Old 12-18-2013, 08:35 PM   #1
trbill2003
Member#: 322643
2012 Imprezza Tourin
Deep Cherry Pearl
Default CEL and VDC
CEL on and VDC on after block heater install. 2012 Imprezza. Subaru dealer did the work. Car runs good, coolant level is normal. Dealer says bring it in and they will switch the light off. Does this sound right? Other people have reported the same except with the cruise light on. I do not have the cruise light on, just the other two.
Ideas?
trbill2003 is offline   Reply With Quote
Old 12-19-2013, 01:57 PM   #2
trbill2003
Member#: 322643
Deep Cherry Pearl
Default CEL and VDC light on
Just came back from the dealership. Apparently some antifreeze dripped on to the O2 sensor causing the CEL to activate. This in turn causes the VDC light to activate as well. Mechanic cleaned the sensor, cleared the code and all appears to be well.
Old 12-19-2013, 02:21 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Cleaned an O2 sensor? Either they did something stupid like forgot to plug something back in or your O2 sensor is not long for this world.
Old 12-19-2013, 06:36 PM   #4
trbill2003
Member#: 322643
Deep Cherry Pearl
Default CEL and VDC
Service manager did say that if it, (the lights coming on again) happened again they would replace the sensor. So, you are probably right that it is not long for this world.
Old 12-21-2013, 06:47 PM   #5
trbill2003
Member#: 322643
Deep Cherry Pearl
After driving about 30kms the CEL and VDC lights are back on. So, back to the dealership. Does my car retain it's VDC capability even if the light is on?
Old 12-23-2013, 06:01 PM   #6
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
No, if the VDC light is on with CEL, the car is in limp mode and it is disabled. The cruise symbol should blink too, because it's also disabled.
Tha Chakal is offline   Reply With Quote
Old 12-24-2013, 09:44 AM   #7
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
I would express my disgust for their shoddy diagnostics and poor maintenance practices. Cleaning an O2 sensor is almost the dumbest thing I have ever heard. They are so sensitive that the stuff they are designed to be used in, exhaust, kills them. Who the f would think you could spill oil on one and just clean it up? Not to mention the time you waste during your holiday and the gas to take back and forth from this dick heads
