Welcome to the North American Subaru Impreza Owners Club Friday October 31, 2014
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 12-26-2013, 05:32 PM   #726
3mlwhly
Member#: 217648
01 2.5rs
But will the 5x114 hub fit inside that rotor?
3mlwhly is offline   Reply With Quote
Old 12-26-2013, 08:03 PM   #727
05subysti
Member#: 268190
2005 STi
RWD, 18x10.5/12.5s
I don't think it will. But with so many affordable 5x114.3 rotor choices you're better off buying a pair off the shelf than doing custom machine work to the 2.5i rotors.
Old 12-26-2013, 08:30 PM   #728
3mlwhly
Member#: 217648
01 2.5rs
I agree but when you do that your parking brake drum is the wrong size, and won't have the same contact patch, machining will give you the same problem. So the solution would be swap spindles or deal with the poor parking brake right?
Old 12-26-2013, 08:57 PM   #729
05subysti
Member#: 268190
2005 STi
RWD, 18x10.5/12.5s
Or to solve the parking brake dilemma would be to go dual calipers in rear with an individual ebrake.
Old 12-26-2013, 09:27 PM   #730
3mlwhly
Member#: 217648
01 2.5rs
Oh well ya I love that idea and dream about it from time to time I'm running mine in series with the brakes, but not a solution for everyone
Old 12-27-2013, 01:05 AM   #731
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
sorry guys, the car has just been sitting in my driveway, i have been super busy with work, and then the motor on my banshee blew up, so i had to spend a bunch of money on that... and then the motor on my daily blew up, so i had to spend a bunch of time/ money fixing it... i should be making some progress on the subaru again here really soon
Originally Posted by Snydas_99legacy View Post
Any luck with the drive shaft yet??
i have all of the parts that i need now, i just need to take them in and get them put together... i found out that the 240sx slip joint for the transmission will work with the subaru transmission, so that should save some people a big headache down the road.
Originally Posted by bluemk3 View Post
Keep in mind everything before the turbo needs to be tig welded or it will break
that is not at all true... but y exhaust is indeed all tig welded
Originally Posted by 3mlwhly View Post
I have some questions about you r200 swap, I read the thread you got the idea from also. But I was curious about your set up as it's closer to mine to start.
So are you using 2.5i or sti spindles?
What are your plans for brakes if 2.5i?
I didn't think 2.5i brakes would fit over bigger hub, if they do this will be a cheap swap for me, otherwise I might aswell but sti spindles and brakes. $$$$$$
Thanks in advace, I don't mean to clutter your build thread, I really love the ingenuity, it's a sweet build
right now i have 2.5i spindles, but i dont know how well they are going to work, i plan to switch to sti spindles asap... i wish i would have just waited and got sti spindles in the first place.
i plan on fabbing up brackets to run dual calipers on the back
Originally Posted by VIsubi View Post
theres a bracket kit housing for calipers that allows 290-330mm rotors on stock 2.5i calipers over paying for brembos or wrx's, as for drive shaft. Why don't you go the proper route with that one and order one custom from the Driveshaft Shop, lol all this work means a hefty pay check. Drive shaft is not something i want to come flying apart from any kind of weld.
i will be having a custom one made, but i dont want to pay for shipping when i can have one made local
the 5x114.3 hubs will not fit inside of the 2.5i rotor... my plan is to run sti rotors, and machine the centers out to fit the 240sx hubs. ( i got the idea from the canadian dude with the drift legacy) (sorry man, i forgot your name)
olsen726 is offline   Reply With Quote
Old 12-27-2013, 01:11 AM   #732
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i did get a sweet new tig welder though... she is a dinosaur, but it will weld anything that i can throw at it... excuse the mess, it has been cleaned since then
Old 12-27-2013, 10:01 AM   #733
3mlwhly
Member#: 217648
01 2.5rs
Oh good I was hoping you were going to chime in here, I didn't feel right filling up you thread without you on here.
That works out well that the drive shift will fit the tranny. Does it fit the seal right too?
The hub will probably fit in sti rotor, there bigger than the wrx/impreza. If anything maybe machine down the hubs a little so you can keep the parking brake. That's my plan, but I was hoping impreza rotors fit so I would have to change spindles.
Also if your going to change to sti spindles, your modified s14 hubs won't fit as the sti hubs are bigger. I could be wrong but I'm pretty sure.
I've been looking at getting a tig also, does it have ac I've heard thats pretty important when welding aluminum.
Looking for to you finishing, I want to start mine soon but I don't have the car yet.. Haha
Old 12-28-2013, 08:37 AM   #734
ImmortalSoul219
Member#: 360340
Now you just need a better welding table and lighting.
ImmortalSoul219 is offline   Reply With Quote
Old 12-31-2013, 11:23 AM   #735
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Tell me about it lol, it's just a deep single car garage, so space is very limited,I can't wait to get a real shop some day
The seal seems to fit right, I haven't tested it with fluid, but the od of the nissan and subaru driveshaft are the same, so I don't see why it would leak.
The hub centric part of the hub is bigger than an sti rotor.so you have to machine a bit too make it fit
You see correct on my modified hubs not working if I switch to sti spindles, I will have to get another set of hubs, and machine them to fit the sti spindles.
Yeah, it has ac. That was the main requirement that I had when I was looking for a tig. This machine isn't as good for aluminum as a syncrowave or inverter style machine, but it works just fine for me, plus down the road I can always sell it for the same price thatI payed for it, if I decide to upgrade to something newer
Old 12-31-2013, 11:49 AM   #736
3mlwhly
Member#: 217648
01 2.5rs
That's lucky that the ds fits, I didn't even think about the centric not fitting, good to know. I just got a new to me outback impreza so I will be starting mine soon.. :-)
Old 01-02-2014, 12:47 PM   #737
3mlwhly
Member#: 217648
01 2.5rs
Hay so which driveshaft was that auto or manual... The manual version looks really strange, ant the auto looks like it could work... but I don't know if there different yokes?
Old 01-03-2014, 01:24 AM   #738
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
its out of a manual. you dont use the entire driveshaft though, just the ends of it
Old 01-03-2014, 10:07 AM   #739
3mlwhly
Member#: 217648
01 2.5rs
Ya I knew that but it has a weird 6 bolt flang on I right? Were do the u joints go? Do have a pic maybe?
Old 01-05-2014, 03:31 PM   #740
3mlwhly
Member#: 217648
01 2.5rs
Oh I think I figured it out, I was looking at s13... s14 one looks better
Old 01-06-2014, 02:00 PM   #741
3mlwhly
Member#: 217648
01 2.5rs
Ok adding some info hope that's ok
S14 hubs are 67mm (roughly) centric
Sti is 56.15mm there is not enough material to remove that from the hub
so it looks like the only option is to bore out sti brake rotors
Then oem sti wheels won't fit so get used to that.
Hubs will fit inside sti parking brake drums though so u can retain oem sti parking brakes
All s chassi driveshafts fit on trans output but I'm not sure if the s13 flange is going to be to big?
I'm not sure about axles length yet as I'm trying to get my friends to measure them for me still
I'm collecting parts still so I haven't started putting it together, so ad more and correct me if I'm wrong
Old 01-06-2014, 03:08 PM   #742
05subysti
Member#: 268190
2005 STi
RWD, 18x10.5/12.5s
Good info, and from what I've read, s13 and s14 passenger axles are needed.
So you can base off of those lengths.
I'm pissed I missed a whole rear s14 subframe assembly with axles, hubs, diff, and everything for 100..
Old 01-06-2014, 05:20 PM   #743
3mlwhly
Member#: 217648
01 2.5rs
Wow thatsa good deal, I read thatabout the axles also, ongoing to be puttingit on gd chassi and am not sure how that differs in width, what is the factory length of passenger side axles? I have a s13 one but I'm not sure the length as it's not installed
Old 01-12-2014, 12:47 PM   #744
3mlwhly
Member#: 217648
01 2.5rs
just started my build thread if you intered
http://www.rs25.com/forums/f145/t204...ject-baku.html
Old 01-17-2014, 02:29 PM   #745
FlatBlack280
Member#: 237612
2005 Forester XT 5MT
So - you're hacking up the 240SX driveshaft for the shop to make a custom piece, or are you using all of the driveshaft and fabbing mounts for the 240's driveshaft bearing?
FlatBlack280 is offline   Reply With Quote
Old 01-19-2014, 12:49 AM   #746
dcb4life88
Member#: 379049
Default swap it
do you bro but id swap it wrx....
dcb4life88 is offline   Reply With Quote
Old 01-19-2014, 01:48 AM   #747
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i will definitely check it out
yep, hacking up the factory 240sx one to have a shop make a 1 piece
Old 03-13-2014, 07:58 PM   #748
05subysti
Member#: 268190
2005 STi
RWD, 18x10.5/12.5s
Updates?
Old 03-13-2014, 11:54 PM   #749
3mlwhly
Member#: 217648
01 2.5rs
Old 07-10-2014, 05:53 PM   #750
05subysti
Member#: 268190
2005 STi
RWD, 18x10.5/12.5s
Long over due for updates!
My '07 2.5i project Vizzionz Member's Car Gallery 25 06-09-2012 04:40 AM
2.5i wrx header project coopeco2.5i General Community 9 02-03-2010 09:12 PM
Project 2.5i scoobyimp07 Member's Car Gallery 112 10-20-2008 09:28 AM
2.5i Turbo Project JLW2007RS Normally Aspirated Powertrain 13 04-02-2008 05:33 PM
2.5i n/a project. call me insane all you want iRick. Normally Aspirated Powertrain 26 01-08-2008 10:59 PM
