Old 01-07-2014, 12:50 AM   #1
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Default Control arm compatibility
Was under the Baja yesterday and noticed the front control arm bushings could use replacing and the arms themselves have some surface rust.
Was wondering about swapping them with aluminum control arms from an STI (just wasn't sure of fitment). Any help is appreciated
JungleFevre is offline   Reply With Quote
Old 01-07-2014, 01:41 PM   #2
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Looks like it would take a lot of customization, so I will probably just replace all the LCA bushings with Whiteline or AVO and call it a day.
Old 01-07-2014, 02:07 PM   #3
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
I replaced the bushings with OEM ones and they are expensive, like 120 a set.
Baja_Gernaut is offline   Reply With Quote
Old 01-07-2014, 10:39 PM   #4
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
For both the inner and rear it would be about $180 total from Whiteline + whatever the ball joints cost
The OEM ones I found are really cheap
http://www.fredbeansparts.com/subaru...-bushings.html
Old 01-08-2014, 02:24 PM   #5
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
I know i got jipped because they were purchased at my local dealer
Old 01-15-2014, 01:09 PM   #6
rdhayward
Member#: 322076
2002 2.5RS
Blue RidgePearl MC
Here are a couple of photos of JDM aluminum Legacy BE/BH front control arms I bought last May via eBay, had them powdercoated, then installed with Whiteline bushings.
File Type: jpg 2013-06-07 #01 powder coated aluminum arms.jpg (61.0 KB, 33 views)
rdhayward is offline   Reply With Quote
Old 01-15-2014, 07:53 PM   #7
frogmonk
Member#: 74489
'04 FXT/05 Baja Tur
'71-FF1/05 Saab-92X-Aero
GC aluminum control arms fit directly. That's what I have on my Baja.
frogmonk is offline   Reply With Quote
Old 01-15-2014, 09:10 PM   #8
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
How is that possible? The rear busing is vertival on the baja and horizontal on the gc control arms
example
http://www.avoturboworld.com/images/...ca/lca_011.jpg
Old 01-15-2014, 10:37 PM   #9
Hawk296
Member#: 14555
1995 Impreza L
Baja
Really?
On my 05 turbo they are horizontal just like the GC, GD imprezas
EDIT: Just so you know I am not completely crazy, I just went out in the freezing cold and took some pics.
Rear bushing, driver's side front
Hawk296 is offline   Reply With Quote
Old 01-15-2014, 10:42 PM   #10
Hawk296
Member#: 14555
1995 Impreza L
Baja
The one you posted looks like a 2004 and up Legacy control arm (BL,BP). That's a generation newer than the Baja. Bajas are off of the previous BE,BH chassis.
Old 01-16-2014, 07:00 PM   #11
frogmonk
Member#: 74489
'04 FXT/05 Baja Tur
^ Correct. Like I already posted, the alum. CA's on my Baja came from a GC Imprezza. One way I was able to confirm was that they share the same part numbers for the CA's. The GC arms also fit the SF Foresters (pre -02my).
Old 01-31-2014, 08:09 AM   #12
Legacy
Member#: 10188
2007 Forester XT
That is correct, GC CA's will also fit 2000-04 Legacy, 02-07 Impreza wagons and 98-02 Foresters. Correct me if I'm wrong : Baja is effectively an 00-04 Legacy wagon.
OP- I have a set of GC STI aluminum control arms ready to go for $250
Legacy is offline   Reply With Quote
