Old 10-17-2011, 05:44 PM   #26
girodisc
Member#: 177674
Not yet. I have some other projects I need to finish before I can devote all my time to this project.
Johann @ Girodisc
girodisc is offline   Reply With Quote
Old 10-21-2011, 05:25 PM   #27
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
i like the concpet, kinda gocart/dune buggy crossover!
Matt515 is offline   Reply With Quote
Old 01-14-2012, 04:28 PM   #28
04trailsti
Member#: 179170
Ive always pondered just building a tube chassis based off the front and rear subframes. Then you can use pretty any aftermarket part. Or get crazy and use a tubular subframe as well.
04trailsti is offline   Reply With Quote
Old 01-14-2012, 04:45 PM   #29
d3v0
Member#: 225692
2015 WRX
Ariel*
d3v0 is offline   Reply With Quote
Old 01-18-2012, 01:48 PM   #30
drumchum
Member#: 286027
2008 WRX
Subscribed!
drumchum is offline   Reply With Quote
Old 01-18-2012, 03:41 PM   #31
jlitchkowski
Member#: 288316
2011 STI
subscribed
jlitchkowski is offline   Reply With Quote
Old 01-19-2012, 11:02 PM   #32
exhaust_note
Member#: 73375
AWD atom will be sick
exhaust_note is offline   Reply With Quote
Old 01-22-2012, 11:35 AM   #33
ssantoro01
Member#: 307658
the revo from traxxas is a sick platform to base the design off of. GL
ssantoro01 is offline   Reply With Quote
Old 01-27-2012, 11:15 PM   #34
Vdubtype1
Member#: 297549
Why would you not reverse the spool drive in the transmission so you can mount the engine in the rear I have seen a volkswagen bug done with a similar setup in Australia for the suspension how could you think struts for a 4000 ib car work for something quarter of its weight never mind the huge difference in lower center of gravity. Maybe look into a R1 which are all adjustable or just look into companies who sell coilovers. Very interested in the build, would not mind seeing some cad drawings
I like the idea
Vdubtype1 is offline   Reply With Quote
Old 03-03-2012, 04:20 PM   #35
drumchum
Member#: 286027
2008 WRX
Need Updates
Old 09-15-2012, 03:12 AM   #36
Holden11sti
Member#: 327226
Any NEED RALLY CAR
Any
that would be amazing. please build it.
Holden11sti is offline   Reply With Quote
Old 09-19-2012, 11:13 AM   #37
RustyHinge
Member#: 299742
2007 STI Limited#382
07 WRB STI sold 9/28/12
Interested to see this come together
RustyHinge is offline   Reply With Quote
Old 10-11-2012, 10:55 AM   #38
schastleevo
Member#: 277705
Looks interesting, how's your progress?
schastleevo is offline   Reply With Quote
Old 10-11-2012, 09:28 PM   #39
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
I've thought of doing this, but lack of funds, space, and motivation always conspire to stop me.
If you do do it the best way is using a 2wd conversion kit like the Saker and do mid engine RWD.
bushflyr is offline   Reply With Quote
Old 02-04-2013, 08:03 PM   #40
05bluesti
Member#: 251804
05 WRB STi
subscribed!!!!
05bluesti is offline   Reply With Quote
Old 07-24-2013, 02:29 PM   #41
stisubaru07
Member#: 363132
2007 Impreza STI
Any updates? Please make this happen!
stisubaru07 is offline   Reply With Quote
Old 07-26-2013, 12:22 AM   #42
Romero05STI
Member#: 363344
This is sooo badasss man
Romero05STI is offline   Reply With Quote
Old 08-07-2013, 10:18 AM   #43
mcdermotta
Member#: 351010
1998 Postal Legacy
I get the feeling this isn't happening based on the 2 year old thread with no updates?
mcdermotta is offline   Reply With Quote
Old 08-22-2013, 10:45 PM   #44
dammitmitchell
Member#: 364057
holy crap, im going to watch this one.
dammitmitchell is offline   Reply With Quote
Old 11-21-2013, 02:41 PM   #45
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Hey all. This is going to happen but I have to finish my pre-runner BATLFOZ Forester thing before I start this. I have everything drawn up. All the parts picked. Budget calculated. Just gotta finish a couple other projects ahead of it.
The whole point was to make it AWD so make it more stable and more (for lack of a better word) versatile. Change the springs and the pushrod length and put some knobby tires and you can hit the dunes... I've re-designed a lot of this going from something cheaper and using off the shelf parts to just going all out and making most of it from scratch. I changed the suspension design to utilize the same lower arm, upper arm, and knuckle to work on all four corners so save fab time and the amount of jigs I'll need to make if I decide to go for re-production. I've taking a lot of time to simplify the design because with this type of car I believe less is more. Standard bearings, coilovers, hyme joints, and bolt sizes will make it go together a lot better and if i start racing it or sell a couple to those who do it will require less spare parts and tools to work on it. Price for the first one is going to be pretty steep but once the jig and I have the list of actual material and parts it will take to re-produce it should drop about 30-40% to make the next one. Also I will have more bugs fixed by then if I need to make revisions during the build process.
I can give you a lil math though
Bugatti Veyron has 1046hp at 4100 lbs
So it has about 523hp per ton power/ weight ratio
Subreal Atom will have 450hp at about 1100 lbs
So it should have a power/ weight ratio of about 816hp per ton
Basically it will be fast.... Really Fast....
Eventually when my wrist gets better I will finish my Forester and start on this when my Garage is free. I'll built a full roller with a jig to make a couple more and then hopefully sell the 2 extras so buy the donor parts. I have a blown STi longblock and a 5mt to use for fab. The rest will be made from scratch so... Don’t give up on me.
Here is the current project I’m working on... But due to a broken wrist from a car accident I have to take the winter off to heal so I will be back on the Foz to finish it and start this...
http://forums.nasioc.com/forums/show....php?t=2507805
Once I get more time to sit down and take my drawings and get them into CAD with the suspension system I have already finished I will start posting again so we can discuss the project before I start throwing money at it. I really want to make something that works well and maybe make a couple more and sell em to help pay off the original project...
Johann
Bad Wagon is offline   Reply With Quote
Old 01-02-2014, 07:31 AM   #46
wreckitralph88
Member#: 374907
I was considering doing a lotus 7 with subaru parts but had a hard time figuring out how to get the engine in the front. Maybe the atom is a better idea.
wreckitralph88 is offline   Reply With Quote
Old 01-02-2014, 06:28 PM   #47
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Why would the engine be hard to get in?
I have found that my wrist is basically a piece of crap for finish the Batlfoz project so I parted out but a buddy and I are talking about a quick and easy buggy built using the coilovers suspension arms, and wheels and tires from the forster as a start. Just a fast non approved tube chassis and cheap parts to get it going for some fun at the dunes. I will link this thread to it if I start it but it won't be untill the spring if I even get going. I want to use it as a trial run for some ideas I have for the Subreal Atom to test and optimized certain ideas on how to build it so I figure if i can do something thats fast and doesn't require a lot of care I can at least look into the basics of doing some of the parts for real. Arms, knucles, chassis, welds, etc...
Old 01-03-2014, 04:25 AM   #48
wreckitralph88
Member#: 374907
The matchbook frame me and my buddy are building is too narrow up front. I could get the engine in the frame but Id have the cylinder heads sticking out the sides.
Old 01-06-2014, 02:13 PM   #49
Freeskierinsf
Member#: 371449
that is an awesome design
Freeskierinsf is offline   Reply With Quote
Old 02-08-2014, 09:49 AM   #50
senseimike
Member#: 353453
2004 Forester XT
Looks like an amazing concept!
Subscribed!
senseimike is offline   Reply With Quote
The Quaker Steak & Lube Show: Tux2122 Completes the Triple Atomic Challenge! SoonerOrLater Mid Atlantic Impreza Club -- MAIC 5 04-02-2010 03:34 PM
OT: Help decide the color of the 1970 FF-1 Project Car! (Link to Poll inside) Kostamojen Off-Topic 68 08-29-2008 11:32 PM
Saw this on the science channel. The Ariel Atom. Suber Krout Non-Subaru News & Rumors 14 11-08-2007 01:56 AM
Should I make an extra visit to the Ariel Atom facility next week??? Kostamojen Off-Topic 32 06-11-2006 07:37 PM
The Wade Robson Project mykrrrr Off-Topic 36 10-08-2003 05:39 PM
