello, pretty new to the forum. I've had my '09 WRX hatchback since the beginning of August 2013.
I've read through about a quarter of the pages of this forum but have yet to find a clear and concise answer to whether the 521's will fit the WRX or not. If this could be cleared up if greatly appreciate it.
Also, running stock suspension, would any of the fenders need to be altered to accommodate the rims?
KazaKun7 is offline   Reply With Quote
Old 12-04-2013, 05:34 PM   #7238
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
Depending on offset, you should be good to go.
Old 12-04-2013, 05:37 PM   #7239
KazaKun7
Member#: 363764
2009 Imnpreza WRX
Rally Blue
So for future reference what would give me a flush look for when I eventually go lower? Would an 18x8.5 +35 get me to where I want to be?
Old 12-04-2013, 07:20 PM   #7240
MisterO
Member#: 324734
2013 WRX Hatch
For those that might want to go up in width with stock tires and wondering how much stretch it will have check out this site, it has pictures of all tire sizes on various rim widths
http://tyrestretch.com/
Old 12-04-2013, 08:45 PM   #7241
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
Yea, the +35 offset should work. That is the correct width, unless you want to modify fenders. Probably not going to be able to fit a very aggressive tire under there, still.
Old 12-05-2013, 05:55 AM   #7242
IllwaukeeNA2.5
Member#: 330830
2010 Impreza2.5i 5dr
Obsidian Black Pearl
XXR 526 on my '10 hatch. 17x9 +35, 225/45/17
IllwaukeeNA2.5 is offline   Reply With Quote
Old 12-06-2013, 12:47 PM   #7243
Silverbullet_07
Member#: 281910
xxr 530s 17x8.25 35 offset should clear front brembos without spacers? going on 07 sti i believe it has h tech springs. i want to run 235/45or 40 tire any help would be much appriciated
if not 35 if i go with a 25 offset would they poke out too much? i just want function here no stance
Silverbullet_07 is offline   Reply With Quote
Old 12-06-2013, 02:59 PM   #7244
Silverbullet_07
Member#: 281910
Originally Posted by DanSweet View Post
Good news, I got my 17x8.25 +35 530's last night and test fitted them over the GD STI Brembo's this morning. Looks like I have equal or better clearance then the stock BBS wheels.
Also realized I'm going to need new lugs, my Ray's are too fat. Any suggestions on what lugs to run? (betting this already exists in the previous 175 pages of this thread).
well after hours of searching finally found exact same setup i am going to run so glad you posted that
Old 12-07-2013, 01:28 PM   #7245
DARTH MAGNUS
Member#: 285248
2014 PBP GR WRX
2006 STi - SOLD :(
I KNOW THIS IS OT, BUT:
Hey guys,
Admiral1942 and I have put together a Toys 4 Tots charity meet/caravan/cruise in Orange County, CA which will take place on the 21st of this month. If anyone is interested or can think of someone who is, click on this link, please! http://forums.nasioc.com/forums/show....php?t=2566300
Please share it on other sites too if you want to help!
DARTH MAGNUS is offline   Reply With Quote
Old 12-08-2013, 11:25 PM   #7246
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
Changed up the color for the time being.
chlnOrSlpn? is offline   Reply With Quote
Old 12-08-2013, 11:58 PM   #7247
Soobie4life
Member#: 337830
It says "error"?
Old 12-09-2013, 12:01 AM   #7248
Soobie4life
Member#: 337830
Too lazy to check if I posted my new wheels but here they are! :P
Old 12-09-2013, 01:17 AM   #7249
13whiteguywrx
Member#: 351622
2013 Wrx
Yea you did but it's okay
13whiteguywrx is offline   Reply With Quote
Old 12-09-2013, 11:35 AM   #7250
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
It says "error"?
It's showing up for me, is it still coming up as "error?"
Enough of teh Sex threads! Remy E. LeBeau Off-Topic 18 08-19-2013 07:47 PM
teh burn thread Samuelleeogden Off-Topic 13 09-06-2005 08:28 PM
Teh Welcoming Thread.. PwNeD Texas Impreza Club Forum -- TXIC 7 10-06-2004 10:42 AM
