Old 02-19-2013, 11:51 AM   #201
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
What do I need for a 09 sti trans swap into a 03 wrx wagon.
Someone is selling 09 STI 6 speed transmission, Differential, axels, hubs, slave cylinder, flywheel, clutch.
kevin85193 is offline   Reply With Quote
Old 03-16-2013, 09:42 AM   #202
chrisp0192
Member#: 350191
2003 WRX
Sonic yellow
Default nice.
this was a huge help, it answer alot of questions i had and clear somethings up as well.
Thanks for putting your time into this one.
chrisp0192 is offline   Reply With Quote
Old 03-29-2013, 08:01 PM   #203
Freddygapex89
Member#: 351815
Default 03 Wrx looking to swap Sti tranny
I'd like to swap an Sti tranny into my 03 Wrx with a Sti swap from 06 what tranny can I do this with and do it as simple as possible I found one on eBay but I want the swap to he unbolt and rebolt what year tranny do I need parts exc.please hell
Freddygapex89 is offline   Reply With Quote
Old 04-25-2013, 07:44 AM   #204
optikul81
Member#: 248698
2005 Baja Turbo
So I am starting my six speed swap and just have a few things that I am confused about. First here is the parts list:
2005 Subaru Baja Turbo (4EAT)
2005 STI 6 Speed Transmission
6mt Transmission Mount + Brace
6mt Slave cylinder
6mt Clutch + Flywheel
6mt R180 Rear Diff 3.90
6mt Factory Short Shifter assembly
From reading this post and a bunch of others you can supposedly use a WRX 4EAT drive shaft correct? Since this is a Baja I am planning to reuse my auto drive shaft.
My main question is the axles...I dont want to swap my hubs/rotors/brakes. So i'm assuming I need to do the Hybrid axles with the new races.. i dont have the link handy but I found it on this forum.
Can I use my 4EAT starter with the 05 6mt Transmission?
Thoughts?
Thanks!
optikul81 is offline   Reply With Quote
Old 06-09-2013, 08:57 PM   #205
WRXfool83
Member#: 300988
1998 WRX LTD RA
blue
will a 6speed clutch bolt onto a 2.0l flywheel. what i'm asking is dose it matter the fly wheel or will both 6 and 5 speed clutches bolt up to the same flywheel?
WRXfool83 is offline   Reply With Quote
Old 06-09-2013, 09:23 PM   #206
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
I don't think it works that way, but I believe that the clutch/flywheel set is interchangeable. Meaning a 5 speed clutch and flywheel or a 6 speed clutch and flywheel will work with either tranny. I think the spline on each tranny is the same. If I'm wrong someone will pipe up.
prochucker is offline   Reply With Quote
Old 06-10-2013, 11:40 AM   #207
DCCDPro
Member#: 227549
Just to mention that we do not go with the spiider name anymore for our DCCD controller and prefer to be called dccdpro. Just as a reference for others if they are interested to do a similar swap or can't find that name on the web.
DCCDPro is offline   Reply With Quote
Old 06-22-2013, 02:46 PM   #208
theo79
Member#: 159621
2002 WRX - WRB
JDM v7 Spec C drivetrain
Default 07 JDM Sti (V9) transmission into a USDM 02 wrx
Question about swapping 07 JDM Sti (V9) transmission into a USDM 02 wrx.
Referencing page 4:
USDM
3.454 / 1.947 / 1.366 / 0.972 / 0.738 / 3.900FD - '02-'05 USDM WRX
All-Wheel-Drive 6-speed Transmissions
3.636 / 2.375 / 1.761 / 1.346 / 1.062 / 0.842 / 3.900FD
- JDM Impreza WRX Spec C/STi/STi Spec C RA/V-Limted/S202/S203/S204/Spec C RA-R
02 USDM wrx and JDM s204 (v9 aka 06-07) have the same 3.54 thus allowing me to keep the stock rear diff.
Parts needed for this swap are:
-Transmission- trans code TY856WB6KA
-Automatic driveshaft from impreza 98-07 OR yolk from a wrx with an sti driveshaft
-DCCD Pro
-07 sti slave cylinder- not needed
-07 Sti clutchfork
-07 sti linkage
-07 sti shifter + assembly
-04 sti Front Axle stubs
-04 sti oil seals
-04 sti circlips
-Re use 02 wrx clutch and flywheel since it is brand new and has less than 10 miles on it. Wait until it goes
Please help me out here, I understand the swap has been done before, but I haven't been able to find any specific information about swapping JDM to USDM. I am also concerned about harnesses matching up from JDM to USDM
Please note that all 04 sti parts will be USDM version, not sure if that matters or not.
theo79 is offline   Reply With Quote
Old 06-23-2013, 12:26 AM   #209
DCCDPro
Member#: 227549
Default Spiider is now DCCDPro
Just for those who might be interested in an aftermarket DCCD controller, our product is called DCCDPro Universal Controller and if you are interested to read more about the latest version of the product and the features available you can have a look at this link on our website:
dccdpro.com/zcart/index.php?main_page=product_info&cPath=1&products_ id=2
Kind regards,
-Jeff Reid
DCCDPRO INC
Old 06-23-2013, 12:00 PM   #210
nimrod8560
Member#: 274267
2004 FXT
Built, FPgreen, & STi 6MT
Kind regards,
-Jeff Reid
DCCDPRO INC
You guys need to do a group buy on them here!
nimrod8560 is offline   Reply With Quote
Old 07-08-2013, 01:05 AM   #211
PigWagon
Member#: 360961
hey quick question, I have a 2002 subaru wrx some work done too it not too sure what (literally just got it) all I know is it has a lot of cobb tuning parts including downpipe heat shield those are the two I know off the top of my head but I know there's some decent work done to it, only problem, ITS AUTOMATIC. I prefer auto to manual in the past but with this car I feel like it being automatic is so lame. Plus, the transmission has roughly 140k miles on it so my question is....
Should I do a trans swap (to manual)
-What would I need
-How much would It cost
-If I can't figure it out myself what kind of shop would do it.
thanks.
PigWagon is offline   Reply With Quote
Old 07-08-2013, 11:57 AM   #212
AlbanianImpreza
Member#: 38506
2000 NEW hotness RSC
SRP SON!
to do a 6spd swap? exactly what he said, plus new pedal box for clutch, with lines master and slave cylinder and lines. pricing you need to find out for yourself. it varies. could be 3grand to 7 grand. if you cant figure it out yourself. dont do it.
AlbanianImpreza is offline   Reply With Quote
Old 07-08-2013, 02:17 PM   #213
PigWagon
Member#: 360961
Ok thanks
Old 07-09-2013, 11:46 AM   #214
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Right, if you can't figure it out, don't do it.
Wrong. If you can find someone that can figure it out, or help you, DO IT.
You don't list where you are in your profile that shows up with your screen name. That is important information when asking if we know of someone to help you. In Jacksonville Florida, I could point you to several people that can get it all done for you for the right price.
Old 07-29-2013, 08:28 PM   #215
Taskarnin
Member#: 363737
Default 2002 5 mt outback spec B swap?
I've been reading through this thread and there's a lot of great information. I'm new to subaru swapping, however I have rebuilt a 2.5L dohc engine in a 98 legacy outback. (Know enough about wrenching to get in trouble!) That being said I can follow a repair manual!
Notes on my wagon: 2002 5mt wagon, EJ25 SOHC engine
I know that I should (?? correct me if I'm wrong) be able to do a full STI swap into my outback wagon (transmission, rear diff, engine, wiring harness, ecu?) as outlined in the original post (correct me if I'm wrong here, still figuring out details/doing research).
However I've been having a lot of trouble figuring out if I can swap in a Spec B setup (I would like the longer gear ratios, as I want this to be a stock swap, DD trollol wagon). Can anyone help me out on this? At the very least I was expecting: Front undercarriage (engine mount, transmission mounts, steering track, maybe control arms?), rear undercarriage (Rear diff mounts, hubs, knuckles/suspension), and of course transmission/motor/flywheel, internal clutch linkages. (My current motor has 241K on it... not sure if I'd want to re-use it even if I could).
Thanks in advance for your help! Still in early planning/list phase.
Taskarnin is offline   Reply With Quote
Old 08-05-2013, 09:57 AM   #216
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
The Spec B externally is the same, so the swap would be the same as one of the others.
Old 08-05-2013, 05:26 PM   #217
Taskarnin
Member#: 363737
Thanks! So that means that swap info for a regular STI 08-09ish it should work for spec B of same years. (Really looking for the longer gear set, for a more rounded swap, don't really want the very short track 6 speed as I wont' be doing many track days in the car).
Old 08-05-2013, 06:19 PM   #218
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Right, IIRC all the newer trannies are female, meaning the Prop shafts are male.
Old 12-13-2013, 06:33 PM   #219
staiflexat1
Member#: 372542
Default Built 5 Speed Or A '05+ Sti 6 Speed
Gentlemen,
I've been doing my research and talked to a few shops. No one can give me an answer for which is better.
Most say it depends on opinion.
Here is the story. I got an '02 WRX with a 2.5 short block and 2.0 heads built motor. My goal is to have 350 whp and about 320+torque.
A built 5 speed costs about 1900$ and maybe 400+$ in labor for everything to be installed. Total price will be about $2500. Some people say this is the way to go. The built five speed won't break at all with the power I wanna make. They say it won't break at all if I have 375 hp or under and 350 torque and under.
On the other hand, others say to do the 6 speed swap out of an '05 STI because it is much stronger and it won't break ever. They also say that the built 5 speed will still break.
The STI trans and everything that I need would be about 3500$.
Which is the better way to go?
I wanna be able to drive hard and launch and downshift from 5th to 3rd on the highway with no issues.
Thanks for taking the time!
staiflexat1 is offline   Reply With Quote
Old 12-18-2013, 01:38 PM   #220
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Originally Posted by staiflexat1 View Post
Gentlemen,
I think you have been posting on FB about this as well. I say go with the 6 speed. Is the early shift to 2nd and 3rd going to hurt you in a1/4 mile. I think not. Granted that in the 1/4 you will have to shift into 5th so an extra shift , but is the gain of lower gearing negated by it?
Old 12-20-2013, 10:48 AM   #221
coolzeero
Member#: 376593
Great job dude
coolzeero is offline   Reply With Quote
Old 12-24-2013, 02:32 PM   #222
thejaredhuang
Member#: 86206
2006 WRX Wagon
Its probably been answered but when you swap to a 6spd what tire size should you assume is stock? The STIs had a 225/45/17 while my car, 06 WRX, is a 215/45/17. I know its not a significant difference but I'd like to know.
thejaredhuang is offline   Reply With Quote
Old 12-31-2013, 03:13 AM   #223
sir_enigma
Member#: 351594
I'm a little lost guys... What clutch should I get if I have an 06 sti engine, but an 05 wrx tranny?
sir_enigma is offline   Reply With Quote
Old 01-07-2014, 07:00 PM   #224
EVL RS-T
Member#: 30071
2001 RS-T
2015 XT
Clutch kit selection is determined by the transmission... So get something made for the 05 wrx.
EVL RS-T is offline   Reply With Quote
Old 01-24-2014, 12:01 AM   #225
BlueToRed
Member#: 362319
2008 Subaru WRX
WRB Stage 2+ & WRB 13 STI
I know this question isnt a 06 to 02 drivetrain swap question but its related i want to do an 08 sti drivetrain swap into my wrx 08 sedan and the question here is if i swapped said drivetrain and trans in would i also have to the differential adjuster by the shifter??
BlueToRed is offline   Reply With Quote
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 808 08-12-2015 09:01 AM
Feeler: 06 wrx sti 6-speed drivetrain swap... 06TRDude Drivetrain 8 02-23-2009 07:50 PM
Cost estimates for 6-speed swap into an 02 WRX? aasim_a Transmission (AT/MT) & Driveline 24 05-31-2008 04:37 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 01:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 04:15 PM
