Old 06-16-2003, 08:18 PM   #1
CRS9
Member#: 7175
1999 Impreza 2.5RS
Question MY99 LSD swap
I would like to swap in an LSD. I have a 99RS with 5MT. I know I have a 4.11 ratio and that I need an LSD from a MY00-01 5MT. Would this be a direct drop in replacement, or would I have to worry about axles and other things. I'm looking for ease here. Thanks for any info.
CRS9 is offline   Reply With Quote
Old 06-17-2003, 11:50 PM   #2
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Bump, Im interested too.
Bobalouy is offline   Reply With Quote
Old 06-18-2003, 12:06 AM   #3
RedBrighton96
Member#: 1246
As far as I know you will also need the rear axles. The ones for the LSD rear diffs are slightly different or so I was told when I was looking for a diff for my swap.
Rob
RedBrighton96 is offline   Reply With Quote
Old 06-18-2003, 11:25 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yup Mr. brighton is correct you will need the axels ... other than that .. pretty straight forwared..
Old 06-18-2003, 03:26 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Not knowing enough about your model year think about this as a possibility.
Find an LSD with the wrong gear ratio but that will drop in directly.
Take the ring a pinion from your differential and swap it into the LSD
That way you dont have to modify the vehicle in anyway. To return it to stock just drop another 4.11 open diff. To replace axles just purchase the normal ones.
This is what I did, I got a 4.44 lsd and a spair 4.11 open diff for my legacy and mixed the parts.
ciper is offline   Reply With Quote
Old 06-18-2003, 05:01 PM   #6
phong
Member#: 10884
2002 WRX Wagon
All you need is the differential from an RS either a 2000 or 2001. Everything else should match up with no problem assuming you a have a 1999 RS. If you have a L then you will need a rear diff. from a legacy turbo and the rear axles as well because they do not match up. The other possibility is the ring and pinion swap with a different gear ratio but that may be pricey (Must be professionally done I think?), I have not researched this option.
phong is offline   Reply With Quote
Old 06-18-2003, 06:14 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Professionally done? I did it all alone with my own tools as well.
Id say you have a snowballs chance in hell to find a cheap legacy LSD. I might have one for sale soon though..... 3.9 ratio
Old 06-18-2003, 10:51 PM   #8
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
How much do used 00-01 LSD go for. New they are like $1300.
Do they really make that big of a differance? I mainly auto-x but there might be some local drift events soon .
Anthony C
Old 06-19-2003, 09:08 AM   #9
Puckaveli
Member#: 1518
00 2.5RS
I can get you one from a 2000 RS with axles for $700.
Puckaveli is offline   Reply With Quote
Old 06-19-2003, 12:33 PM   #10
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
quaife diffs can be had for around $1000, so I would look to pay around 3-400 for a my00-01...
If not, get the phantom grip...
DanzBorin is offline   Reply With Quote
Old 06-19-2003, 02:40 PM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Open diff axles are different from LSD axles. They have a different spline count. I don't have the actual spline count yet, but I should have it within a week. So, if you purchase an LSD from a 2000-2001 RS then you MUST get the axles for it as well. Axles can be had for $45 each from www.4subarusuzukikiaparts.com. The LSD itself runs for about $400 from a number of yards.
-Jon
stimpy is offline   Reply With Quote
Old 06-19-2003, 02:52 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
Im sure that is not always the case. Ill count them when I go home.
Old 06-23-2003, 11:22 PM   #13
mr2hutch
Member#: 6613
01RS v6.STi(convert)
I will be pulling mine out(01 RS 37K mi) and selling the rear LSD plus drive shafts would like to get 550 plus shiping. will be ava. mid. july. PM me if interested
Ian
mr2hutch is offline   Reply With Quote
MY99 MAF swap to a MY98 MAF FuJi K Subaru Conversions 3 06-22-2005 12:36 AM
LSD Swap ........ BossGVR4 Forester Forum 12 03-19-2003 01:31 PM
MY99 MAF swap? s Normally Aspirated Powertrain 6 09-04-2001 03:29 PM
Rear LSD swap on 99 RS RallyNavvie Normally Aspirated Powertrain 1 07-02-2001 12:13 PM
LSD swap? silverSurfer Legacy Forum 2 07-23-2000 01:22 AM
