Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 01-07-2014, 01:00 AM   #126
calisubie
Member#: 340025
Default PW TMIC and Cusco tower strut bar
Originally Posted by Wrexflex View Post
Doesn't look like you have a strut tower bar, but does it look like one might fit? How much closer to the windshield, if any, does the PW sit compared to the stocker?
RSD has photos on their site showing their 2011 STI with Cusco bar and PW intercooler fitting together. A customer review there states "5 mm" gap between the two.
calisubie is offline   Reply With Quote
Old 01-07-2014, 06:21 AM   #127
point78
Member#: 344329
2008 Wrx, 6mt
I have a '08 WRX with a Cusco bar and PW intercooler. Plenty of room. I'll try and get some pics later today.
point78 is offline   Reply With Quote
Old 01-07-2014, 08:15 AM   #128
wrxscal412
Member#: 351604
13 WRX Moore Built
Mike@Innovative Tuned
13 WRX.
Check the link to see current fitment. No issues with my Cusco bar.
https://www.dropbox.com/sh/diw3w9gez2h88b5/6na7qrurjz
wrxscal412 is offline   Reply With Quote
Old 01-10-2014, 03:01 PM   #129
dpicc64
Member#: 364498
2013 WRX
WR Blue
Had my tuner install this for me due to snapped bolts and he left off the hood scoop fins but put the metal shroud on. Haha anyone else do this for any reason?
dpicc64 is offline   Reply With Quote
Old 01-10-2014, 03:54 PM   #130
wrxscal412
Member#: 351604
13 WRX Moore Built
Sorry, but I am not sure I follow? Any chance you can snap a pic and post it?
Old 01-10-2014, 04:10 PM   #131
kozumasbullitt
Member#: 374557
I installed the Process West TMIC today and it was much simpler than what people on these forums make it out to be. I am currently in a leg cast due to surgery on my ankle so I am only able to weight bear on 1 leg. I used a cooler to kneel on and basic hand tools to complete the install in under 3 hours. The most difficult part of the install was lining up my provided t-bolt clamps. If I used the provided worm clamps I would of finished in less than 2.5 hours. Big thanks to the OP, I must of read through your instructions 10 times last week and it made my install a breeze today.
kozumasbullitt is offline   Reply With Quote
Old 01-15-2014, 11:58 PM   #132
dpicc64
Member#: 364498
2013 WRX
WR Blue
Its a 13 wrx and ya know when you look into the hoodscoop you see fins? They didn't put that on so the engine is exposed. Is this bad? What if it rains heavily?
I do assume there's plenty of air hitting the intercooler w/o tho
Old 01-16-2014, 04:23 PM   #133
ta_forever
Member#: 305609
I have been running this for about a month now. The throttle body side hose keeps popping off. How tight can I clamp the throttle body clamp with a t-bold clamp? Is it plastic or aluminium? I just don't want to damage anything if I wrench it down.
ta_forever is offline   Reply With Quote
Old 01-16-2014, 04:57 PM   #134
tmburke
Member#: 342345
2008 WRX Hatch VF-52
SSM
I had the same problem! Fresh hose clamps (I had used ones) and a dab of hairspray on the inside of the hose before fitting it seemed to do the trick. Tighten them with a socket, not a flathead screwdriver, and don't over tighten! Worm clamps will hold fine if done properly.
tmburke is offline   Reply With Quote
Old 01-16-2014, 06:53 PM   #135
ta_forever
Member#: 305609
Ok, thanks for the tip. I'm going to give it a try this weekend and see if it stays on then. The hoses above make it a pain to readjust the tbolt, so maybe I will switch to the worm clamp.
Old 01-19-2014, 04:03 PM   #136
Boostin_Blobeye
Member#: 366620
2004 WRX
Recently traded my STI TMIC for a Turbo xs TMIC. I have a 2004 wrx. The Turbxo XS was off of a 2005 STI. Took my tmic out, and now I'm trying to fit my turbo xs in. I heard something about having to bend a bracket? Which bracket do I have to bend for it to fit in there? Been trying for a while.
Boostin_Blobeye is offline   Reply With Quote
Old 01-19-2014, 07:32 PM   #137
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
did you read the thread title?its for a wrx 08 and up,and process west. you have none of those.
Old 02-22-2014, 10:29 PM   #138
MT-REX
Member#: 291978
2008 WRX 5dr
Default Should I wait
I'm upgrading my '08 to TP Stage 3.52 (VF52, PW TMIC, one step colder spark plugs, fuel pump and EBCS)....right now I have every part except by new turbo and the TMIC and fuel pump are the only parts I can install without my new map. Would you recommend that I just wait to install the TMIC until I get the turbo since I'll have to remove it to install the turbo?
I've taken my stock TMIC off several times so I'm not expecting the swap to be an issue for me, but it sounds like the PW TMIC is more difficult than stock to take on and off.
Thanks for any advice!
MT-REX is offline   Reply With Quote
Old 02-25-2014, 06:38 AM   #139
NBRX
Member#: 356927
'15 WRX Limited
Anybody else's intercooler sit crooked on the
Passenger side. No matter how much I tried to get it to sit straight it just didn't happen. The driver side is about 1/4 lower then the driver side.
The install was waaaay easier then this thread made it seem by the way.
NBRX is offline   Reply With Quote
Old 02-25-2014, 06:40 AM   #140
NBRX
Member#: 356927
'15 WRX Limited
Ya man the pw is def gonna be a pita to take on and off . There's very little space once it's installed, unlike the super easy stock intercooler.
Old 02-25-2014, 02:31 PM   #141
point78
Member#: 344329
2008 Wrx, 6mt
HUH? It's literally takes like 5mins.
Undo 3 bolts holding driver side bracket, loosen T-bolt clamp on the "cold" side.
remove 2bolts holding Bypass valve
undo one bolt under passenger side of TMIC, loosen T-bolt on "hot" side.
done….
Saw another post with same problem-it turned out to be the wrong hose was supplied, guess there are 2 hoses-only slightly different.
Old 08-04-2014, 01:48 PM   #142
sebi1990
Member#: 362910
2013 Impreza WRX
The hose touches the hot side of the IV WTF is up with that tho?
sebi1990 is online now   Reply With Quote
Old 08-04-2014, 01:50 PM   #143
sebi1990
Member#: 362910
2013 Impreza WRX
Do you have oil in the hoses? Are you using Tbolt clamps?
Old 08-05-2014, 05:35 PM   #144
peekeesh
Member#: 316476
12 WRX
Anyone noticed that the car vibrates more at idle after installing processwest splitter? It is much felt on the steering wheel and it's a little annoying to hold on to it at a stop. The hood vibrates a lot as well when idling.
Sent from my C6806_GPe using Tapatalk
peekeesh is offline   Reply With Quote
Old 12-05-2014, 02:41 PM   #145
blue sedan
Member#: 311622
2010 WRX
Just installed the Process West Tmic. The Correct T -Bolt clamp sizes are:
Turbo flange:2.25"-2.65"
Intercooler inlet:2.75"-3.10"
Intercooler outlet:3.01"-3.25"
Throttle body:3.01"-3.25"
I really didn't like how the t -bolt clamp on throttle body was fitting, so I removed it and replaced it with an extra strong worm clamp .
blue sedan is offline   Reply With Quote
Old 05-25-2015, 06:40 PM   #146
Steye05
Member#: 197008
2013 WRX
Plasma Blue
Back from the dead but is the best thread for installing the process west tmic. I ended up breaking the bolt that holds the passengers side bracket and goes from tranny to motor. Luckily the angle is ok and the one top bolt holds just fine and tight. Rusted bolt and terrible subaru hardware seems to get cheaper by the newer year.
Steye05 is offline   Reply With Quote
