Old 01-07-2014, 05:47 PM   #1
SkorpionZ
Member#: 365986
2016 WRX
Crystal White
Default Am I stupid, or?
Okay, so I drive an 06 saabaru. I got rs uels, as well as the tsudo, high flow cat. 2 Questions, 3 holes in the cat....why? I thought there was only 2 o2 sensors, also it came with a "L Shaped CEL fix" What is this? How does it work?
SkorpionZ is offline   Reply With Quote
Old 01-07-2014, 07:36 PM   #2
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
The CEL fix is probably a tube that goes between the secondary O2 sensor and the bung. The second bung can probably just be capped. Some cars have more O2 sensors based on emission requirements in different states
Rudgers73 is offline   Reply With Quote
Old 01-07-2014, 07:44 PM   #3
Turd Nugget
Member#: 346017
2013 STi Wagon
Probably there in case you want to stick a wideband in it.
Turd Nugget is offline   Reply With Quote
Old 01-07-2014, 08:54 PM   #4
SkorpionZ
Member#: 365986
2016 WRX
Crystal White
There's one pre cat, one right after the cat and then one near the end of the pipe. Which ones should be used for o2s?
Old 01-08-2014, 12:54 PM   #5
Monstrsubi22
Member#: 256245
Your first 02 will be pre cat, you can use either of the further two post cat ports for you second o2; although, with a higher flow exhaust you may want to use the further downstream hole to avoid possible cel.
Monstrsubi22 is offline   Reply With Quote
Old 01-08-2014, 01:41 PM   #6
SkorpionZ
Member#: 365986
2016 WRX
Crystal White
Good call, and how would I go about plugging the other hole? Or shoul I get just a a/f gauge? I wouldn't want a wide as I don't think because they're like double the price.
Old 01-08-2014, 05:31 PM   #7
Omni003k
Member#: 348963
2008 WRX
Lightning Red
If your not getting a wideband, save your money. Narrow bands are useless.
Omni003k is offline   Reply With Quote
Old 01-13-2014, 12:17 PM   #8
Monstrsubi22
Member#: 256245
You can get a plug online or at any exhaust shop that just screws into the extra port.
Old 01-13-2014, 04:54 PM   #9
Kuros
Member#: 328669
2011 STi boosted FRS
04 sti
This.
Just make sure it doesnt leak (to avoid the annoying PTH PTH PTH PTH sound of an exhaust leak)
Kuros is offline   Reply With Quote
Old 01-13-2014, 06:39 PM   #10
JoshP
Member#: 94350
I think its the same as the oil drain plug
JoshP is offline   Reply With Quote
Old 01-13-2014, 07:58 PM   #11
EdHilario
Member#: 137398
2004 Impreza 2.5RS
The first bung is for your pre-cat O2 (AFR) sensor.
The next one will probably be in the cat and then after the cat.
This will be for your rear cat O2 sensor.
The CEL fix is just a spacer to use for your rear O2.
Since your car only has the two O2 sensors, use the first and third holes and ask your exhaust shop when installing this to plug that middle port.
EdHilario is offline   Reply With Quote
Old 01-14-2014, 09:26 AM   #12
SkorpionZ
Member#: 365986
2016 WRX
Crystal White
Old 01-15-2014, 01:37 PM   #13
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Yep assuming the threads match.
