Old 06-16-2003, 05:23 PM   #1
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
Default What do I have here?
Just received a used motor that came from Japan. '98 DOHC ej25. On the valve covers are raised letters that say "2.5 DOHC", or something to that effect. Compared to my original motor the intake manifold is totally different, being higher and among other diff's has the coil facing the firewall. The cams appear to have more lift, are wider all around, and look to be hydraulic as there are no shims between the cam and tappet The inner gaskets under the valve cover are shaped differently, and apparently the part #'s from the gaskets indicate that it is a Canadian motor. Obviously I'll only be using the long block from this motor and swapping all of my parts to the new engine, but I would be interested in finding out what exactly I've got. Were motors from Canada different headwise? Anybody interested in the takeoff parts from this motor?
hossak8 is offline   Reply With Quote
Old 06-16-2003, 08:43 PM   #3
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
Sorry, but I have no access to a digicam, or scanner. The motor is going into my '98 RS. I'll get part and serial #'s and try to get some info. The vertical rise on the manifold is at least 3-4" higher than the one on my stock motor. The rep at Japan Direct told my tech that the long block was all that would directly swap to my car due to sensor compatability and such. I didn't measure the cam dimensions, but the ones on the new heads have visibly beefier lobes in width and more lift. As mentioned the gaskets inside the valve cover have part #'s that indicate it was a Canadian version. All information is welcome.
Old 06-22-2003, 04:45 PM   #4
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
OK. Engine is in the RS, and running really well. Also did the Sti motor and trans mounts (DO THIS MOD!), so the car feels and sounds entirely different. This engine did come from Japan, but it's still unknown exactly what vehicle it was in prior. There is no EGR port on the motor, so the EGR port on my original intake manifold is plugged....hopefully the ECU won't notice. The new block takes up a little more space in the engine compartment, which is kind of a mystery to me; could this be a different block than was used in my USD ej25? The engine does seem to be stronger than my original, and is definetly quieter with the hydraulic lifters. Any discussion as to what the story is with what version engine this might be is welcome.
now what do we have here? azn2nr Rocky Mountains Impreza Club Forum -- RMIC 32 07-02-2009 10:09 PM
what do i have here? yashuone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-20-2009 01:12 AM
What do I have here? (seriously) Jackie Electrical & Lighting 14 06-15-2007 09:02 PM
What do I have here? hossak8 Normally Aspirated Powertrain 4 06-22-2003 09:56 PM
