Old 12-16-2013, 02:48 AM   #1
Jackulous
Member#: 312637
2008 WRX hatch
Default weird vibration after new trans and rear diff install
hey guys. a few months ago i had to get a new transmission in my 08 wrx. i had already rebuilt the original, and it went out again....somehow lost fluid. a shop had replaced an axle not a month before this happened. anyway. bought a used trans and rear diff from a reputable friend in the subie community. well, since then it has developed a really weird and frustrating vibration. the vibration is present in first gear, but is most noticeable in second gear under strong torque. i'm only running "cobb stage 2 + SF", so i dont think i have enough hp to shift the diff that much. i recently bought some whiteline bushings (not installed yet) and am also going to get motor and trans mounts soon, as well as the sub frame bushings. can anyone think of anything else it could be? possibly something in the trans or diff? a busted pin, broken bearing? (i do not know much in this realm of cars.) any help would be appreciated. thanks.
Jackulous is offline   Reply With Quote
Old 12-21-2013, 05:28 AM   #2
Jackulous
Member#: 312637
2008 WRX hatch
seriously? no one?
Old 12-22-2013, 09:44 PM   #3
TurboTeggyBoy
Member#: 81247
2005 PSM WRX
TD04L-19T Stage 2ish
Not too familiar with what the 08+ come with for ratios but know that the 02-07 came with a few different options. Are you 100% sure that the diff/ tranny that came out are the same ratio as what went in? If you got a diff for an AT car and you have a 5sp MT they need to be compatible with each other. Good luck.
TurboTeggyBoy is offline   Reply With Quote
Old 01-02-2014, 03:56 AM   #4
Jackulous
Member#: 312637
2008 WRX hatch
Yes. I made sure before the purchase. Both trans and diff were pulled from a 2010 wrx. Codes matched.
