Old 11-24-2013, 09:00 AM   #10176
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
Originally Posted by Breezio View Post
Could get some OEM WRX wheels... 17x7 +55 with 225/45 tires.. I'm not sure how it'll look at stock height, but my opinion, about the best combination for the narrow body and no fender or camber mods is a 18x8 ~+45 with a 235/40R18 tire.
^^agreed. That's exactly what I am driving on my 2010 WRX.
I am using 18x8 +45 Work Emotion XD-9's with 235/40/18 Falkens. The gap was not as noticeable as that set up should match the STi stock set up.
I have mine dropped now with koni struts, OEM strut body and Tein springs-which fills the gap perfectly without rubbing!
I posted pics a page or two ago of my WRB WRX prior to the drop; I can't upload any pics right now from the phone app, but hope this helps
falconWRX is offline   Reply With Quote
Old 11-24-2013, 07:19 PM   #10177
Jsm93
Member#: 368551
02 Impreza rs2.5
Midnight black pearl
What you pay for them springs?
Jsm93 is offline   Reply With Quote
Old 11-24-2013, 08:58 PM   #10178
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
I paid $900 for the set up.
Old 11-25-2013, 07:09 PM   #10179
08SubbySniper
Member#: 361108
2005 STi
Any of you guys running a light weight flywheel? I'm about to order a clutch masters FX200 (stage 2) clutch and I'm debating on if I should go with a light weight flywheel or stick with a new OEM one.
08SubbySniper is offline   Reply With Quote
Old 11-25-2013, 10:31 PM   #10180
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
why are you replacing it? Is it having an issue?
Old 11-25-2013, 11:04 PM   #10181
08SubbySniper
Member#: 361108
2005 STi
My car is pushing 325hp/323tq and my OEM clutch is slipping so while I'm in there I'm wondering if I should go light weight with flywheel
Old 11-26-2013, 09:42 AM   #10182
currymaciel
Member#: 346941
2010 WRX
If you have the money to spend on a couple more hp go for it while shes torn apart
currymaciel is offline   Reply With Quote
Old 11-26-2013, 09:55 AM   #10183
08SubbySniper
Member#: 361108
2005 STi
Any recommendations that will work with clutch masters? Also I don't want to go too light iv read that causes issues with a misfire code.
Old 11-26-2013, 10:22 AM   #10184
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
I am having the squeaky clutch issue right now with the OEM clutch-on the forum it says it could be master cylinder, broken welds, clutch pedal assembly, flywheel, throw out bearing and a few other possibilities: I am having the dealer check it out for warranty issues as there is a class action lawsuit going on right now about this. So maybe do the same before messing with it and see if they will install a brand new OEM part for you and if it doesn't fly then research and invest in something different??
Old 11-26-2013, 10:49 AM   #10185
Ninowrx504
Member#: 342193
2009 Impreza wrx
2009 Subaru Impreza WRX
Mods:
-Hks super power flow filter
-Denso Iridium sparkplugs
-SPT turbo heat shield
-Uel headers
-Full exhaust 3" downpipe to midpipe
2.5" y pipe
-Greddy spectrum elite ti tip
-Stop tech Ss brakelines with motul dot 5.1 fluid
-Ebc drilled & slotted rotors
-18x7.5 +45 volk rays te37 bronze with bridgestone tires
-kyo wei lugnuts
-Hks turbo timer type 0 anniv. Edition
-Defi boost gauge
-Sti shift knob
-Ap short shifter
-Tein s tech lowering springs
-Carbon fiber hood
-Carbon fiber chin
-Carbon fiber diffuser
-Carbon fiber fenders
-Hood fastener
-Emotion coilovers
-Tomioka td05 20g turbo
-Dw 265 lph fuel pump
-Dw 750cc injectors
-Torx topmount intercooler
-Carbon fiber wing
-Aem water/methanol injection
-Tuned 350whp/370wtq
-Upgrading to brembo's soon
Ninowrx504 is offline   Reply With Quote
Old 11-26-2013, 11:31 AM   #10186
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
Edit: ^^ who makes the carbon fiber fenders??
May I also suggest a set of blast plates from Moore performance while you got the tranny out... You're getting to numbers that will start to cause the tranny case to flex, and the blast plates will help prevent this...
Let's Spool is offline   Reply With Quote
Old 11-26-2013, 12:07 PM   #10187
JuanWins
Member#: 328915
2005 STi
That diffuser. I must have it. Where did you get it from?
JuanWins is offline   Reply With Quote
Old 11-26-2013, 12:32 PM   #10188
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
^^ looks like the treble/Forman performance diffuser... But it's like $575 or something...
Old 11-26-2013, 07:23 PM   #10189
Ninowrx504
Member#: 342193
2009 Impreza wrx
I'm from the phil. just wanted to share my ride. Both my fenders and diffuser are made here. Fenders are molded from stock. I designed my own diffuser and let my friend do it for me. You also have good sedans there here's a couple of pics of the diffuser for your reference.
Old 11-26-2013, 09:52 PM   #10190
Vt_rdr
Member#: 363640
2010 WRX
That diffuser looks fantastic!
Vt_rdr is offline   Reply With Quote
Old 11-26-2013, 11:06 PM   #10191
Ninowrx504
Member#: 342193
2009 Impreza wrx
Old 11-27-2013, 04:13 AM   #10192
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Originally Posted by kpSTi View Post
Mine are great... As close to flush without any rubbing or fender rolling, under any driving condition. SSR Type-F (forged) 18x8.5 +44 offset with 245/40 18 Falkens for tires. They are available in gold, silver and flat black and weigh 17.6 lbs a piece.
still holding it down i see!! makes me wish i kept my 09_swp_wrx lol you still liking the wrx?
Gregor91 is offline   Reply With Quote
Old 11-29-2013, 11:41 PM   #10193
kpSTi
Member#: 134097
2008 WRX Sedan
Spark Silver Metallic
Yep! Still love my car!
kpSTi is offline   Reply With Quote
Old 12-01-2013, 06:21 PM   #10194
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
That's what's up man. I sold my 12 Wrx too ended up in a 370z. Completely random but I drove it and had to buy it haha anyways carry on people.
Old 12-01-2013, 07:00 PM   #10195
pyroglycerin
Member#: 234634
2009 wrx
spark silver metallic
I love my car! After dropping a built motor in. Along with some supporting goodies in it. I'll drive it until the wheels fall off.
pyroglycerin is offline   Reply With Quote
Old 12-05-2013, 08:01 AM   #10196
08SubbySniper
Member#: 361108
2005 STi
Just got some window visors off eBay installed yesterday, please excuse the dirty car!!!
Old 12-05-2013, 05:32 PM   #10197
NickDHdfc
Member#: 203250
2011 Bmw 135i
Alpine White
Roof Rack is back on
_DSC0237 by NickPollick, on Flickr
_DSC0185 by NickPollick, on Flickr
_DSC0168 by NickPollick, on Flickr
NickDHdfc is offline   Reply With Quote
Old 12-05-2013, 10:04 PM   #10198
Vt_rdr
Member#: 363640
2010 WRX
^^^ What are you running for suspension on there? Car looks great!
Old 12-05-2013, 10:39 PM   #10199
NickDHdfc
Member#: 203250
2011 Bmw 135i
Alpine White
isc n1 coilovers 8k/6k
Old 12-06-2013, 10:11 AM   #10200
Davegreyrex
Member#: 364538
2009 WRX
My Fitment:
night pics:
Davegreyrex is online now   Reply With Quote
WTB: 2008-2010 WRX/Impreza Sedan chrome trunk trim predavore Private 'Wanted' Classifieds 4 05-17-2014 10:00 PM
the BIG 2008-2010 WRX/STI thread bhhamblin Member's Car Gallery 15981 05-20-2010 12:28 PM
SOLD NY 2008-2010 WRX Sedan Rear Spoiler MINT....PICTURES ADDED wrxphantom Exterior/Styling 14 03-18-2010 10:50 AM
