Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 11-10-2013, 10:40 AM   #51
thebigd1973
Member#: 339368
Originally Posted by TurboLag23 View Post
Awesome!!!
You have any problems with rubbing with that setup? Going to go ahead and guess you rolled your fenders haha. 8.75 would be a nice width to run if it's practical, because it could allow for a really wide tire (255/45 would be awesome).
I actually have not rolled the fenders yet. I had only had very little rubbing with current setup. I will be rolling them come spring time though. When I have a full car and hit a deep pothole, I rub fairly hard, and I want to eliminate that issue.
thebigd1973 is offline   Reply With Quote
Old 12-01-2013, 03:04 AM   #52
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
What offset are your wheels? I'm curious cause I have some 8.5 width wheels, but the offset is 35. I'm curious as to what width of tire I would be able to get away with.
kyletakahero is offline   Reply With Quote
Old 12-01-2013, 12:49 PM   #53
thebigd1973
Member#: 339368
XXR 527 - (Matte Black) 18x8.75" +35 wheels
BF Goodrich Comp T/A 245/45-18 Tires
Old 12-01-2013, 08:42 PM   #54
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Thank you for the fast reply!
Car looks great by the way.
Old 12-01-2013, 08:49 PM   #55
thebigd1973
Member#: 339368
No worries, and thank you. :-)
Old 12-05-2013, 06:11 PM   #56
Taylor.CK
Member#: 375108
2002 Impreza OBS
I have a 02 Impreza Outback sport what do I need to lower it?
Taylor.CK is offline   Reply With Quote
Old 12-05-2013, 10:47 PM   #57
bulldawg23
Member#: 375421
Good thread.
bulldawg23 is offline   Reply With Quote
Old 01-02-2014, 10:49 AM   #58
stillstock_02
Member#: 377168
Ronald, your subi looks boss, flash jump amazing! Any chance your in the north west, I'd love to catch you cruzin...
stillstock_02 is offline   Reply With Quote
Old 01-16-2014, 01:00 AM   #59
grimmreeper
Member#: 365929
2000 Outback
Regatta Red
can i install a k sport air bag suspension on my 2000 outback? i would want my pre-ride set about 2.5inches lower than it is now (stock) i've been looking at these setups on NASIOC and around the internet and noticed no one has bagged a legacy outback yet. is there a reason? am i going to run into any problems that would prevent me from using a bagged suspension as opposed to coil overs? thanks for any help.
grimmreeper is offline   Reply With Quote
Old 01-17-2014, 03:51 PM   #60
My74elite
Member#: 284615
2001 Outback
Maroon/Gold
My girlfriend's 2001 on 08+ Wrx racelands. Spring perches still in correct place, just spun very far into the mount. Lowered 5.75" in the front and 6" in the rear. Rear camber is -4*, front is just over 1*. Wheels and tires are 16x7 stock wrx wheels, unsure on the offset, clearly not low enough. Tire size is 205/50/16.
My74elite is offline   Reply With Quote
Old 01-17-2014, 08:57 PM   #61
grimmreeper
Member#: 365929
2000 Outback
Regatta Red
omg that OB is sick!
Old 01-19-2014, 10:59 PM   #62
grimmreeper
Member#: 365929
2000 Outback
Regatta Red
how much fabricating did you have to do in order to make 08+ wrx coils fits or did they go right in?
Old 01-19-2014, 11:17 PM   #63
joe r
Member#: 53412
2003 Outback
Black and Gold.
Rear top hats are different. Swap them for 05 to 09 legacy tap hats or pull the studs drill new holes and insert the studs back in the top hats.
joe r
joe r is offline   Reply With Quote
Old 02-04-2014, 02:05 PM   #64
SixtySplitty
Member#: 380733
Originally Posted by Sasquatch88 View Post
THAT....is sexy as ****. That red with gold wheels...impressive sir. Looks great. Needs a little low to complete it, but I dig.
Agreed....I love the look!!
SixtySplitty is offline   Reply With Quote
Old 02-04-2014, 02:10 PM   #65
SixtySplitty
Member#: 380733
Originally Posted by Ronald_Type-R View Post
Hi everyone! New on NASIOC here, and I'm just looking through all the sub-forums on here! Hoping to get to know more people on this site in the near future!
For now, here are a few pics of my 2000 Subaru Outback! I bought this car 8 months ago, and have since re-done the whole suspension, interior, wheels & tires, as well as a few performance upgrades under the hood
ENGINE
- '05 USDM EJ257 STi Ver.8 Engine Swap
- Crawford Air / Oil Separator V2
- Spearco 900cfm Weld-On Aluminum Top Mount intercooler
- DEI Gold Heat Reflective Tape
- Tial Q 50mm Blow-Off Valve
- Samco Silicone 2.4" Turbo Inlet Hose
- AEM Silicone Throttle Body Coupler
- Perrin Silicone Intercooler Elbow
- JDM STi by Samco Silicone Radiator Hoses
- Grimmspeed Port & Polished OEM Intake Manifold
- Grimmspeed Port & Polished OEM Drive-By-Wire Throttle Body
- Grimmspeed TGV Delete Kit
- Grimmspeed Phenolic 8mm Intake Manifold Spacers
- BeatRush Engine Mounts
- Injen Short Ram Intake
- APS Equal Length Exhaust Manifold
- APS Catless Uppipe
- Stromung 3" Bell-Mouth Downpipe
- iON Performance Stage 1 VF39 Turbo Upgrade (Port & Polished Factory Turbo, w/ Ceramic Coating)
- JDM Cusco Turbo Heat Shield
- Perrin Lightweight Crankshaft Pulley
- GFB Underdrive Power Steering Pump Pulley
- Komoto Racing Stainless Steel Midpipe
- Zero Sports Axleback Exhaust
- A'PEXi High-Capacity Race Aluminum Radiator
- JDM BE5 Legacy B4 S401 STi 1.3Bar Radiator Cap
- JDM BE5 Legacy B4 S401 STi Radiator Hoses
- Deatschwerks 320lph Fuel Pump
- Beatrush Radiator Cooling Plate
- Beatrush Alternator Pulley Cover
- Greddy Magnetic Drain Plug
- SYMS Aluminum Oil Cap
- SYMS Aluminum Brake Fluid Reservoir Cap
- SYMS Aluminum Clutch Fluid Reservoir Cap
TRANSMISSION
- OEM 5-speed Manual Transmission w/ JDM STi Ver.5 RA Cryo-Treated Gearset
- Cryo-Treated STi Ver.5 Shift Forks
- Quaife Cryo-Treated Front LSD
- JDM BE5 Legacy B4 S401 STi Transmission Mounts
- JDM BE5 Legacy B4 S401 STi Short Shifter Linkage
- Kartboy Short Shifter
- Kartboy Rear Shifter Stay Bushings
- Beatrush Polyurethane Shifter Bushings
- Lightweight Aluminum Race Flywheel (Unknown Brand)
- OEM STi Clutch Disc & Pressure Plate
- Beatrush Solid Aluminum Pitch Control Rod
INTERIOR
- JDM BE5 Legacy B4 S401 STi Instrument Cluster
- JDM BE5 Legacy B4 S401 STi Pedal Set
- JDM BE5 Legacy B4 S401 Aluminum Door Sills
- NRG Short Hub
- WorksBell Rapfix QRSII Steering Wheel Quick Release Kit
- ATC Rallye International Type 95 330mm Steering Wheel
- Sparco Dual External Horn Buttons
- Bride FO-Type Seat Rails & Sliders
- OMP WRC VTR Bucket Seat [Driver]
- OEM GDA STi V5 Bucket Seat [Passenger]
- Beatrush Titanium 5-speed weighted 220g Shift Knob
- Circuit Hero Shifter Extender
EXTERIOR
- JDM GDB STi V-Limited Front Lip w/ Optional Rubber Add-On Flap
- JDM BH5 Legacy Kouki Rev.D Headlights w/ HID
- JDM BH5 Legacy Kouki Rev.D Taillights
- JDM BH5 Legacy Kouki Rev.D Rear Spoiler
- JDM Pink STi Rear Emblem
- Ganador Carbon Fiber Powered Aero Mirrors
- WorksBell Carbon Fiber Hood
- JDM Zero Sports Front Grille
- Tein Hood Struts
FOOTWORK (SUSPENSION/BRAKES/CHASSIS)
- BC Racing BR-Type Short-Stroke Coilover Damper System w/ custom Swift Springs [16kg/mm Front & Rear]
- Beatrush Front Performance Bar
- Beatrush Front Strut Brace
- JDM Legacy BE5 Spec B Forged Aluminum Front Lower Control Arms
- Megan Racing Rear Upper Control Arms
- Megan Racing Rear Lower Front Control Arms
- Megan Racing Rear Lower Rear Control Arms
- Beatrush Driveshaft Carrier Hardened Bushings
- Beatrush Rear Differential Carrier
- Zero Sports 23mm Front Sway Bar
- Zero Sports 21mm Rear Sway Bar
- Whiteline Front Sway Bar Adjustable End Links
- Whiteline Front Control Arm Lower Inner Front Bushings
- Whiteline Front Control Arm Lower Inner Rear Bushings (Anti-Lift Kit)
- Cusco Rear Lower Arm Bar Stiffener Ver. II
- Whiteline Rear Sway Bar Adjustable End Links
- SuperPro Rear Trailing Arm Lower Front Bushings
- Beatrush Rear Strut Brace
- OEM WRX Front 2-Pot Brake Calipers
- Technafit Stainless Steel Brake Lines
- Axis Rear 2-pot Big Brake Kit
- ARP Extended Studs
WHEELS/TIRES
- JDM Work Meister S1R 18x9" (Glim Silver) w/ 225/40ZR18 Bridgestone Potenza RE-11 [Summer]
- JDM Work RS Extended Open Ended Anodized Red Lug Nuts
ELECTRONICS
- Cobb Tuning Access Port V2
- JDM A'PEXi Voltage Stabilizer & Ground Kit
- JDM Blitz DTT DC Turbo Timer
- Rockford Fosgate 10 Farad Hybrid Capacitor
- Pioneer AVIC-Z140BH Double Din Head Unit
- Phoenix Gold MS-2125 SQ Amplifier x2
- Focal Polyglass 165VB Component Speakers
- Focal Access 27 Twin Lux Subwoofers & Box
After I installed a JDM STi V-Limited Front Lip
Just a few nights ago, with my newly acquired personalized plates
Ronald
Hands down the best looking Outback I've ever seen. Have been contemplating selling my car, but this just made me decide to keep it!
Old 02-09-2014, 11:13 PM   #66
LossTraction
Member#: 381228
1999 Outback
Originally Posted by thebigd1973 View Post
Diggin' the stance and color combo, great looking outback!
LossTraction is offline   Reply With Quote
Old 03-24-2014, 10:27 AM   #67
Member#: 301037
2004 Forester XT
The two Outbacks above make me want to break out my wallet and troll Craigslist immediately, ha. Such a great combination of aggressive and sleeper.
-Art
art@grimmspeed is offline   Reply With Quote
Old 03-25-2014, 07:34 AM   #68
My74elite
Member#: 284615
2001 Outback
Maroon/Gold
joe r
Front top hats are different too, need to drill new holes in the strut tower. Not that hard to line up though.
Old 03-25-2014, 08:21 AM   #69
My74elite
Member#: 284615
2001 Outback
Maroon/Gold
Here's the sister to my girlfriend's '01 outback I posted a while ago. This is my '00 RWD outback with a single catted straight pipe. It's annoying, it's ugly, but my god is it fun.
https://www.youtube.com/watch?v=Rx-V...ature=youtu.be
Old 03-29-2014, 11:58 PM   #70
SubyWRX_02
Member#: 345116
I want to lower my 06 Outback LL Bean, would any coilover kit that fits a LGT work for me?
SubyWRX_02 is offline   Reply With Quote
Old 04-08-2014, 10:51 AM   #71
SPUDD
Member#: 249768
2000 outback
green
anyone know if 05-09 lgt suspension will bolt into 00-04?
SPUDD is offline   Reply With Quote
Old 04-14-2014, 02:06 PM   #72
SixSpeed5
Member#: 387740
Lots of good looking Outbacks ITT!
SixSpeed5 is offline   Reply With Quote
Old 04-25-2014, 03:10 PM   #73
BlueByYou
Member#: 33478
2005 Outback XT
Atlantic Blue/Grey
might as well throw my Outback XT into the ring here too. Just lowered with Legacy GT suspension, 07 WRX rims, low profile Avids. It's a nice clean look that appears stock.
BlueByYou is offline   Reply With Quote
Old 04-27-2014, 02:12 AM   #74
manik1770
Member#: 337460
2013 Outback ltd 3.6
GGM
Probably all the same folk that are on the LegacyGT forum have seen mine. Pretty much only suspension upgrades and wheels/tires for her.
manik1770 is offline   Reply With Quote
Old 04-30-2014, 12:41 PM   #75
Shanaru242
Member#: 344828
2007 Outback Wagon
I also like the supertones and blacked-out grill. Did you use Plasti-Dip?
Until I saw your OB, I was not a big fan of the newer gens (mine's 3rd gen). But yours looks great! Nice combo of wheels and ride height!
Shanaru242 is offline   Reply With Quote
